Old 11-29-2007, 09:56 AM   #1
Car: 07 Subaru WRX STi Bl
Fav Mod: APS INTAKE
Send a message via Yahoo to manny07sti
Default How long to install Downpipe with or without lift??
manny07sti is offline   Reply With Quote
Old 11-29-2007, 09:59 AM   #2
oMgWTFpewpew
Fav Mod: grip.
Send a message via AIM to chaos311clarity
Default Re: How long to install Downpipe with or without lift??
depends on your experience level and knowledge of the car... it took me like an hour my first time
Old 11-29-2007, 10:04 AM   #3
Car: 04 SUBARU WRX sti
Fav Mod: JDM FOGS
the first one i did took about 1 hour and 30 minutes start to finish. We did it in his garage with jack stands. pretty easy install just take your time.
Old 11-29-2007, 10:09 AM   #4
Fav Mod: TBE
It all depends on your mechanical ability but the first time I did it it only took 45 min because all of the bolts on the heat shield were rusted on.
Old 11-29-2007, 10:30 AM   #5
Car: OBP 07 STi
Fav Mod: Ring-Shaped Reinforcement Frame
Give yourself at least a couple hours to be safe. Taking your time is a good thing. Trying to do any project in a hurry is bad news waiting to happen. Some peoples claims of less than an hour for their first time seem a little optimistic. I think it took me close to that long just to get the intercooler back on .
Old 11-29-2007, 10:47 AM   #6
Car: 06 STI, 08 GSXR 750
Fav Mod: WC Lathe Werks Shift Knob
Mine took 2 hours on a lift. The tuner told me he had to jack up the engine an inch or 2 to get the DP to fit. FWIW it's a bellmouth catted invidia
Hitman83 is offline   Reply With Quote
Old 11-29-2007, 10:59 AM   #7
Car: 05' STi
Fav Mod: JDM Fogs
It's not long at all. I did my hole exhaust in 1hr 15min.
Old 11-29-2007, 08:41 PM   #8
Car: 06 Subaru WRX STi
Fav Mod: Cobb Xaust!
to install a aaftermarket downpipe is easier than installing the stock one back on...
an hour and a half to istall an aftermarket one and like 145 for thestockone... both these times with jackstands...
not too bad.. i like to tak emy time...
oscargarza88 is offline   Reply With Quote
Old 11-29-2007, 11:56 PM   #9
Zeb
Ninja Lurker
Car: '04 STi
Fav Mod: New Pavement
You can probably shave off a little time if you spray some pb blaster on the bolts the night before. But probably isn't a big issue on your '07. Having the right tools is what is going to save the most time. Ratches with extensions or ratchet wrenches preferable. The one on the inside bottom at the top of the DP is hard to get to from some angles.
Zeb is offline   Reply With Quote
Old 11-30-2007, 01:00 AM   #10
Car: 2006 Siliver STi
Fav Mod: Recaro's
i would say about 1 hour if you hit it with pb blaster the night before, but if you miss thred one of the bolts and have to cut it with bolt cutters, than it will take you about 2 days, 1 day to find the bolt cutters, and 1 day to return the bolt cutters to a friend with also a 6 pack.
rekedevoate is offline   Reply With Quote
Old 11-30-2007, 04:50 AM   #11
100% More Wingless
Car: 05 STi + 08 OBXT
Fav Mod: baby seats
Agree with above. Plan on a few hours if it is your first time. It may take much longer if you don't have the right tools and have to go back/forth to the hardware store. I would highly recommend a flexhead 14mm socket to get that last DP bolt. You will also need to have the front of the car on jackstands or ramps. Because your car is new, the rust shouldn't be too bad, but you'd be surprised how quickly the nuts/bolts can freeze up.
Old 12-03-2007, 06:16 AM   #12
Car: 2004 Subaru WRX STi
Fav Mod: The one I can afford. . ..
with: 1 hours to 2 hours
without: good luck
T
2004_ASPEN_STI is offline   Reply With Quote
Old 12-03-2007, 03:12 PM   #13
Car: JBP 04 STi
Fav Mod: EWG !!!
Send a message via AIM to ATTI2D
3+ hrs... in the dark and looking for tools. Plus I had a fitment issue with one of the main bolts. Had to grind down the outer rim / ring a little.
ATTI2D is online now   Reply With Quote
Old 12-05-2007, 01:16 PM   #14
Car: black 04 WRX STi
Use a new factory gasket where the dp bolts to the turbo housing. And you will probably have to spend time modifying the turbo heatshield if you want to reinstall it.
Walt is offline   Reply With Quote
Old 12-05-2007, 02:01 PM   #15
Fav Mod: Driving School / Trunk swap (no attention ftw)
2nd time took me 2 hours, plus some time for a lunch break
Give yourself plenty of time - leave a full day for it, and another day for a shop to fix it if you make any mistakes better safe than sorry.
Take your time, its not hard...
Jesse
mgsm666 is offline   Reply With Quote
