Old 11-28-2007, 05:30 PM   #1
Car: Blue 04 STi
Fav Mod: Its a Secret
Send a message via AIM to MattyB
Default e brake adjustment
do i have to take out the center console to adjust the e brake or is there an easier way
MattyB is offline   Reply With Quote
Old 11-28-2007, 07:14 PM   #2
Teh Other White Meat
Trader Rating: (21)
Default Re: e brake adjustment
yes you have to take the center console out. there is a nut 10mm that you tighten at the bottom of the ebrake lever.
Old 11-29-2007, 06:09 AM   #3
Fav Mod: TBE
1) Remove the console box.
2) Forcibly pull the parking brake lever 3 to 5 times.
3) Adjust the parking brake lever by turning adjuster until the parking brake lever stroke is set at 7 to 8 notches with an operating force of 196 N (20 kgs, 44 lbs.).
4) Tighten the lock nut.
Lever stroke: 7 to 8 notches when pulled with a force of 196 N (20 kgs, 44 lbs.)
Tightening torque flock nut): 5.9 Nm (0.6 kgf-m, 4.3 ft. lbs.)
5) Install the console box.
Old 11-29-2007, 06:31 AM   #4
Car: 05 STi & 05 LGT
Fav Mod: My wifes 05 LGT Stage I
Nice detailed instructions ^^^^ , I was interested in this as well
MRGLASS is offline   Reply With Quote
Old 11-29-2007, 06:51 AM   #5
Car: clean but slow 04STi
Fav Mod: the driver!
Send a message via MSN to FlybySTi
i did by adjusting shoes inside of rear rotor~~
FlybySTi is offline   Reply With Quote
Old 11-29-2007, 08:13 AM   #6
Fav Mod: TBE
That's another option and is actually pretty easy to do. If you look behind your rear rotors you will see a small rubber plug on a plate. This is the housing for your parking brake assembly. Pull that cover off and you'll see the adjustment screw in there.
The only issue with doing this is that you can't really see where the shoes are when you're adjusting them. It can kind of be a guess and see technique until you get it where you want it.
Old 11-30-2007, 06:34 PM   #7
Car: 07 STi LTD #091 UGM
Fav Mod: APS Exhaust
Send a message via AIM to WRXSTi0487
if u adjust inside the shoes when you replace the rotors do u have to make any changes?
WRXSTi0487 is offline   Reply With Quote
Old 11-30-2007, 06:53 PM   #8
Trader Rating: (21)
either way, if your adjusters are working properly, you will have to retract(tighten) the adjusters when you go to do the brakes.
Old 11-30-2007, 07:50 PM   #9
Car: blue 05 wrx sti
please explain i don't understand
mcbst is offline   Reply With Quote
Old 11-30-2007, 08:25 PM   #10
Trader Rating: (21)
You likely wouldn't see it on the STI because the drums/shoes on the rear assembly are for the emergency brake only. Wear would be minimal. The adjusters can make getting the disc off and on difficult because they will hold the shoes nearly against the inside of the drum.
