Old 12-30-2007, 11:28 AM   #1
Car: 07 WR Blue STI
Default request how to removie dashboard to remove firewall deadning
Anoxeric Sti has inspired me to put myself and my car on a diet to get more performance for free
Can someone make a step by step instructions how to remove the dashboard then how to remove the firewall sound deadning
gOt_rally? is offline   Reply With Quote
Old 12-30-2007, 11:33 AM   #2
Car: 2006 Subaru WRX STI
Fav Mod: Maddad DP and P&L Catback, stage 2!!!
Send a message via AIM to haroman311
Default Re: request how to removie dashboard to remove firewall deadning
dunno if u will find one of those... id just start pulling stuff to be honest.
i had a brand new 2007 tundra come in to dealer with a dash rattle, it only had 5k on the odometer. i had to disassemble the entire dash and foam everything to get rid of the rattle. basically u probably jsut remove your shifter trim, possibley the plastic cover that goes arround the trans tunnel. stereo faceflate, stereo, glovebox, gauge cluster, and so on. theres probably alot of screws and bolts that are holding it on then once everything looks good it should just pull out im sure.
remember to disconnect the negative cable on the battery, because you will probably have to disconnect airbags to remove the dash completely.
now this isnt a guide obviously, but maybe it will put yoru foot into the door.
haroman311 is offline   Reply With Quote
Old 12-30-2007, 12:38 PM   #3
Car: 07 WR Blue STI
Thanks but im really looking for something more detailed as i dont want to start ripping apart my car and halfway in the process get stuck and have to put it all back.
Old 12-30-2007, 01:45 PM   #4
Fav Mod: Ported Heads & Cams
why not buy the service manual on cd or something.. that would give you good instructions... I doubt you`ll ever find anyone on here who took pics with instructions on how to remove the dash and get it back together
STi_Guy04 is offline   Reply With Quote
Old 12-30-2007, 03:02 PM   #5
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
just leave your car how it is if your not on the track than you wont even notice a difference. Every 100 pounds loss is about .1 sec on the quarter mile removed off of your time. so i heard
Old 12-30-2007, 03:26 PM   #6
Car: 07 WR Blue STI
Sry I don't live my life a 1/4 mile at a time .
I track the car often and I am doing more then just removing the deadning. I plan to loose around 100 lbs from the front make the car more balanced.
Old 01-27-2008, 10:09 AM   #7
Car: 02 WRX
Fav Mod: TE37 Time Attack Edition
Send a message via AIM to wrx650ps
why dont you just buy some pullies or something it's not free but much less hastle....i took alot off just by hand looking under or removin ur glovebox gives you SOME access...clearly not all but it's a start
wrx650ps is offline   Reply With Quote
Old 01-27-2008, 07:09 PM   #8
I would be interested in this as well, I have a gash in my dash and I will be buying a replacement down the line. So a way to remove/install would be lovely!!!!
BBKG79 is offline   Reply With Quote
Old 01-27-2008, 07:11 PM   #9
Fav Mod: Zzyzx Coilovers
everything you need is in the service manual. buy one.
Old 01-27-2008, 07:12 PM   #10
Car: SGM 06 STI
Fav Mod: Prodrive GC010G's
Send a message via AIM to CharcoalSTI
is it a dirty gash ???
CharcoalSTI is offline   Reply With Quote
Old 01-27-2008, 07:28 PM   #11
If you're not being sarcastic then the answer is no.
Old 01-27-2008, 07:47 PM   #12
You know what you are right, and I forgot I have access to the 04 service manual in pdf. A little digging and it's in there:
2004 Subaru Impreza WRX STi
16. EXTERIOR INTERIOR TRIM
19. Instrument Panel Assembly.pdf
Old 01-27-2008, 07:48 PM   #13
Car: SGM 06 STI
I am being foul mouthed of course
Old 01-27-2008, 07:51 PM   #14
I figured that, just checking. Sometimes it's hard to read into things online
