Old 10-20-2007, 10:10 AM   #1
Car: urban gray 07 sti
Default SPT turbo heat shield install without removing intercooler?
I was wondering if I could do this by just removing 1 bolt on the left side of the intercooler. I attempted this with no luck or is there a special way of doing this? I don't want to take the intercooler off cause I heard it was a pain to put back on.
dewey is offline   Reply With Quote
Old 10-20-2007, 10:30 AM   #2
Car: CMG 04 STI
Fav Mod: AP FTW
Send a message via AIM to twozzracer
Default Re: SPT turbo heat shield install without removing intercooler?
I did mine in less than 5 mins, you dont need to remove the innercooler. You have to angle it in the right direction for it so slide in.
twozzracer is offline   Reply With Quote
Old 10-20-2007, 11:10 AM   #3
How would I angle it? I tried taking the bolt off and then I put the shield on top of the turbo and couldn't slide it in between the clamp in the intercooler. Or am I supposed get a nut or something to hold it in?
Old 10-20-2007, 11:14 AM   #4
Car: CMG 04 STI
Fav Mod: AP FTW
Take the bolt off along with the rubber grommet. Slide the heat shield through then slap the grommet back in and screw the bolt in.
Old 10-20-2007, 11:24 AM   #5
Car: 06 STI SGM
Fav Mod: seatbelts
Send a message via MSN to boost_happy
take the intercooler off, its not that bad, makes you learn how to do it for the future if needed. Challenge yourself.
boost_happy is offline   Reply With Quote
Old 10-20-2007, 12:15 PM   #6
lol well I'll give the easier way a try first if I can't get it in I'll try taking the intercooler off. thanks for the help guys.
Old 10-20-2007, 04:40 PM   #7
i just replaced my stock heat shield today with a cobb hs. did NOT take intercooler off. all you need to do is remove 5x 10mm bolts 3 on top 2 on bottom end and rotate it out. took me about 10 mins. the replacement hs goes in even quicker.
divine.revelation is offline   Reply With Quote
