Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > Gruppe-S
Closed Thread
Old 06-05-2007, 08:14 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default CLEARANCE:JDM 6MT Close Ratio Gears($279)/Cusco Twin Plate($1299)/Exedy Sport($599)
CUSCO TWIN PLATE - STI (CLEARANCE, ONE AT THIS PRICE!!)
-2205lbs Clamp Load!
-Includes Flywheel
-Great for big power STI's - 600ft/lbs+
-Special for both 5mt or 6mt
$1299 + Shipping!!
JDM 6MT CLOSE RATIO GEARS
The USDM 6-speed transmission was compromised by stringent US regulations for cruising fuel efficiency. Sacrificed was the close ratio gearing of the JDM 5th and 6th gears. This kit includes a shorter 5th and 6th gears to convert your taller USDM 6-Speed Transmission to a true close ratio JDM STi spec gear box. Professional installation is recommended.
Ratios
5th Gear - 1.062 (0.971 stock)
6th Gear - 0.842 (0.756 stock)
$279 SHIPPED! (Includes 4 gears, driven / drive)
EXEDY STOCK REPLACEMENT CLUTCH KIT (~375HP)
-Up to 350ft/lbs
-Great for use with stock and Stage 1/2 cars (stock turbo)
-Gruppe-S 14.9lbs FORGED flywheel!
6MT $499 Shipped!!
EXEDY SPORT CLUTCH KIT (~400HP)
-Up to 400ft/lbs
-Great for use with Stage 1/2 cars and pump gas upgraded turbo cars
6MT $599 Shipped!!
ACT HEAVY DUTY STREET DISC CLUTCH KIT (~450HP)
-Rated at 425ft/lbs
-Good for up to 350whp cars
-Excellent pedal feel / smooth engagement
6MT $669 Shipped!!
ACT 6-PUCK CLUTCH KIT (~590HP)
-Rated at 500ft/lbs
-Good for up to 450whp cars
-Reasonable pedal feel / crisp engagement
$699 Shipped!!
Cusco Twin Plate Clutch Kit (~600HP+)
-Excellent Twin Plate Clutch by Daikin
-Improved wear characteristics over Exedy Twin Plate
-Great for big power applications!!
$1399 Shipped!!
CUSCO TWIN PLATE CARBON
-Excellent Twin Plate Carbon Clutch by Daikin
-Carbon clutch disc for superior thermal characteristics
$1799 Shipped!!
ATS CARBON/CARBON CLUTCH KIT (~600HP+)
-Torque Capacity: 650 lbs/ft
-Pressure Increase: 1350kg
-Excellent Carbon Fiber heat resistance
-Ideal for FP Red, GT30r, and GT35r Turbos.
$1999 Shipped!!!
TILTON CLUTCH KIT
-Torque Capacity: Anything you can throw at it (850+ ft/lbs)
-Full blown race clutch - will probably last the entire season
-Not recommended for street use
-Easily / cheaply rebuildable
-Most people don't have this in stock - we do
$3999 Shipped!!! IN STOCK READY TO SHIP!!!
KARTBOY 6SPD SHORT SHIFTER & BUSHINGS!
-Excellent design / construction short-throw shifter
-6-speed shifter bushings
$149 Shipped!!! (two at this price)
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 06-06-2007, 01:18 PM   #2
Trader Rating: (13)
Default Re: CLEARANCE:JDM 6MT Close Ratio Gears($279)/Cusco Twin Plate($1299)/Exedy Sport($599)
Bump!!
Gruppe-S is offline
Old 06-07-2007, 10:10 AM   #3
Trader Rating: (13)
Bump!!
Gruppe-S is offline
Old 06-07-2007, 11:28 AM   #4
Car: 04 Subaru WRX STI
Send a message via AIM to 1STI2NV
hrmm i may take those gears seeing how my tranny mit have to come out
how long will those take to come to canada and is it free shipping as well
1STI2NV is offline
Old 06-07-2007, 01:39 PM   #5
Car: 05 subaru wrx sti
Send a message via AIM to tycoon53
Have anymore of the Exedy STI Hyper Single Clutch on clearance? i could of swore i saw them on here for like 699
tycoon53 is offline
Old 06-08-2007, 02:52 PM   #6
Trader Rating: (13)
1STI2NV - Shipping to canada is a little bit more. Whats your zip code?
tycoon53 - Sorry sold out. Let me know if you would like to place an order for a new one. Thanks!
-Travis
Gruppe-S is offline
Old 06-09-2007, 08:18 PM   #7
Car: 04
Hi Gruppe-S,
Trying to choose between:
-Up to 350ft/lbs
6MT $499 Shipped!!
-Up to 400ft/lbs
6MT $599 Shipped!!
#Replacing stock clutch on stock power.
#Lots of commuting, occasional track/lap time, no drag.
Which one would you suggest?
How much to ship to Canada postal code L5S1R2?
What carrier do you use "(scare of UPS charges)?
Thks
2dino
2dino is offline
Old 06-10-2007, 09:34 AM   #8
Car: 06 STI SGM
Fav Mod: seatbelts
Send a message via MSN to boost_happy
Originally Posted by 2dino
Hi Gruppe-S,
-Up to 350ft/lbs
6MT $499 Shipped!!
-Up to 400ft/lbs
6MT $599 Shipped!!
Thks
2dino
For $70 bucks more go for the ACT, much better clutch. Course thats MHO.
boost_happy is offline
Old 06-10-2007, 03:53 PM   #9
Trader Rating: (13)
The ACT clutches are very good clutches. I have spent a lot of time in cars with both types of clutches. IMO the Exedy clutch is more geared towards the stock turbo STI, with a softer engagement, better pedal feel, etc. whereas the ACT is great for the "step up" turbos, such as RR500, FP Green, etc as it holds more power at the expense of sharper engagement and stiffer pedal feel.
Cheers,
Gary
Gruppe-S
Gruppe-S is offline
Old 06-11-2007, 11:41 AM   #10
Car: 04
Default 2004 Sti clutch OE or Exedy stg1
Hi Gruppe-S
Sent PM re ship to Canada L5S 1R2.
Plas advise:
-Up to 350ft/lbs
6MT $499 Shipped!!
Also do you carry OE Sti clutch set?
Thks in advance.
2dino
2dino is offline
Old 06-11-2007, 02:39 PM   #11
Trader Rating: (13)
PM Replied!
Gruppe-S is offline
Old 06-21-2007, 06:51 AM   #12
Car: 2007 WRX STi
Fav Mod: Dual OEM subwoofer daisy chain
Kartboy shifter/bushings still available?
Gouki is offline
Old 08-14-2007, 04:21 PM   #13
Trader Rating: (13)
Hey Gouki, sorry we must of missed this post. Still available, call in to check your application.
Thanks,
Kyong
Gruppe-S is offline
Closed Thread
HTML code is On
