Old 12-10-2007, 02:37 PM   #1
Car: white 05 WRX STi
Fav Mod: cobb ap v.2
Talking how to install turbo inlet hose?
anyone have pictures or instructions on how to install perrin turbo inlet hose?
stinoz34 is offline   Reply With Quote
Old 12-10-2007, 02:50 PM   #2
Car: 05 WRX (STi Clone)
Fav Mod: JDM Fogs
Default Re: how to install turbo inlet hose?
Its a lil bit of a pain in the ass. I have no patiences, so after 5 mins, I started to just cut mine with a knife and took it off.
The rest is cake.
...This comment probably didnt help you one bit.
Phame is offline   Reply With Quote
Old 12-10-2007, 03:09 PM   #3
HAHA thanks.. yea it seems like a pain.. but i dont want to start the job without knowing everything there is to know about installing it.. thanks tho =]
Old 12-10-2007, 03:11 PM   #4
bump =]
Old 12-10-2007, 03:19 PM   #5
Car: 02 Subaru WRX Wagon
Fav Mod: teh jdmness
Send a message via AIM to danscoobywagon
it really isnt to bad to do. un-connect all your hoses, slide out the old turbo inlet hose. slide the new one in and reconnect. it really doesn't matter if you break any of the nozzles sliding the old one out because after you get the perrin one in there you will never want to take it out.
take the tmic off. use some lube/grease to slip all the hoses back on.
danscoobywagon is offline   Reply With Quote
Old 12-10-2007, 03:38 PM   #6
i heard this is pretty hard to do.. and could take several hours..
Old 12-10-2007, 03:50 PM   #7
Enginerd
Car: The Spaze Mobile
Fav Mod: Tuning
It's easy, especially if you have small hands. But it will probably take 2 hours if it's your first time. Atleast it's no the APS inlet.
Old 12-10-2007, 03:53 PM   #8
whats the difference between the perrin and the APS?
Old 12-10-2007, 03:58 PM   #9
Enginerd
Fav Mod: Tuning
The Perrin is Silicone and the APS is aluminum. I think it's aluminum...well it's metal.
Old 12-10-2007, 04:27 PM   #10
Car: Black 04 STi
Fav Mod: HSF-5
I'll tell you that I did mine this weekend I started on Sat night then continued on Sun for 11 hours.
PS I also installed perrin fuel rails, TGV deletes, 850cc injectors and the APS inlet... It was a royal PITA
ktulu990 is offline   Reply With Quote
Old 12-10-2007, 04:37 PM   #11
Car: 06 STI, 08 GSXR 750
Fav Mod: WC Lathe Werks Shift Knob
Doesn't the manifold have to be removed to install a new inlet?
Hitman83 is offline   Reply With Quote
Old 12-10-2007, 04:47 PM   #12
Car: White and Nerdy
Fav Mod: PayPal !!!
if its hard plastic or metal yes , rubber no .
Nasioc_STi is offline   Reply With Quote
Old 12-10-2007, 04:50 PM   #13
Thanks, time to search for a good silicone inlet
Old 12-28-2007, 07:53 PM   #14
Car: 06 WRX STi WRB/Gold
Fav Mod: Kartboy Super Shifter Kit
Send a message via AIM to Icereaperx303
This bad boy can take up to 2 days depending on not having correct tools. I ended up having to cut my bpv connector on the stock turbo inlet because the hose clamp was facing the engine block. After spending a large amount of time cutting and pulling things out a day was already gone. Another problem you will run into is the bpv hose is too long and kinks up so you have to cut it then its a ***** to get it on the connector for the perrin turbo inlet. All in all I wish i paid someone to do it and I still need to get a hose clamp on the bpv for the perrin inlet
My back, legs, arms, and head all hurt.... Night!
Icereaperx303 is offline   Reply With Quote
