Old 10-15-2007, 12:42 PM   #1
Car: 07 STi
Fav Mod: My t3/t4
Send a message via AIM to EK9 BEEZLER
Default Adjust headlights on 06/07?
My headlights point the beam pretty low to the ground and even on the highest setting "0" on the switch inside the car they are still too low. Has anyone adjusted it so that the lights point higher and further down the road? I haven't even looked at the lights to determine if this is possible but I would assume that you could just aim the projector a little higher and there wouldn't be any problems. Any suggestions?
EK9 BEEZLER is offline   Reply With Quote
Old 10-15-2007, 12:48 PM   #2
Car: 2006 SGM STi
Fav Mod: Stage 2
Send a message via AIM to Vypurr
Default Re: Adjust headlights on 06/07?
Yes, there are adjustment screws to raise and lower the direction they point.
Vypurr is offline   Reply With Quote
Old 10-15-2007, 12:57 PM   #3
Car: 07 STi
Fav Mod: My t3/t4
any pics of the screws? are they under the projector?
Old 10-15-2007, 02:38 PM   #4
Car: 06 STI & FXT
Fav Mod: painted Hella horns!
Link to pics and thread for headlight adjustment
covert747 is offline   Reply With Quote
Old 10-15-2007, 02:44 PM   #5
Really easy to do. Mark the wall you are using first at the middle setting on the height adjustment next to the IC spray. It takes a LOT of turns to raise them up, but try to remember the number so you can do the same to the other side. Good luck!
Old 10-18-2007, 07:53 PM   #6
Car: 07 OBP STi
One side should actually point a bit higher than the other depending on what side of the car the steering wheel is on.
fatcircles is offline   Reply With Quote
Old 10-18-2007, 08:07 PM   #7
Car: 2006 SGM STi
Fav Mod: Stage 2
The right side should point higher to illuminate street signs better.
