Old 10-15-2007, 07:16 PM   #1
Car: 05 Subaru WRX STi
Default bearing in tgv
there's a little bearing in the tgv housing where the shaft goes through. How should I take it out? Thanks.
an_juan is offline   Reply With Quote
Old 10-22-2007, 08:27 PM   #2
Car: 04 Subaru WRX
Fav Mod: Blown Ring Grooves
Default Re: bearing in tgv
good luck. the only way to get it out would be by hammering it from the inside, which is impossible. if you make some sort of a hook-like tool to pull the bearing out, maybe it will work.
i just JB'd the crap out of the holes, and seem to have no problems (i run 19 PSI)
Ashot is offline   Reply With Quote
Old 10-23-2007, 12:00 AM   #3
thanks dude!
Old 10-23-2007, 07:31 PM   #4
Car: 04 Subaru WRX
put back my catback today, and forgot to set the boost solenoid to a lower duty cycle. drove at 21 PSI for quite a bit with no issues
there are 2 JB's out there. "JB Qwik" and "JB Weld". both are basically the same, but the quick one sets within 4 minutes and cures in 4 hours while the standard one sets within an hour and cures overnight (12-16 hours)
in theory the "Qwik" one is weaker, but i say either one should be fine, as i used "Qwik" on the passenger side, as i ran out of the normal one.
good luck,
Ashot
Old 10-25-2007, 12:11 PM   #5
Fav Mod: sz55 external wastegate
drill it out then weld shut
Mycues1982 is online now   Reply With Quote
