| Authorized Vendor Car: 01 Subaru WRX STi Spec C Fav Mod: Coming Soon Posts: 3,967
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Helix Power 860cc Injectors for STi + Walbro 255L FP and setup kit - $565 Shipped! $495 Shipped for just the Injectors! - Ideal for 20G, Green, Red, GT30R, GT35R, etc. - 550WHP Capable ![]() Gruppe-S V2 Manifold Crucial Racing 2000 Coating - 02+ WRX / 04+ STI - $599 Shipped! The Gruppe-S manifold is a 4 to 1 manifold designed to provide extensive midrange and top-end power gains. Our manifold features T304 Stainless Steel piping, mandrel bends, and CNC precision cut flanges. The 4-1 collector is cast to ensure the smoothest possible low rates. Strong gains in both HP and torque can be expected with the addition of the manifold, especially with high horsepower applications. The Jet Hot 2000 outside coating eliminates heat loss thus virtually eliminating low end power loss (compared to stock headers). These are the best coated headers we have ever seen; the coating is evenly applied with no bubbles and is absent from all bungs and threading. Includes all necessary gaskets. The Crucial Racing 2000 outside coating eliminates heat loss from the exhaust gasses (as compared to stock headers). Because warmer air travels more quickly and expands more quickly, this helps to spool the turbo more quickly. More information on the coating is available here: http://www.crucialracing.com/products/coating.php ![]() Gruppe-S Oil Cooler Kit - $499 Shipped! This Oil Cooler kit was introduced to the public after testing several iterations on Brian Lock's USTCC race car in the deserts of Arizona. The stock WRX and STi lack an oil cooler and running any turbo charged motor hard puts an extreme load on the motor's cooling systems and fluids. Keeping your oil cool not only prolongs the life of your oil but more importantly, it prolongs the life of your motor. This is one of the most overlooked upgrades on the WRX / STi and we feel that anyone who drives their turbocharged vehicle hard should have one. Perhaps that's why the Spec. C comes with an oil cooler from the factory. This oil cooler is track tested on a race winning vehicle and data logs show that it works. In comparison to competitors' oil coolers, the Gruppe-S Oil Cooler features an extremely high quality European core manufactured by a world famous brand and a thermostat of similar quality. Key Features: *High quality European core (240mm x 120mm x 45mm), not some Taiwanese knock off core. *Thermostat operated Oil Cooler to avoid cooling cold oil upon startup. *Aerospace fittings / stainless steel lines, professionally assembled and tested to 1000psi. *Light weight mounting brackets. In the words of USTCC race car driver Brian Lock, “this oil cooler rocks. After installing this setup we never had a problem with oil temperature again. Even at PIR where it was 115 and it was so hot inside the car I thought my legs were on fire, it was golden. Brian Lock thinks that this oil cooler is the ****, Brian Lock thinks you should buy it.” ![]() Mounts and Acessories: Cusco Engine/Tranny Mount Combo - 02+ WRX / 04+ STi - $250 Shipped These mounts are stiffer than the STi Group N mounts and are designed to reduce excessive flex in the stock mounts. STi Group N Engine Mounts - 02+ WRX / 04+ STi - $95 Shipped STi Group N Pitch Stop Mounts - 02+ WRX / 04+ STi - $45 Shipped The STI "Group-N" Engine Mounts and Pitch Stop mounts are designed to reduce excessive motion of your motor during hard acceleration, deceleration, and cornering. This is done by increasing material stiffness over your stock engine mounts. By decreasing this type of motion, more energy is focused to the drivetrain rather than shifting the engine. These make an excellent replacement for the liquid filled platic units that are standard issue in the 06 STi. ![]() STi Group N Engine / Pitch Stop Mount Combo - 02+ WRX / 04+ STi - $130 Shipped Cusco Radiator Shroud - 02+ WRX / 04+ STI - $99 Shipped! Built Shortblocks and Motors: Gruppe-S Stage 1 USDM STi Longblock - $3999 + Shipping (built to order) We have one blown STi motor that we will be rebuilding into one of our stage 1 longblocks (balanced, forged Wiseco pistons, coated race bearings, etc.). This longblock will be capable of holding 535 crank HP consistantly and will drop into any WRX or STi easily. Build time will be ~3 weeks and a 50% deposit will be required. You will not see this price on a longblock like this again! *Longblock does not include ancillaries located on top of motor or accessories: no water pump, AC condenser, power steering pump, intake manifold, wiring harness, turbo, intercooler, etc. -Gruppe-S / Wiseco Forged Pistons (custom spec) -Gruppe-S Coated High Performance Rod & Crankshaft bearings -Forged STi connecting Rods -Forged STi crank shaft -ARP Headstuds -Cometic Head Gaskets (on long-block option) -Professionally balanced rotating assembly (recommended 7500 RPM redline) -Rehoned cylinder walls -Capable of up to 535HP Operation -~3 week build time, 50% deposit required *Picture represents product and is not actual product. Actual product is longblock, not motor. Gruppe-S 2.5L Stage 1 Shortblock - $2599 + shipping Our Stage 1 shortblock replaces the components we feel are most likely to fail in the USDM STi shortblock. This is essentially a bulletproof USDM STi shortblock and will compliment a GT30R, SZ55, FP Red , FP Green, or TD06-20G sized turbo nicely on 100 octane. WRX owners can benefit from this shortblock also since their heads will bolt right onto