Engine:
Built block
TGV delete
Air pump delete
Killer B Oil Pickup and Baffle
POWAH:
Accessport
AEM CAI
Invidia EL Headers, coated and wrapped
Grimmspeed EBCS
DW 65c fuel pump
EFI Logics Fuel System
Grimmspeed TMIC
ACT HDSS clutch
KillerB Spoolinator kit with GTX-3067R
EWG
Moroso Catch Cans
Corsa catback exhaust
Handling:
Perrin SLS
RCE swaybars
Kartboy endlinks
Project Mu B-Spec pads
Kartboy short shifter and some bushings
RCE Blacks on bilstein struts with whiteline com c front tophats
Superpro ALK
Group N Engine mounts
Beatrush pitch stop
Whiteline rear diff inserts
Super pro eccentric rear inner control arm bushings
Goodridge SS Brake Lines
2015 steering rack with superpro steering rack bushings
Exterior/Appearance/Style changes:
18x8.5 TSW Nurburgrings
red taillight vinyl covers
debadged front and rear
replica v-limited lip
nokya yellow fog lights (one removed)
Plastidipped side badges
Anarchy Motive Shift Knob
Pioneer AVH-X3500BHS Head Unit with Axxess and a backup camera.
Bike rack!
A shit ton of dents, paint chips, poorly rolled rear fenders, and dirt.
longer studs, lug nuts
R205 badges
Prova SI-Drive Cover
Hella Sharptones with subimods harness
So I have been terrible about updating this I know. What has gone down since last post:
When tuning, shop found compressor blades were rubbing on housing. Boo. So my $600 turbo needed an $800 rebuild. Sucked. But everything is mostly now working. Made 402wtq and 350sih hp (shop said they had to pull timing up top due to what they suspected was bad gas).
They did do a meh job of re-routing the extra long fuel line, which I might have to fix.
Up next:
1. The beatrush pitch stop sitting in the garage
2. SS brake lines (also sitting in garage)
3. DEI on the intercooler.
4. Diff bushing inserts
5. The big thing: thinking an ALK and front inner LCA bushing as well.
6. Possibly a master cylinder brace.
Re: The Black Swan (Now with a built block and a Dom 1!)
Diff bushings installed! God those bolts on the crossmember were tough. We rounded one getting it off and possibly overtorqued its (hardware store) replacement putting it on. I'll get the real castle nut soon enough.
Finally bought a nicer phone mount for the AP. Might route the cable through the steering column too.
I was thinking ALK, but everyone seems to think that picking up 2011+ control arms is a better idea. So might get to work on that.
So it snowed in Charlotte today. So I took her to an empty parking lot (or two), as she'd never seen snow before, and I've never really driven on it. Both entertaining and educational, especially on Star Specs.
Well, track day is in 1 week, which will probably be the death of said star specs. I'm probably going to bite the bullet and get the Raijins I said I'd get once my tires went, so the question now is what tires to put on them. 265 or 275? And so many different tires to choose from!
For the 3 other people that read this:
Took her to Barber for a track day. She was working well, though the tires were trashed, until on the second to last session of the day I suddenly and completely lost all of my brakes. And they weren't coming back.
Then, trying to get the wheels off with SubieEngineer to bleed the brakes I broke one lug and managed to strip the other without the lug nut coming off. So instead of coming home as planned spent an extra night in Birmingham and took her to a tire shop the next morning for 2 new lugs and a bleed. But brakes don’t feel quite where they were and there was some fluid in the engine bay, so I’m gonna have the dealer or someone look at it. And probably pay a shop to do the blasted SS lines since I can’t get those brass nuts to move to save my life.
:lol:
I'm hoping there's no leak or anything anywhere and it's all air in the lines. How'd the shop bleed the brakes? You could also take this time to install ARP wheel studs if you were so inclined.
When you get the SS lines, I'd suggest Valvoline Synpower fluid as a minimum. I use Motul RBF600. It's not cheap, but it's cheaper than RBF660 and others and is good piece of mind.
Welp, I'm now off break-in oil. And on to Rotella T6.
Also bought a Moroso catch can setup on impulse yesterday.
Up next handling:
Wheels and tires (likely gonna move to dedicated street and track sets)
GTworx Struts with comc hats
superpro ALK
superpro front inner LCA bushing
Lots of fun times ahead! Would love to have all/most done by tail of the dragon.
Tomorrow: Track wheels and tires go to get mounted, and car goes to get SS lines installed (I have given up on doing it myself). Hopefully all done tomorrow so I can get my fenders rolled tomorrow night.
Related Threads
IW STi Forum
4.1M posts
121.3K members
Since 2001
