Old 10-30-2007, 12:03 PM   #1
Car: Silver 05 STi
Fav Mod: Driver License
Default Which hole on whiteline 27mm front swaybar?
Which hole is soft and which is hard? The instructions that came with the bar are for the rear bar with 3 holes. The front bar has 2 holes one above the other. Someone please help me.
ihadmail is offline   Reply With Quote
Old 10-30-2007, 12:35 PM   #2
Car: 05 S2000
Default Re: Which hole on whiteline 27mm front swaybar?
IIRC, the hole closest to the front of the car is the HARDER setting.
eXstasy is offline   Reply With Quote
Old 10-30-2007, 12:43 PM   #3
Car: Silver 05 STi
it looks like my choices are top or bottom holes.... i think i'm just going to pick a set until i can call the shop.....
Old 10-30-2007, 12:50 PM   #4
Car: 2004.5 Subaru WRX ST
Fav Mod: 17x10s
One hole will be closer to the pivot point. That is the 29mm section. Imagine the bolt hole of the swaybar swinging around a large large arc around the bushing. The larger arc will be the 27mm setting.
loworbitSI is offline   Reply With Quote
Old 10-30-2007, 12:56 PM   #5
Car: 05 S2000
Once the bar is mounted, the holes are more or less horizontal.
Old 10-30-2007, 01:21 PM   #6
Car: Silver 05 STi
ok, i got it now. thanks guys.
