Old 01-03-2008, 11:06 AM   #1
Fav Mod: Crawford
Send a message via AIM to 07 Flt4bxr
Default How to install gauge set up on 07
on the 07 STi i was told by 2 different dealers and their service guys that u can not put the 3 gauge set up on the console because the clock is linked to the airbag light of the passenger seat, if disconnected air bag wont work.
has anyone done a gauge set up on the console for an 07?
i was thinking of keeping the clock/airbag unit plugged in and hiding it under the dash and running power from else where to the gauge set up.
..any thoughts or input?
07 Flt4bxr is offline   Reply With Quote
Old 01-03-2008, 01:17 PM   #2
Car: 07 STI UGM
Default Re: How to install gauge set up on 07
Yes the airbag light stays on but you can leave it plugged up and just put gauges pod over it, just be sure to ziptie it off or else you will have rattles (even more than usual)
bwoosti is offline   Reply With Quote
Old 01-03-2008, 01:31 PM   #3
Trader Rating: (15)
My airbag light is still on. I put my gauges in like 1 month ago. All hook the clock pod back up when im not lazy. hahah
Old 01-03-2008, 01:43 PM   #4
Fav Mod: Crawford
alright thnx for the info.
Old 01-03-2008, 04:31 PM   #5
I'd run power from the radio and HVAC harness. This way you can listen to the radio when then engine isn't running without the warning beep driving you mad from the gauges. Plus you get one uniform sweep from the dash and gauges assuming you're going with Defi's.
Spoolin415 is offline   Reply With Quote
Old 01-03-2008, 07:18 PM   #6
Fav Mod: Crawford
i was gonna go with the STRI which also have the sweep.
