Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > Gruppe-S
Old 06-21-2007, 12:54 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default KW Coilovers+Hawk Pads ($1895)/GS Slotted Rotors+Pads($349)/Peak Lines/PFC 2pc Rotors
Hey guys,
Crazy specials!
KW V3 COILOVERS + HAWK HPS PADS
-Independent Compression / Rebound Adjustable
-14pt compression / rebuild adjustment
-Independent height adjustment
-Made in Germany
-Hawk HPS Pads included free of charge!
$1850 Shipped!
Introducing Gruppe-S slotted rotors!!
Gruppe-S Performance Slotted rotors are private labeled from a world-famous OEM rotor manufacturer and offer the best value in a high performance rotor system for your car. Manufactured to the same specifications as OEM components in an ISO certified production facility. The rotors are made using high quality casting techniques and precision machined to provide the maximum stopping and cooling efficiency. Rigorously tested on track and street cars these rotors offer long life, reduced brake fade, reduced pad wear, and improved wet / dry weather braking.
GRUPPE-S SLOTTED ROTORS & HAWK HPS PADS
-Gruppe-S Front Slotted Rotors (pair)
-Hawk HPS Pads (pair)
04 STI (Brembo) $349 Shipped!!
05+ STI (Brembo) $359 Shipped!!
ADD PEAK PERFORMANCE STAINLESS LINES
-DOT Approved
-Full Stainless Lines
-Race Proven
$89 with order!
PERFORMANCE FRICTION FLOATING 2PC ROTORS + PFC RACE PADS
-The BEST 2pc Race rotor on the market
-True Floating 2pc Rotor
-Reduction in rotational mass means performance gains
-Improves bearing life by reducing heat transfer
-Aerospace grade rotor material
-Designed for PFC TRACK pads (INCLUDED!)
$749 Shipped!!
Gruppe-S is offline   Reply With Quote
Old 06-21-2007, 06:49 PM   #2
Trader Rating: (13)
Default Re: KW Coilovers+Hawk Pads ($1895)/GS Slotted Rotors+Pads($349)/Peak Lines/PFC 2pc Rotors
Bump!!!
Old 06-25-2007, 03:23 PM   #3
Trader Rating: (13)
In Stock Ready To Ship!!
HTML code is On
