Old 01-05-2008, 11:56 AM   #1
Car: 05 WRX STI OBP
Fav Mod: learning how to heel toe
Default How to prime youre new Turbo
Ok ive seen this question everywhere so here it goes.Lets say youre going to put in an upgraded turbocharger and you have to prime (lubing the turbo before starting)it. Well since youre going to upgrade youre fuel pump anyway youve probablly aready ran the fuel lines dry and unpluged the fuel pump relay. now since the pump is already out and the lines are dry when youre turbo is bolted on and all lines are hooked up just crank the engine for 10to 15 seconds or until there is oil comming out of the return line from the turbo. and your turbo charger is prime and ready that simple.
Old 01-06-2008, 09:17 PM   #2
Car: 05 STi Aspen White
Fav Mod: 20g MMMMMM
Send a message via AIM to szeny
Default Re: How to prime youre new Turbo
or you can pull the ignition fuse under the dash and crank.. car wont start
szeny is offline   Reply With Quote
Old 01-06-2008, 10:01 PM   #3
Car: 05 WRX STI OBP
right just about anything to disable the car from starting when cranking i just said fuel because youre prob. gonna upgrade the pump anyway
