Old 01-12-2008, 04:22 AM   #1
Fav Mod: broken kyb strut.
Default blow-thru boost tube
I'm going to make my own blow-thru maf and was wondering about a couple of things?
1.does the intercooler pipe have to be a curtain size?
2.can i just loop or block off all the vac lines running to the intake?
3.what is the sensor on the inner fender well behind the block off plate?
thanks in advance.
04_Sti_Man is offline   Reply With Quote
Old 01-12-2008, 01:07 PM   #2
Default Re: blow-thru boost tube
anyone?
Old 01-12-2008, 01:57 PM   #3
Perrin GT30r
Fav Mod: 30r
Send a message via AIM to Kaltex
I dont have any answers to your question but just wanted to warn you to be ready for some extensive tuning....I just had my car tuned and it took nearly a week to get everything running properly with the blow thru setup....
Kaltex is offline   Reply With Quote
Old 01-12-2008, 08:44 PM   #4
anyone else have diffaculties tuning with the blow-thru.
and what problems accured with the tune?
Old 01-12-2008, 08:55 PM   #5
Car: White 93 EG8
Send a message via AIM to EBTurbo
do you guys mean blowing through the MAF? why would you do that? i suggest keeping th stock setup IMO.
EB Turbo
EBTurbo is offline   Reply With Quote
Old 01-13-2008, 07:49 AM   #6
Perrin GT30r
Fav Mod: 30r
I bought the perrin 30r turbo kit and the only way to retaiin the maf is to add a blow thru boost tube
Old 01-13-2008, 08:18 AM   #7
Car: White 93 EG8
If you are going to do it i would recommend buying the Perrin blow-through boost tube and, getting a good tune. unless your a good fabricator and have the right tools, buy the boost tube.
EB Turbo
Old 01-13-2008, 01:30 PM   #8
Perrin GT30r
Fav Mod: 30r
EB Turbo
Definately correct...thats what i did..
Old 01-13-2008, 02:52 PM   #9
i can make one just the same as theres if not better, whats the diffaculties that made it so hard to tune?
i had a blow thru on my eclipse gs-t and the tune was simple.
Old 01-17-2008, 07:09 PM   #10
Car: 04 Aspen White STi
Fav Mod: exhaust powered intake
or you could get the maf bracket off an intake and cut the intercooler pipe so the maf can fit in that spot on the intercooler ($50 or less after silicon hose and clamps)
B4RSTiwsnc is offline   Reply With Quote
Old 01-18-2008, 04:24 AM   #11
very true, but i hate couplers blowing apart so the less there are the better for me.
Old 01-19-2008, 09:25 AM   #12
Fav Mod: AP
I think I read that the pipe diameter around the MAF has to be same as stock, or it won't read correctly... makes sense, but I'm no expert.
rmarceau is offline   Reply With Quote
