| | Thread Tools |
| Platinum Member Feedback Score: 0 reviews Fav Mod: SPT Exhaust | I mostly DD, but like to participate in various motorsports events. So far I've done HPDE at Pacific Raceways, a few 1/4 miles drags at Pacific Raceways, and Bonneville Salt Flats 1 mile 130mph club. Suspension is great, now time for a new engine + rotated turbo. Engine: New built block from MPS Ported heads Kelford 264 cams Perrin FMIC Killer B oil pan with baffle Killer B oil pickup Perrin rotated turbo kit with GTX3576R with .82 AR housing Cobb Accessport SPT Exhaust TGV Deletes Deatschwerks 850cc Injectors '04 Stock FPR Interior: SPT Boost Gauge 5lb Fire Extinguisher with mount Exterior: Volk Racing TE-37 18x9.5 wheels w/Bridgestone Potenza RE-11 265/35R-18 Stock wheels w/Bridgestone Blizzak WS60 235/40R-18 DBA 4000 Series rotors front and rear Ferodo DS2500 brake pads front and rear RCE Kool Brake kit Beatrush Aluminium Undertray Custom Driveshaft Retention loops Suspension: KW Variant 3 coilovers Cusco Power Brace Floor Cusco Front Lower Arm Brace Cusco Power Brace Rear Lower Cusco Power Brace Rear Upper Cusco Power Brace Crossmember Cusco Exhaust hanger 2011 Lower control arms Group N Rear Suspension Crossmember Bushings Powerflex Rear Upper Arm Inner Front Bushing with camber adjustment Powerflex Rear Upper Arm Inner Front Bushing with camber adjustment Group N Rear Lower Arm Front Bushings Group N Rear Lateral Arm Rear Bushings Group N Rear Lateral Arm Front Bushings Group N Rear Trailing Arm Rear Bushings Group N Rear Trailing Arm Front Bushings Group N Front Control Arm Front Bushings Parts ordered: Aeromotive FPR Last edited by Gleep; 07-25-12 at 07:29 PM. |
| | #2 |
| Platinum Member Feedback Score: 0 reviews Fav Mod: SPT Exhaust | Reserved |
| | #3 |
| Advanced Contributor Level 2 Feedback Score: 3 reviews Fav Mod: Invidia Downpipe | Looking forward to your updates! I don't see any sway bars on your list. If you are going to offload those RCE Blacks, let me know. I may be interested. I have RCE yellows right now, but want some better ground clearance. |
| | #4 | |
| Platinum Member Feedback Score: 0 reviews Fav Mod: SPT Exhaust | Quote:
I don't have any plans for the RCE Blacks so I'm sure we can work something out. | |
| | #5 |
| Platinum Member Feedback Score: 0 reviews Fav Mod: SPT Exhaust | Adding pictures of stuff to be installed. 2011 Lower Control Arms Cusco Power Brace Rear Lower Cusco Front Lower Arm Bar Type II Cusco Power Brace Floor Center |
| | #6 |
| Platinum Member Feedback Score: 0 reviews Fav Mod: SPT Exhaust | Car has been the shop for the past couple days, the rear upper control arm bushings never arrived and once the shop had everything apart they suggested a camber adjustable bushing. Powerflex makes a urethane bushing with a nice adjustment. New GR rear camber adjustment So another day of delay while they are shipped but it should make the alignment better. I'm not a fan of urethane bushings on my daily driver due to the maintenance required but it seems there is no good solution rear camber adjustment. |
| | #7 |
| Silver Member Feedback Score: 2 reviews Fav Mod: Coming Soon | You don't happen to play Myth 2 do you? I know a guy on there with the screen name Gleep heh. |
| | #8 |
| Platinum Member Feedback Score: 0 reviews Fav Mod: SPT Exhaust | |
| | #9 |
| Platinum Member Feedback Score: 0 reviews Fav Mod: SPT Exhaust | Everything is installed now. I haven't had a chance to push the limit, but ride comfort is better than RCE blacks with stock shocks. In a few weeks I'll have a chance to push it on a track and really see what the changes feel like. Alignment numbers Front Caster 6.53/6.30 Front Camber -1.88/-1.86 Front Toe 0.02/0.02 Rear Camber -1.09/-1.14 Rear Toe 0.02/0.02 I'd like more front camber but without camber plates -1.86 was all we could get. With all the bracing and 1/4 tank of gas the car weighs 3377lbs. |
| | #10 |
| Platinum Member Feedback Score: 0 reviews Fav Mod: SPT Exhaust | Went to Pacific Raceways this week, the coilovers + bracing feels great. The brake cooling kit + DS2500s had 0 fade even after a 30 minute session, of course it was only in the mid 40s so I don't know if the brakes will be an issue on a 90F day. If the brakes hold up to a 90F day then I'll stop drooling over BBKs. I bled my brakes before the track and everything felt great, but after the track the pedal has some play at the top so I'll have to bleed everything again. I need to come up with a cover for the brake cooling kit, not only do I not need the cooling for DD but it doesn't look that good right now. Ordered an external GPS to log some data, so the next video should have some useful overlay info. |
| Thread Tools | |