it; however, combining their heads with something like the Helix cams and valvetrain and this shortblock would yield something with peak power output similar to the USDM STi. In comparison to other companies' Stage 1 shortblocks, our adds coated race bearings and balancing to within 1 gram (JDM STi motors are balanced to within 7 grams). Features: -Gruppe-S / Wiseco Forged Pistons -Gruppe-S Coated High Performance Rod & Crankshaft bearings -STi Forged Connecting Rods -STi Forged Crankshaft -ARP Headstuds (on long-block option) -Cometic Head Gaskets (on long-block option) -Professionally balanced rotating assembly (recommended 7500 RPM redline) -Rehoned cylinder walls -Capable of up to 535+ CHP Operation -Final Displacement 2.48L -Compression ~8.5 : 1 *Assembly time is generally 3-4 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order. Gruppe-S Stage 2+ 2.5L Shortblock - $3999 + shipping Our Stage 2+ shortblock is built for big numbers. This block is capable of over 625 CHP and 7800 RPM. It will max out a GT35R .82 and anything smaller than that. In comparison to the Stage 1, it adds a nitrated, lightened, and magnafluxed forged STi crankshaft and forged steel Pauter connecting rods. Features: -Gruppe-S / Wiseco Forged Pistons -Coated High Performance Rod & Crankshaft bearings -Reworked high RPM Forged STi Crankshaft -Forged Pauter Connecting Rods -Gruppe-S Stage Two camshafts (AVCS available) (on long-block option) -Gruppe-S Stage Two Valve Train (on long-block option) -ARP Headstuds (on long-block option) -Cometic Head Gaskets (on long-block option) -Professionally balanced and assembled (recommended 7800 RPM redline) -Rehoned cylinder walls -Capable of up to 625+ CHP Operation -Final Displacement 2.48L -Compression ~8.5 : 1 *Assembly time is generally 3-4 weeks. For the Long block option, we require a core charge for the heads which will be refunded if you heads are in good working order. ![]() Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: sales@gruppe-s.com When ordering w/ paypal, please include the following: product name: XXXX sales rep: Mark Price including shipping: $XXXX Shipping address. This ad is not endorsed by this member. Please register or login to hide this ad. |
| | #2 |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Catbacks: Helix Full Ti JDM type Exhaust for WRX / STI - $849 Shipped Helix has just released a limited edition full titanium exhaust. However, unlike the JIC and Greddy Exhausts, this exhaust is not made from rolled titanium tube; it's made from true tubular titanium (like the Amuse). Again, this is a true JDM spec exhaust system. It is not Chinese made titanium, or constructed by rolling titanium into a tube and then welding it (basically non-seamless tube), The Helix unit uses full JDM aerospace grade titanium that is one piece extruded titanium pipe. - Super lightweight 11.5 LBS - JDM Spec SEAMLESS Mandrel Bent Piping - Available in both blue scorched tip and normal - Robotic TIG Welding - Includes gaskets ![]() *Scorched tip version shown. HKS Hiper for WRX / STI - $529 shipped -75mm piping -Full stainless steel, comes with all gaskets and hardware ![]() HKS Carbon Ti for WRX / STI - $719 shipped -75mm piping -Full stainless steel with carbon canister and titanium tip, comes with all gaskets and hardware ![]() Greddy Evo2 for WRX / STI - $579 shipped -CARB certified, under 95 db -80mm piping -Full stainless steel, comes with all gaskets and hardware ![]() Greddy SP2 for WRX / STI - $539 shipped -CARB certified, under 95 db -80mm piping -Full stainless steel with carbon canister and titanium tip, comes with all gaskets and hardware ![]() Perrin: Perrin Front Mount IC for WRX / STI - $1099 shipped -Rated for 500-800 HP -Low pressure drop across core, efficient core. -Comes w/ new bumper beam Perrin Signiture Series FMIC for WRX / STI - $1175 shipped -Rated for 500-800 HP -Low pressure drop across core, efficient core. -Comes w/ new bumper beam -Comes w/ wrinkle red piping Perrin Big MAF for WRX / STI / FXT - $209 shipped -Allows more air to travel through the MAF without maxing it -Highly recommeded for 20G / Green and larger sized turbos -Requires tuning Perrin Turbo Inlet Hose for WRX / STI / FXT - $209 shipped -Smooths airflow into turbo ![]() Perrin Downpipe for WRX / STI / FXT - $319 shipped -304 Stainless, 75mm piping -Divorced wastegate design ![]() MORE PERRIN HERE: http://www.gruppe-s.com/subaru.htm Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: sales@gruppe-s.com When ordering w/ paypal, please include the following: product name: XXXX Price including shipping: $XXXX Shipping address. |
| | #3 |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | We've got some new T-shirts that I happen to think are pretty fresh. Notice how the front of the shirt has the cam-covers on it but the back doesn't. We're so clever! Gruppe-S T-Shirt - $19 Shipped!!! -Black - M, L, XL, XXL -White - L only ![]() Thanks, Mark Phone: (510) 783-5300 We Accept Paypal! Paypal: sales@gruppe-s.com When ordering w/ paypal, please include the following: product name: XXXX Price including shipping: $XXXX Shipping address. |
| | #5 | |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | Quote:
Cheers, Mark | |
| | #7 |
IWSTI Addict since: Aug 2005 Trader Rating: (14) | We haven't heard of Helix making another run on these exhausts just yet, but be sure that when they do that we will have it up on the boards. Cheers, Mark This ad is not endorsed by this member. Please register or login to hide this ad. |
| Thread Tools | |
