Go Back   IWSTI.com: Subaru STI Forums > STi Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > Gruppe-S
Old 02-19-2007, 04:04 PM   #1
Car: 01 Subaru WRX STi Spec C
Trader Rating: (13)
Default GS Stg2 +2mm Forged Kit ($999)/Perrin+DC Pak/Helix Catted/Alki Inj
Hey guys,
We got a crazy special on:
GRUPPE-S STAGE 2 (+2mm) FORGED INTERNAL KIT!
-Custom Wiseco +2mm Pistons
-Aerospace coating to reduce detonation and improve thermal characteristics (same as Cobb)
-Helix +2mm rods with ARP L19
-Longer piston dwell time improves rev range and top-end power
-Gruppe-S Coated Race Bearings
$999 Shipped!!
PERRIN AND DC COMBO!!ONE AVALIABLE!!
-Perrin Panel Filter
-Perrin Charge Pipe
-Perrin Down Pipe V1
-DC Up Pipe
SALE PRICE: $499.00 SHIPPED!!
Helix Catted Down Pipes BACK IN STOCK!!
The Helix Catted Downpipe incorporates Helix Power’s first-rate bell-mouth downpipe, with the addition of a 200 cell Metal-Substrate high-flow catalytic converter and thermal barrier heat-shield. The 200 cell Metal-Substrate downpipe has been tested by us to yield 7-10whp over the factory twin cats, while able to pass stringent California smog standards on the WRX / STI. The thermal barrier heat-shield assists in rapid warm-up of the cat for maximum efficiency and helping to reduce engine bay temperatures.
Price: $329.00 SHIPPED!!
HELIX V3 DOWNPIPE & DC SPORTS FLEX UPPIPE
-SS304 TIG welded design
-DC Sports Flex Uppipe Or Helix V3 Up pipe
-Excellent Performance gains
DC Sports Flex Up Pipe And Helix V3 Down Pipe
Regular Price: $325.00
SALE PRICE: 289.00 Shipped!!
TURBO BACK SPECIALS!!
Helix V3 Downpipe & Greddy EVO 2 exhaust
-Great balance of power & quietness
-Add $150 for Catted Version
$729 Shipped!!
Helix V3 Downpipe & Borla Hush
-Excellent stealth / quiet system
$745 Shipped!!
$669 Shipped!!
The Cobb Version 2 Access Port is one of the most user friendly systems on the market. This hand held ECU reprogramming system utilizes the full extent of your fuel management system allowing for easy, real time tuning. The Cobb AP V2 has come out with some upgrades since the Cobb AP V1 but still retains the high level of performance.
Cobb V2 Access Port Features:
-On the fly map switching
-Monitor vehicle sensor data and display in analog or digital format
-Vibrant color graphic display
-Read/Clear engine trouble codes
-Preloaded with performance, economy and convenience maps.
-Update via the Internet
-Measure 0-60 and ¼ mile times
-Adjustable on screen shift light functionality
-Estimates horsepower and Torque
-Displays current and averaged fuel economy
-Drag race simulation with reaction time and time slip data
-Built in on screen help mode function
-Multi language support
-RoHS Compliant (Lead Free design)
Cobb V2 Access Port Package 1
This package includes
-Cobb V2 Access Port
-Your choice of 1 Step Colder Spark Plugs or Walbro Fuel Pump
-Dyno Tuning
-Free Installation
Sale Price: $899.00 INSTALLED/TUNED
Cobb V2 Access Port Package 2
-Helix 660cc Injectors
-Walbro Fuel Pump
Regular Price: $1199.00
SALE PRICE: $899.00 OTD!!
INSTALLED/TUNED PRICE: $1149.00
Customers will have 30 days to schedule dyno tuning from time of purchase.
Non Local Customers!!!
This Package Includes:
-Set of NGK 1 Step Colder Spark Plugs
$699 shipped!
TURBO COMBOS!!
We have a great selection of turbo packages just for you Combo with Cobb Access Ports For ADDITIONAL SAVINGS!!
NEW ITEM HELIX RR500 Turbo Package!!
The Helix RR500 Turbo is a new turbo brought to us by Helix. This turbo is a 46lbs wheel turbo, race designed 8cm hotside, and features similar to the TD06 20G but with a larger compressor wheel. This turbo is rated at 500HP and will give you that extra boost of power when you most desperately need it.
-Helix RR500 Turbo
-Helix 660cc WRX or Helix 860cc STI
-Walbro Fuel Pump
Sale Price: $1449 Shipped!!
Combo With Cobb V2 Access Port: $2099.00 Shipped!!
Forced Performance Green or Red Turbo Package
-FP Green Turbo or Red
-Helix 860cc Fuel Injectors
-Walbro Fuel Pump
-Water and Oil Lines
Regular Price: $2755.00
Combo With Cobb V2 Access Port: $2599 Shipped!!
Helix RS430 (Prototype) ONLY 1 AVALIABLE!!
-BRAND NEW CHRA
-Basically this is a TD05 / 20G with the more efficient Helix compressor housing, high quality bearings, and high quality 14psi actuator
-Great pump gas / auto-X turbo
-Worth 40ft/lbs & 20whp more than the VF39 on pump gas.
-12,000 mile / 1 year warranty
$599 Shipped Brand New CHRA used turbine housing only
-Perrin Charge Pipe
-DC Up Pipe
-Gains of over 20whp!!
SALE PRICE: $499.00 SHIPPED!! ONE AT THIS PRICE!!!
SMC ALKI INJECTION KIT
-High quality / reliable pump
-Good for substantial horsepower gains
$499 Shipped!!
Thanks!!!
-Travis
Gruppe-S
Gruppe-S is offline   Reply With Quote
Old 02-20-2007, 04:29 PM   #2
Trader Rating: (13)
Default BUMP FOR +3MM Gruppe-S Throttle Bodies!!
Gruppe-S +3mm Throttle Bodies
-Match ported to +3mm (63mm)
-Matched butterfly plate
-Requires ported intake manifold for maximum benefits
$149 Shipped!! No Core!
>ONE< available!
Old 02-21-2007, 05:49 PM   #3
Trader Rating: (13)
Bump!!!
Old 02-27-2007, 06:01 PM   #4
Trader Rating: (13)
Bump!!
Old 03-12-2007, 05:14 PM   #5
Trader Rating: (13)
Bump!!
Old 03-13-2007, 07:08 PM   #6
Trader Rating: (13)
Bump!!
Old 03-15-2007, 05:05 PM   #7
Trader Rating: (13)
Bump for price drop on Perrin + DC Pak!!
Thanks,
Gary
Gruppe-S
HTML code is On
