Old 06-22-2008, 04:17 PM   #31
Car: JBP 04 STI / gold
Fav Mod: BLITZ NUR SPEC
Default Re: How To: Replace Brake Pads and Rotors **Rear caliper bolt torque UPDATED!**
Hey Well Ok Um I Need Help Bad Now Lol, Well I Did One Of The Rear Rotors But On The Other Side For Some Reason It Just Wouldnt Come Off, I Put The Screws In The Holes And Well It Just Striped It, I Went So Big Now And Dont Know What To Do, Also Had My Buddy Try It Thru Those Small Gear Things But Um Yea He Forgot The Count Plus Still Couldnt Take Them Off, We Hammered It Alot And Put Alot Of Spray But Nothing, So Any Ideas Of What To Do? Also What About The Gear Things Since We Lost Count How Do We Figure Out Where Its Suppose To Be At? Well Just Let Me Know Asap For I Dont Really Want To Go To The Dealership Since I Know Its Gonna Be Alot Thanks For Any Kind Of Help
malinolatino is offline   Reply With Quote
Old 06-22-2008, 05:59 PM   #32
Fav Mod: TBE
Don't worry about the tooth count on the parking brake for now. If your rotor is still stuck first make sure the parking brake is RELEASED!! I know it sounds stupid but I did it myself.
Next make sure you are loosening the parking brake screw and not tightening it. To loosen it make sure you are cranking the gears downward and not upward. I had to move 25 teeth on mine before it would release the rotor.
The next step is to take a soft face dead blow hammer and give each side of the rotor a whack to loosen it up. Just work at it and be patient. If it doesn't come off then take a break and grab a beer until your nerves calm down because you don't want to get pi$$ed and wind up breaking something.
Old 06-22-2008, 10:56 PM   #33
hey whats up, well , i did have the parking brake down , but it was just that it was so rusted, so i loosened the hell out of the gear thing all the way and then went all caveman on it and finally four scores and seven years later it came off, lol, but um thanks for your help, finally put new rotors and brakes on and the only problem i have is how many clips of the gear should it be at? well talk to you soon thanks again,
Old 06-23-2008, 04:32 AM   #34
Fav Mod: TBE
Some times you just need to use some brute force! Glad everything went well!
1. Make sure the parking brake is disengaged
2. Tighten the screw until the wheel will not turn anymore, the parking brake will actually engage the rotor
3. Back it out about 5 clips and test to see if the wheel is free spinning
4. Pull the parking brake handle and engage the parking brake and make sure the wheel does not spin
5. Take the car to a hill and make sure the parking brake holds the car for at least a few minutes
Old 06-23-2008, 06:22 AM   #35
Well we tightend it all the way and then turned it 15 clicks i think, my buddy helped me and it held it like that, but still havent tried it like up a hill, i should do that huh lol, well when i hit the brakes, the brake pedal is tight, i did the rear rotors, so why would they be tight? it stops but its a lil tight, i just need to get it done right since my wife will be driving the car for like four months and i just dont want any problems you know, cant get rid of her just yet lol jk jk, well thanks to everyone for yalls help i will have to see about re-adjusting the clicks and got to find out about why the brakes are a bit tight,
Old 06-30-2008, 08:58 AM   #36
Fav Mod: 57fs
Great writeup Dan. I think I may be due for pads and rotors since Im at 27k.
Would you mind helping me out? Ill probably have a little install day when I do my T2s and sways. Ill probably do rotors, pads, lines and fluid.
wrxcelration is offline   Reply With Quote
Old 06-30-2008, 05:05 PM   #37
Hey Well Thanks For The Help Wow I Fianally Was Able To Take Them Off I Moved The Click All The Way Loose And Bang The Hell Out Of It, Lol , Put On The New Rotors And Adjusted The Click Till It Got Tight And Loosened It Like 10 Times Its Good Now, Just Gonna Take It To The Dealership So It Can Be Correct Dont Really Want To Take No Chances, But They Are Good It Stops And Holds On Hills So Again Thanks, I Will Be Doing The Fronts Here Soon So Yall May Hear From Me Again Lol, Thanks Again
Old 07-12-2008, 07:00 AM   #38
Car: UGM 07 STi L #95
Fav Mod: oil drain valve
I need 8mm bolts to get the rotors off!!! Where is a good place on my car or around the house.... my car is on stands...
STISubSilver is offline   Reply With Quote
Old 07-12-2008, 08:17 AM   #39
N/M.. I literally laced up and made a run to the local Napa!
Works like a charm!
Old 09-07-2008, 12:29 PM   #40
Even though these are fixed calipers shouldn't the wear indicator be on the inside pad....
I am talking about the first picture.
skyline8409 is offline   Reply With Quote
Old 09-15-2008, 03:09 PM   #41
Car: 2007 STI Limited
Fav Mod: Stage 2
Send a message via AIM to coop1103
If I am just replacing the front pads I do not have to perform step 5 correct??? I dont ever remember removing bolts to get to the pads in previous cars I have done the brakes on...
coop1103 is offline   Reply With Quote
Old 09-15-2008, 07:55 PM   #42
Car: Black 05 WRX STI
Fav Mod: ......The Car
Send a message via AIM to snaredrumr04
Are you just pad slapping it? you should take the rotor off and have it turned.
snaredrumr04 is offline   Reply With Quote
Old 09-19-2008, 09:57 AM   #43
Fav Mod: TBE
No to replace the pads only you do not have to remove the caliper. Just remove the 2 studs and the spring clip and pull the pads out. You will have to find a way to flush the pistons again to make enough room to get the new pads in tho.
Old 09-19-2008, 10:05 AM   #44
Fav Mod: Stage 2
I compress the pisotons with a C Clamp to get the pads back in. thanks
