| Authorized Vendor Car: 01 Subaru WRX STi Spec C Fav Mod: Coming Soon Posts: 4,022
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Hey guys, we have the following specials: Perrin GT30R Rotated Mount Complete Kit -GT30R Turbo -Uppipe / Downpipe -Rotated intake kit, 44mm WG -Includes BIG MAF, and filter $2699 Shipped! ONE AT THIS PRICE Add Helix 860cc Injectors (600+HP capable, depending on fuel system) $2999 Shipped!! Need Professional Installation by our ASE Master techs? $3599!! (Plus Tax) ![]() Gruppe-S 4-1 Header & DC Uppipes! This is a critical part of our "BIG TORQUE" combo. The 4-1 Header as well as the 2.25" uppipe substantially opens up your exhaust flow for huge torque numbers (top end is limited by turbo). An excellent combo for those guys trying to push more torque out of their stock turbo. Check out the dyno graph on 91 octane. That is an STI with less than $1K in mods. Turbo porting is recommended. -Gruppe-S Stainless 4-1 Header -Investment cast collector insures smooth flow -Fully SS304 Stainless, TIG welded -DC Sports 2" uppipe with flex section -We normally see gains of over 20tq and 10whp on a tuned STI with 93+ octane $449 Shipped! SWITCH TO HELIX V3 EWG UPPIPE - ADD $25 (for you big turbo guys!) ADD HELIX V3 DOWNPIPE - $159 ADD GREDDY EVO 2 EXHAUST - $CALL ![]() ![]() ![]() GRUPPE-S GS600 BUILT ENGINE! GRUPPE-S STAGE 1 (GS600) 2.5 FULLY FORGED ENGINE -Good for up to 600HP -Forged Wiseco Pistons (Custom) -Forged Helix Connecting Rods (H-beam) with ARP L19 rod bolts -Fully balanced, polished crankshaft -Professionally assembled and balanced with +/- 1 gram -Gruppe-S coated race bearings -Pre-owned block case (already heat cycled) $2799 + Shipping!! (shortblock only) ![]() GRUPPE-S GS650 LONG-ROD-RATIO BUILT ENGINE! -Good for up to 650HP -Forged Wiseco Pistons (Custom) -Forged +2mm Helix Connecting Rods with ARP L19 rod bolts -Race crankshaft (cross drilled, nitriding, etc.) -Gruppe-S coated race bearings -Pre-owned block case (already heat cycled) $3799 + Shipping!! (shortblock only) ![]() WIDE BAND 02 SENSOR COMBO I just installed the PLx M300 WB02 setup in our 06 STI with the Helix V3 downpipe. The M300 downpipe is an awesome entry level WB02 system, featuring very rapid response, quick warm-up times, and is very easy to setup. Coupled with the external WB02 port of the Helix V3 downpipe (located right in the exhaust stream) the readings are both accurate and rapid. -PLX M300 WIDEBAND CONTROLLER -Includes LED Display & WB02 sensor -Helix V3 Downpipe with Wide-Band 02 sensor port 6" behind turbo $479 shipped!! ![]() HELIX 860CC INJECTORS -Very similar to SARD or PE injectors -Manufactured by Denso Aftermarket program -Good for up to 600HP -Direct drop in, requires only clip swap (10 min) $439 Shipped!! Add Walbro Fuel Pump - $59 COBB V1 ACCESS PORT ONE LEFT AT THIS PRICE 2004 STI ONLY $499 Shipped!! ![]() Thanks, Gary gary@gruppe-s.com This ad is not endorsed by this member. Please register or login to hide this ad. Last edited by Gruppe-S; 12-01-2006 at 05:12 PM. |
| | #2 |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Hi, We have one: TD06-20G -BRAND NEW -GOOD FOR OVER 470HP -BOLT ON TURBO This was for a customer that wanted to go external wastegate but decided to go rotated instead. ACTUATOR and NO WATER/OIL lines are additional. Bare Turbo $849 SHIPPED Helix V3 Uppipe & Turbo $999 SHIPPED (You will need to weld the WG flap, we can do it for $30) Add Oil & Water Lines $50 ![]() Thanks, Gary Gruppe-S |
| | #4 | |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Quote:
Cheers, Gary Gruppe-S | |
| | #6 |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Hi, Sorry about that please give us a call 510-783-5300 or e-mail me. Phones have been pretty light from about 4:00pm today you should be able to get through anytime after 4:00pm PST if you're having trouble before then. My personal e-mail is gary@gruppe-s.com. Thanks! Gary Gruppe-S |
| | #13 | |
![]() Thanks, Gary Gruppe-S This ad is not endorsed by this member. Please register or login to hide this ad. | |
| Thread Tools | |
