Old 10-10-2007, 07:21 PM   #1
Car: Wingless 06 STi
Default Noob Harness Install question?
So I got these Sparco 4 point, 3 inch harnesses. I got a harness bar and understand how to loop and connect the shoulder straps to it. What has me a little puzzled, is how the lap belts connects. I thought I was going to remove a bolt where the seat connects to the floor and put the connection there but the end of lap belts look like this.
Where does this go?
Am I just a retard? The bolt that connect the seats to ground doesn't look like it will fit threw this. Maybe if I try during the day something will come to light.
Cadgod-06sti is offline   Reply With Quote
Old 10-10-2007, 07:42 PM   #2
Car: '06 STI
Fav Mod: air freshener!!!
Default Re: Noob Harness Install question?
Yes, you are a retard!
JK! Couldnt resist the chance....
That style end is intended to work with an "eye-let" style bolt. The "eye-let" bolt will replace the 14mm (head) bolt that is used at the 2 rear seat mount locations.
Sparco USA
Or...
You can replace that with a bolt in style that will just have a simple hole instead of the spring-clip-thing.
Sparco USA
The above links show a thru-bolt design but the thread size/pitch should screw into the existing seat base bolt holes.
Hope that helps
Old 10-10-2007, 07:44 PM   #3
Thanks, That makes sense now.
Old 10-10-2007, 07:46 PM   #4
Car: '06 STI
What? You arent even mad at the retard joke?
Old 10-10-2007, 08:03 PM   #5
Fav Mod: HKS CARBON TI
you have to buy eye bolts and replace the seat bolts with them.
Old 10-11-2007, 03:45 AM   #6
Not really, i felt like a retard. It was a long day, and I wasn't thinking.
