Old 10-04-2007, 02:06 PM   #1
Car: Silver 05 Subaru WRX
Default Tri-pod removal...
I have the facotry option tri-pod thing on the dash where the clock typically goes. I am trying to remove the gauges so that I can change the bulb color from white to red. Does anyone know how to remove the unit without breaking clips, etc? Thanks in advance.
CT_R84 is offline   Reply With Quote
Old 10-04-2007, 02:18 PM   #2
Car: 07 STI Limited #743
Fav Mod: Snow Tires!
Default Re: Tri-pod removal...
Pull up on the back of the gauge pod. It will pop out.
wrxmatt is offline   Reply With Quote
Old 10-04-2007, 02:23 PM   #3
The clock one pops out the same as my 3-pod one? Sorry for sounding redundant, I just want to make sure...
Old 10-04-2007, 02:25 PM   #4
Yeah, it uses the same mounting points as the clock pod.
Old 10-04-2007, 02:29 PM   #5
alright, thanks again bro...
Old 10-04-2007, 03:02 PM   #6
Fav Mod: All of them
Um if your talking about the factory three gauge pod then you have to pop the gray cover forward and up and it will expose the backs of the gauges. Then you will see four screws holding it into the dash.
Here is the bottom of the cover.
and here is what the gauges will look like after the cover is off.
Partysub is offline   Reply With Quote
Old 10-07-2007, 02:20 AM   #7
Car: Haji is my neighbor!
Fav Mod: Getting rid of the 05 money pit!
There "pop" clips. Ive taken them out several times with no issues. There are 2 ways. 1 is pull on it until it comes out. 2nd is take out the radio and gi in from the bottom, but you will have to maneuver arounf the center vents. I usually use opition #1. If your still having issues in 2 weeks, let me know Ill be home by then.
rek888v2 is offline   Reply With Quote
