Old 11-25-2007, 06:04 AM   #1
H4N
Fav Mod: EWG, T 2'S
Default How to Anodize Titanium
I wrote this up because of the recent thread about someone trying to "Burn" there Ti. shift knob and some how shifted into anodizing Ti. Parts. Well here it its.
Anodizing titanium to get the "burnt" blue look.
NOTE: I take no responsibility if you electrocute yourself or destroy your titanium piece...Do this at your own risk!! I do not think it will work with anything but titanium..
Pictures are also borrowed from my friend. Where I learned how to do this, since i originally didn't take pictures while doing mine.
Parts needed:
1. Select the color you want from the color chart below, then buy anywhere from 1 to 15 9V batteries.
2. Depending on the number of batteries used, alligator clips for each terminal + 2. for example, if you use 4 batteries, 10 alligator clips are needed
3. Can of cola (not diet, must contain sugar)
4. Wire.. (if the alligator clips do not already come with wire)
5. Tape
6. Piece of cardboard
7. Paper towel
Assembly:
Attach batteries to cardboard using the tape, then wire the batteries in series using the alligator clips. Attach last (-) negative alligator clip to titanium item you want to anodize..
Process:
Soak the paper towel with plenty of cola. Then take the last (+) positive lead and start rubbing the cola soaked paper towel with the alligator clip. Keep rubbing for like 1 minute and your piece will start to anodize! If it doesn't work check all your connections..
When you are done you will end up with something like this:
H4N is offline   Reply With Quote
Old 11-25-2007, 06:08 AM   #2
RSV2/BF2142 Player
Fav Mod: Fixing Subie Rattles :)
Send a message via AIM to SiCkSTi04
Default Re: How to Anodize Titanium
thats just w0w dude, very cool write up. would you have any photo's of the finish piece installed? =)
SiCkSTi04 is offline   Reply With Quote
Old 11-25-2007, 07:07 AM   #3
Fav Mod: TS3076
Send a message via AIM to crookid7
that's amazing. So does it anodize the part covered by the wet paper towel? would it be possible to have 1 huge wet paper towel and just do the whole thing at once?
crookid7 is offline   Reply With Quote
Old 11-25-2007, 07:11 AM   #4
H4N
Fav Mod: EWG, T 2'S
thanks man, here are some of mine, Installed.
Old 11-25-2007, 07:12 AM   #5
H4N
Fav Mod: EWG, T 2'S
it doesn't work like that. It anodized right under the (+) alligator clip and reacts with the cola.
Old 11-25-2007, 08:36 PM   #6
Car: 07 STI Limited #743
Fav Mod: New Tires!
You can submerge the titanium part in the liquid (I used Simple Green) and attach the positive side to the titanium piece. The negative side must be submerged in the liquid, but it cannot touch the actual titanium part.
Don't electrocute yourself.
wrxmatt is offline   Reply With Quote
Old 11-26-2007, 08:48 AM   #7
Car: working out, studyin
Fav Mod: Gavin My Siberian Husky
Send a message via AIM to ayanami22 Send a message via MSN to ayanami22
i might try this today with my shift knob ill post pics when im done!
ayanami22 is offline   Reply With Quote
Old 11-26-2007, 08:51 AM   #8
Car: 06 STI
Subscribed111111111
DragonXero13 is offline   Reply With Quote
Old 11-26-2007, 10:16 AM   #9
H4N
Fav Mod: EWG, T 2'S
That's good to know.
And I would love to see this process tried on a shift knob. Good luck hopefully it comes out sick.
Old 11-26-2007, 11:39 AM   #10
Fav Mod: New Tires!
I've done the chainrings on my mountain bike. ~40 volts. They came out really nice. I attached the negative lead to a 6"x6" sheet of aluminum foil. The negative electrode should have a larger surface area than the piece being anodized (according to MrTitanium's Basic Titanium Anodizing Instructions).
Old 11-26-2007, 11:42 AM   #11
im just wowed
BunaSTi is offline   Reply With Quote
Old 11-26-2007, 12:08 PM   #12
Fav Mod: New Tires!
That's ~40 volts.
It's a blue-grey color.
Old 11-26-2007, 12:49 PM   #13
so if i understand what ur saying here....if i submerge the knob in the coke solution, attatch the pos end to the knob, i should take a sheet of aluminum foil with a larger surface area of the knob, attach the neg wire to it and then immerse that in the solution as well along with the knob?
Old 11-26-2007, 12:54 PM   #14
Car: White 06 Civic SI
Fav Mod: Injen CAI
Wow, that is awesome. I want to try it on my shift knob!
magicballer2001 is offline   Reply With Quote
Old 11-26-2007, 12:54 PM   #15
Fav Mod: New Tires!
That's about it. Just don't let the negative and positive sides touch.
As a side note, the process gives off hydrogen gas, so make sure that you do this in a well-ventilated area. This shouldn't be a real concern for something like a shift knob, but for something like a radiator shroud, it could pose a problem.
