Old 12-09-2007, 05:50 PM   #1
Car: PSM 03 WRX
Fav Mod: Bosal DP
Default what do i use?
what should i use when i clean the inside leanse on my headlights?
like actual stuff i can buy?
so when i take the lense off.. clean it with somethin and then dont touch the inside and put it back on?
thanks
ryan
wrxisthebest is offline   Reply With Quote
Old 12-09-2007, 05:52 PM   #2
Fav Mod: wingless and mis-fires
Send a message via Yahoo to toogood
Default Re: what do i use?
soap and water...then wipe with lint-free cloth
toogood is offline   Reply With Quote
Old 12-09-2007, 05:53 PM   #3
Car: PSM 03 WRX
Fav Mod: Bosal DP
cool!
i already have the inside painted from the last time in did this, but i would like to know what kind of black paint u recommend?
Old 12-09-2007, 05:56 PM   #4
Originally Posted by wrxisthebest View Post
cool!
depends...if you wanna use a flat black or glossy black...i used the flat black...came out good but one of my buddies went with the glossy black...which imo looks better...but its all up to you...you can purchase the spray can paint at autozone or advance autoparts...you can use any spray can...just when you go to spray the (amber) corner...make sure you give it alot of coats or else when you install it back on with the lights on...it'll shine thru
Old 12-09-2007, 05:59 PM   #5
Car: PSM 03 WRX
Fav Mod: Bosal DP
well.. mine are balck and ill be using the glossy black this time then.. and my black rubbed off some how where the lense hits the actual black painted plastic.. wierd???
Old 12-09-2007, 06:03 PM   #6
its not weird...the weather has alot to do with the curing time (drying)...the hotter the faster...the colder the slower...thats why most bodyshops use a "bake" system...after painting a car/car-body-parts...they set it in the booth where its at a certain temperature for a certain amount of time...you can use a blow dryer an work the heat evenly...just dont concentrate it on one area too long...
Old 12-09-2007, 06:04 PM   #7
Car: PSM 03 WRX
Fav Mod: Bosal DP
ight.. thanks,
im probably gunna do this tomorrow after school!
Old 12-09-2007, 06:06 PM   #8
ight.. thanks,
sounds good...be sure to reseal it properly so that you have no condensation problems...and post some pics when you get the chance
Old 12-09-2007, 06:08 PM   #9
Car: PSM 03 WRX
Fav Mod: Bosal DP
ok.. thanks
will do!
Old 12-09-2007, 09:18 PM   #10
Car: PSM 03 WRX
Fav Mod: Bosal DP
ok.. i decided to do it tonight!
here are my pics
and those two took me two hours roughly!
Old 12-11-2007, 04:33 AM   #11
looks good...you got some day time pics?
Old 12-11-2007, 02:37 PM   #12
Car: PSM 03 WRX
Fav Mod: Bosal DP
ill try to get some.. i am currently re painting them glossy black as we speak!
Old 12-26-2007, 12:19 PM   #13
Car: 06 Subaru WRX STi
Fav Mod: Valentine 1
Send a message via AIM to shan mann
gosh resize the pics!
shan mann is offline   Reply With Quote
Old 12-26-2007, 12:58 PM   #14
high res pics ftw! Get off the dialup!
xtw1ster is offline   Reply With Quote
