| Junior STI Driver Feedback Score: 4 reviews Car: Blue 08 WRX STI Fav Mod: Coming Soon Posts: 57
IWSTI Addict since: Dec 2008 | i have a question , i want to install a swift lower spring on my 08 sti , did i need to cut the front and rear bump stop ? actully did the front has bump stop ? thanks |
| | #2 |
| Silver Member Feedback Score: 0 reviews Car: '08 STi '06 Tribeca My Stuff: Subaru Parts Location: Currently Severna Park MD Posts: 143
IWSTI Addict since: Apr 2009 | I installed RCE springs which came with the shorter bump stops. You might want to call your swift rep. Do the install instructions say anything about cutting them down? It can be done...I've done it on an old BMW without an issue. Cut them from the bottom if you do decide to do it. What's the drop on your springs? |
| | #3 |
IWSTI Addict since: Apr 2009 | |
| | #4 |
IWSTI Addict since: Dec 2008 | when u take out the front , did u see the stock have pump stop inside ? because mine don't has it .thanks for your help |
| | #5 | |
IWSTI Addict since: Dec 2008 | 1 inch drop . Quote:
| | #6 |
| Junior STI Driver Feedback Score: 3 reviews Car: 08 WRB STi Fav Mod: Coming Soon Location: SoCal Posts: 73
IWSTI Addict since: Dec 2008 | inverted struts. once the spring is off, undo the nut on the bottom of the strut and the piston assembly thingie will slide out. the bumpstop is in there just need to do some extra work! |
| | #7 |
| | #8 |
| The Next Petter Solberg Feedback Score: 4 reviews | 1 inch drop? then u should trim them |
| Thread Tools | |
Similar Threads | ||||
| Spring Install | no1stunna2k | Mid Atlantic | 2 | 05-05-2008 12:06 PM |
| Spring install question/ Clunking Problem | DragonXero13 | GD-Suspension, Handling, & Stiffening | 10 | 07-15-2007 09:12 AM |
| cut bumpstops for swift springs? | Wick16 | GD-Suspension, Handling, & Stiffening | 15 | 03-27-2007 10:58 PM |
| I fixed the STi pink spring install thread | Rev | GD-Suspension, Handling, & Stiffening | 3 | 04-09-2005 08:35 PM |
| lower spring | lostcool | GD-Suspension, Handling, & Stiffening | 0 | 07-19-2004 02:53 PM |
