Old 11-12-2007, 12:05 AM   #1
Car: 05 Subaru WRX STI
Fav Mod: suspension!
Default Need help finding right belt
Hello, well I have an 05 sti and would like to remove my power steering, but do not know where i can find a belt small enough to fit without the power steering, (alternator + pulley only) if im correct. Could you guys help me out? thank you in advance
ILoveFishing is offline   Reply With Quote
Old 11-12-2007, 05:51 AM   #2
Car: 04 JBP STi
Fav Mod: All of them
Default Re: Need help finding right belt
I would first venture to ask the question, why? what would the purpose in removing your power steering be?
2nd you can fab up a 3rd pully to use the stock belt
3rd option get a piece of string and wrap it around the two pulleys (crank and alternator) and pull it tightly. Mark where the string comes together and then lay it out flat and measure it up. from that you can get an idea of how long the belt needs to be. Then give somebody like Gates Rubber a call and see how much t hey want for a belt in that size. The robots I build use a bunch of different belts and pulleys and thats where we get them from, and if I remember correctly they also make automotive belts so they should be able to help you out!
NewGenSTi is offline   Reply With Quote
Old 11-12-2007, 07:46 AM   #3
Car: 06 STI
I sure hope you say something like I cant afford to replace the pump right now & nothing about HP loss.
highwayman is offline   Reply With Quote
Old 11-12-2007, 04:22 PM   #4
we'll i heard of people with no power steering or they take it out and they get to feel the road more so i thought i'd give it a try. And highway man would you try helping out instead of makin fun. thanks
Old 11-12-2007, 05:42 PM   #5
Car: 04 JBP STi
My thoughts are it is just going to be really hard to turn the car in just about any situation. If you really want to get a better feel I would look into hardened steering rack bushings, and even a quick ratio rack(although spendy$$)
Good luck with it, but really I would say that you can pretty much just take the belt off and do a little test run to see for yourself. as long as you have a good battery you may be able to go a little ways without an alternator!
Old 11-14-2007, 08:46 AM   #6
lol i might be to afraid to take off the alternator but if i hear about it working without just maybe, havnt heard 1 thing about taking the alternator so don't know about that
Old 11-15-2007, 08:36 AM   #7
sarcism....
