Old 11-16-2007, 05:49 PM   #1
Car: 05 STi |STOCK|
Fav Mod: Not a post 07 sti fan
Default Oil change question
I looked over the How to on this and found the drain plug and the filter. I just had a question on the drain plug. It has a wire coming out of it, the picture on the how to doesn't have anything coming out of it. I was just wondering what this wire is and how to get around it so I can drain my oil. I also need to go get the drain plug washer from the dealership and was wondering if I could drive around without the plastic shield on the car for a day or two?
The last picture shows the shield and it has some oil build up on it, is that normal or should I be concerned? The car has been sitting in my garage for about 2 1/2 hrs without the shield on and no oil has leaked so I would guess I shouldn't be concerned about it.
Here is some pictures of the drain plug with the wire coming out of it. If this isn't the drain plug don't flame me to much it's located in the same spot as the how to write up.
BTW sorry about the pics, my girly spilled soda on the camera and now it doesn't auto focus.
Thanks for any and all responses.
chargedvette02 is offline   Reply With Quote
Old 11-16-2007, 06:27 PM   #2
Default Re: Oil change question
I've never seen a drain plug with wiring coming out of it like that. Maybe its for an oil temp gauge?
You'll be fine without the undertray for a while, its mainly there for protection and aero, so as long as you don't get really unlucky and have a rock bounce up and take out your oil filter or something, you'll be fine.
KrazyKarl is offline   Reply With Quote
Old 11-16-2007, 06:38 PM   #3
Car: 05 WRB STI
Send a message via AIM to bdpakaknox Send a message via Skype™ to bdpakaknox
STIs do not have a wire coming from the drain plug like that stock, so an aftermarket gauge would be a good guess.
An open ended wrench should be abel to get around it.
And judging by the area of the spot on your splash gauge, id say you have an oil filter leak.
bdpakaknox is offline   Reply With Quote
Old 11-16-2007, 06:42 PM   #4
Car: 2006 Subaru WRX STI
Fav Mod: Maddad DP and P&L Catback, stage 2!!!
Send a message via AIM to haroman311
might be some aftermarket stuff with the wire, a open ended wrench would work. as for the oil on the pan, some people dont take off the shield when they do a oil change. just let it drip down onto the shield and wipe if off and or they took it to a quick lube place(jiffy lube, midas) and they didnt take it off. if u dont see a leak then there isnt one.
haroman311 is offline   Reply With Quote
Old 11-16-2007, 06:47 PM   #5
Car: 05 AW STi
Send a message via AIM to STiLLsLow
the wire is for the oil temp gauge, if u have either subaru oem 3-gauge pack or an aftermarket oil temp gauge then that is the sensor for it. u may want to wrap it up since the wiring looks pretty exposed.
STiLLsLow is offline   Reply With Quote
Old 11-16-2007, 06:53 PM   #6
Car: 05 STi |STOCK|
I do have the oem 3 gauge pack that goes where the clock is... I should have known what that was, good call guys and an open ended wrench sould take care of it. Thanks for the input all!
Old 11-16-2007, 06:58 PM   #7
Car: 05 STi |STOCK|
If I had a leak wouldn't it have leaked by now? It's been on the rino ramps for a little over 3 hrs now and no leaks at all. Also I never had a leak on my garage floor and if it was leaking as much as it looks I think I would have had some drips on the ground even with the shield in place. I'm going to go with what haroman said and guess who ever did the last oil change didn't take the shield off.
Old 11-16-2007, 07:16 PM   #8
Car: 05 WRB STI
oil leaks can arise when the car is being driven, when the oil pressure rises.
Haroman makes a good point, as to why you should do your own oil changes
Old 11-16-2007, 07:29 PM   #9
Car: 05 STi |STOCK|
I just bought the car used. I do all my own oil changes.
