Old 02-07-2008, 02:03 PM   #1
Car: WRB 04 STi
Default getting engine at TDC
im going to atempt to do a leak-down test on my engine. how do i get each cylinder at TDC.
04superzillaSTi is offline   Reply With Quote
Old 02-07-2008, 06:47 PM   #2
Car: Black 04 STi
Default Re: getting engine at TDC
-First, take all of your plugs out. -Then you need to screw the little whip hose with the o-ring seal into one of the spark plug holes.
-Next you need to put your finger over the hole from the end of the whip hose.( It's the little air fitting that you plug into the guage part of the leakdown testing tool.)
-Now, have someone get in the car and make sure to set the park brake and put the vehicle in neutral. Have the person "bump the starter" one little bump at a time until you start to feel pressure coming from the hole that your finger is over.
-This means you are getting close to top dead center (TDC).
You may have to do this a bit to get the 'Feel of it". The pressure only happens as you are coming up on TDC because the valves are closing and it is building compression/pressure.
-When you think you can't bump the engine anymore or it will open the valves and spin over you connect your gauge to the whip hose and shop air. Make sure you zero/calibrate your guages.
-If you are just before or at TDC the engine may move just a touch because it is getting to the true TDC and will stop and give you your leakage reading. If you went just a bit past TDC and when you hook up your gauge the engine spins over quite a bit and shows you have A LOT of leakage you need to disconnect the gauge and try to bump the engine till TDC is found again.
-If a reading seems odd or shows more leakage than most other cyl. try it again just to make sure. They also sell a little adapter that fits on your whip hose that is a whissle so when the engine is building the pressure it whissles to let you know when you hit TDC. It is very easy to find TDC so don't get frustrated, just keep trying.
hellomyles is offline   Reply With Quote
Old 02-12-2008, 05:47 PM   #3
Fav Mod: Tires and Brakes!
The way I did it once was,
- take all the plugs out.
- Stuck a telescoping magnet in the cylinder you want to test.
- Put the car in gear and move the car forward or backwards til the magnet rod is at the tallest point. (or in our case, sideways. I did this on an inline motor so id imagine its probably 87x's easier)
- If that cylinder is doing horrible, your probably on the exhaust stroke! You need to be on the compression stroke (all the valves are closed)
gosu is offline   Reply With Quote
Old 02-13-2008, 04:52 AM   #4
Car: WRB 04 STi
ah! thats a great idea. thanks
Old 02-13-2008, 07:55 AM   #5
Car: 04 subaru sti
Fav Mod: 35r turbo kit
well you have to remember, on boxer motors, top dead center the pistons are halfway in the stroke and all 4 are even with each other..it may be more work, but take off your belts and the stock crank pulley and you should be able to see the timing marks
will12345 is offline   Reply With Quote
