Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Marketplace > Vendor Classifieds > Archived Vendor Classified Threads by Vendor > Gruppe-S
Old 11-13-2006, 04:09 PM   #1
Car: 01 Subaru WRX STi Spec C
IWSTI Addict since: Aug 2005
Trader Rating: (14)
Default V1 Access Ports ($499), Helix V3 Uppipes, Stage 1 Short Blocks, Other goodies :)
Hey guys,
We are clearing out the V1 Cobb Access Ports. The V2 Access Port is feature rich, but if you're not looking for all the bells and whistles and looking to save a bit of $$$, the V1 Access Port does allow full control of your ECU. We have a couple left on clearance prices:
Cobb V1 Access Ports
*Ability to use AccessECU maps without removing ECU
*10 Instantly Switchable Maps (Pump gas, race gas, valet, etc)
*True plug and play device
*Download new maps via the Internet
*Revert back to Stock programming
*Limitless Map Switching
$499 Shipped
Cobb AP & Helix 860cc Injectors
*Cobb V1 Access Port
*Helix 860cc Injectors
*Will support up to 600HP
$899 Shipped!!
We're pleased to finally release our Helix V3 Uppipes:
The Helix V3 uppipe was created for the 400+ horsepower EJ25. The V3 uppipe is designed to achieve real horsepower gains and improved torque curves by allowing the use of an external wastegate (EWG). An EWG eliminates the power-loss associated with internal wastegate turbos by moving the exhaust vent turbulence away from just before the nozzle area of the turbo. Not only does this result in improved power levels for high horsepower cars but also greater boost control and better torque curves. The V3 uppipe is mandrel bent from 2.3” SS304 tubing, TIG welded, and employs CNC machined flanges. The full 2.3” tubing allows for greater exhaust gas flow and only reduces down to 2.0” after the EWG port. The uppipe flange can be ported to 2.3” provided a 2.3” gasket is used (not included). The V3 uppipe can also be used as an internal wastegate uppipe with the included block off plate.* **
*External wastegate and external wastegate setup kit is not included. Optional V-band outlet is available.
**To use EWG option, internal wastegate must be secured by either welding the flap or locking the swing-arm.
HELIX V3 UPPIPE
-BIG 2.3" pipe diameter
-EWG Ready
-Direct bolt-on fitment
$199 Shipped!! (Introductory Price - EWG setup kit will be available shortly)
HELIX V3 UPPIPE & V3 DOWNPIPE COMBO
-Includes V3 Uppipe
-Includes V3 Downpipe
-Full SS304 Construction, TIG welded, CNC mandrel bent
$359 Shipped!!!
BIG TORQUE COMBO
We have seen HUGE gains in torque with the use of the Gruppe-S 4-1 headers and the Helix V3 Uppipe on the stock turbo STI. The reason is the huge 2.3" that allows substantially increased exhaust flow. Check out the dyno graph (sorry the scanner just broke).
COMBO INCLUDES:
-Gruppe-S 4-1 Headers
-Helix V3 Uppipe
-Helix V3 Downpipe
-Helix Cat-Back Exhaust
$1099 Shipped!!!
SWITCH OUT TO GREDDY EVO II - Add $125
TANABES ALSO AVAILABLE - CALL FOR PRICING!
Gruppe-S Stage 1 Short Block Engine
-600HP Capable
-Fully Forged Internals, Gruppe-S Coated Race Bearings
-Recommended 7500 RPM Redline
-Professionally Balanced Rotating Assembly
-Built to order (3 weeks, components are in stock)
$2799
If you give us your existing shortblock (we reuse your crank) $2299
Gruppe-S is offline   Reply With Quote
Old 11-13-2006, 04:35 PM   #2
Car: '06 WRB/Silver STI
Fav Mod: Kartboy Gear
IWSTI Addict since: Mar 2006
You got any AP's for the '06? How much shipped w/tax to 92078?
krazyk1371 is offline   Reply With Quote
Old 11-13-2006, 04:50 PM   #3
Trader Rating: (14)
Sorry man, 2006 WRX / STI all sold out
Thanks,
Gary
Gruppe-S
Old 11-17-2006, 09:54 AM   #4
Car: WRB 05 WRX STi
Fav Mod: Corn on a COBB
IWSTI Addict since: Sep 2006
Trader Rating: (17)
Do you have a V1 Cobb Accessport available for an 05 STi? Possible repeat customer.
STlouisSTi is offline   Reply With Quote
Old 11-20-2006, 05:34 PM   #5
Trader Rating: (14)
Sorry man, I have ONE 04 STI Cobb AP (V1) left only for the STIs. Got some WRX's left, but no more STI's.
Thanks,
Gary
Gruppe-S
HTML code is On
