Old 02-07-2008, 11:52 PM   #1
Fav Mod: Coilovers
Default left rear lower strut bolt...STUCK
okay so me and my friend spent a good hour trying to loosen ONE
bolt that stood between me and new springs... finished the fronts just fine... did the right rear.. little trouble, but we got it taken care of. then we got the left rear upper strut bolt out no problem, then we get to the lower one.... it seems like it is way over torqued. we broke two ratchets trying to loosen it. then we used the spare tire wrench and it is screwed up on the inside now... we sprayed the shiz out of it with wd40 so maybe some luck in the morning. any of you guys experience this? any suggestions?
thanks in advanced!!
kyle
ChefMasterfunk is offline   Reply With Quote
Old 02-08-2008, 03:44 AM   #2
Car: 2005 STI
Fav Mod: Methanol
Default Re: left rear lower strut bolt...STUCK
Suggestions:
-Heat the surrounding area with a torch
-Try tightening it a bit, then backing it out
-Use a breaker bar with a pipe
-impact gun
-bigger impact gun
I had the same problem with an acura crank pulley bolt, nothing worked, and I couldnt heat it. 1/2" impact wouldnt work, 3/4" impact zipped it right off.
xrocket21 is offline   Reply With Quote
Old 02-08-2008, 03:55 AM   #3
Fav Mod: CAR LIFT & Protune!
did you use the impact to remove the top bolt, as i suggested? if so howd that work for ya?
i would heatthe actual nut itself with a torch then impact. this will allow to nut to expand over the unexpanded bolt. but dont heat too much or itll just break.
Old 02-08-2008, 04:08 AM   #4
abracious
Fav Mod: Track time
wd40 is no where near as good as PB Blaster.Try that.
If that doesn't help, and the above suggestions, cut the damn thing off.
Old 02-08-2008, 10:05 AM   #5
Fav Mod: Coilovers
yeah i used the impact gun for the top bolt no problem, i just dont have an 1/2 gage 19 mm bolt for the gun.... ill try some pb blaster with some heat today and see what happens
Old 02-15-2008, 10:37 AM   #6
Car: 06 WRB STI
Send a message via Yahoo to WillisW555
Did you get the bolt off? I had the same problem with the right rear lower bolt. We broke a socket trying to get it off. It was ridiculous. We only had an electric impact gun and it was a too big to fit in there.
We finally got it off after 3 rounds of PB Blaster, 1 breaker bar, 1 wrench (to keep the whole thing from spinning), 1 impact socket, and the biggest friend there (to stand on the breaker bar).
WillisW555 is offline   Reply With Quote
