Old 12-23-2007, 02:21 PM   #1
Fav Mod: Big Turbos
Send a message via AIM to blaqsubereezy
Default Pressure source from turbo? - BLITZ ebc
since i recieved no help on Nasioc ill try here....
i am in the process of installing a Blitz Dual spec s electronic boost controller. i purchased it from another member and he told me that its plug and play from the way he sent it to me...But i cant figure out what to plug the "in" port with. the online manuel shows drilling a bung into the IC pipe b4 the throttle body? Cant i tap into a line instead? i have everything else hooked up except this..
i have a gt35r so there is no line to tap off of it like a vf turbo. one supplied plastic lines goes from the unit to a vacuum source which i did. one line from the solenoid to the wastegate..now i need one from under the solenoid to ....
blaqsubereezy is offline   Reply With Quote
Old 12-24-2007, 10:48 AM   #2
Fav Mod: Big Turbos
Default Re: Pressure source from turbo? - BLITZ ebc
ask a friend to ask a friend? someone has to be running the blitz ebc??
Old 12-24-2007, 12:53 PM   #3
Car: 06 Suabru STI 2006
http://www.blitz-performance.com/inc...%20i-D.pdf
tossty is offline   Reply With Quote
Old 12-24-2007, 05:49 PM   #4
Fav Mod: Big Turbos
i dont have the ID i have the blitz dual boost controller..they DO have the diagram on there for mine BUT still its no help..first off i cant read it(had to have a friend print it and remove the logos across the screen...but most importatnly it says to get the pressure source from the turbo...i do NOT have a line like that on the turbo.
Old 12-26-2007, 05:15 PM   #5
Fav Mod: Big Turbos
back TTT!!
