Old 10-17-2007, 03:23 PM   #1
i eat cones
Fav Mod: catless
Default boost gauge wire through where???
my stri gauge finally came in. i mounted it on the top left of the dash, right above that vent, on the pillar with the pod that came with it. my question now is,
where do i run that wire and how...
can it go through that little top vent, or somewhere else? how easy is it to feed through into the engine bay?
thank you in advance
Old 10-17-2007, 03:38 PM   #2
Car: 07 STI
Fav Mod: Wingless & Shaved
Send a message via AIM to Subaru13
Default Re: boost gauge wire through where???
wish i could help, best of luck trying to get some help, hopefully its all set up on friday so i can see it
Subaru13 is online now   Reply With Quote
Old 10-17-2007, 03:52 PM   #3
Car: 05 Aspen w/ Silver
Fav Mod: Morning Fresh Air Freshener
Rite behind the brake pedal there is a rubber grommet push on it and it will fall out to the ground under your car, that opens a direct hole through the firewall. Drop the boost wire from somehwere behind the intercooler to the left of the windshield washer tank go under the car and just put it throught the hole, its right next to where the steering linkage or whatever its called comes through. Once you get it through the hole put a slit in the rubber grommet run put the wire through it put it back on and ur good to go. I just did my defi's this weekend, by far the easiet car i have ever had to to run a wire through the firewall.
Facinnreality is offline   Reply With Quote
Old 10-17-2007, 04:03 PM   #4
i eat cones
Fav Mod: catless
awesome, thanks for the help guys. im gonna go take a peek.
Old 10-17-2007, 04:16 PM   #5
i eat cones
Fav Mod: catless
i found that hole.
ok now my problem is, i didnt mount my gauge where the clock pod would be. its on the driver side pillar. how will i run my wire through the dash to get to that firewall hole?
Old 10-17-2007, 04:46 PM   #6
i eat cones
Fav Mod: catless
ok got it, ran it down the pillar and side of dash. pushed it in. looks clean as hell. thanks jnprn!
Old 10-17-2007, 04:52 PM   #7
Car: 06 STi Spec C
Fav Mod: The STi experience
Nice job bro! Could you post some pics of the gauge, I've never seen the stri gauges before.
06SpecC is offline   Reply With Quote
Old 10-17-2007, 05:21 PM   #8
i eat cones
Fav Mod: catless
for sure, trying to get this thing done tonight!
Old 07-10-2008, 11:12 PM   #9
Car: Aspen White 07 STI
Talking Re: boost gauge wire through where???
Would you happen to have a copy of the manual for the STRI boost guage?
SoCal_STI is offline   Reply With Quote
