RallySport Direct's 2011 STI Sedan!
GR Sedan:
254K views 770 replies 183 participants last post by  yamahaSHO
#1 · (Edited)
On Friday around 1pm we got a wonderful Phone call from the local dealer letting us know our STi was in. The 1st in the state, and one of the first in US. After several months of waiting it was a wonderful thing to see pulling into the dealer lot
We wasted no time and picked up the car a couple min later. With 7 miles on the odometer the car looked amazing and pictures don’t do it justice. We have big plans in the works, but you will just have to wait and see.
1st Impressions compared to a 2008 STi.
WOW! Subaru listened to its customers. The handling is crisper, more precise and surprisingly sporty. The back end is much more stable and the front end just goes where you point it. Another nice thing is that the stock exhaust is actually noticeable. A quick blip of the throttle and you can hear the all so familiar Subaru Boxer rumble.
Update 05/7/2013
Current Parts List
Engine:
Cobb Tuning AccessPort
Cobb Tuning Down Pipe
Cobb Tuning Heat Shield
Invidia Q300 Ti Tip Catback
Cosworth Intake
GT Spec Oil Sandwich Block Adapter
Samco Radiator Hose Kit
Koyo Aluminum Racing Radiator
Omni Power 4 Bar map sensor
Injector Dynamics 1000cc Top Feed Injectors
DeatschWerks 300lph Fuel Pump
Process West Top Mount Intercooler
Tomei Fuel Pressure Regulator Type-S
Tomei Fuel Pressure Gauge
ATP GTX3076
Tomei Expreme Unequal Length Exhaust Manifold
GrimmSpeed Air Oil Separator
GrimmSpeed Manual Boost Controller
GrimmSpeed Electronic Boost Controller
GrimmSpeed External Waste Gate Bracket
AMR Performance Cast Turbo Inlet
GTSpec 44mm V-Band 3-Bolt External Wastegate Uppipe
TurboSmart Duel Port Blow Off Valve
TurboSmart Hyper-Gate45 Wastegate
Prova Radiator Cap
Okada Project Plasma Direct Coil Pack
Okada Project Plasma Spark
APR/ Carbign Craft Radiator Cover
APR/ Carbign Craft Alternator Cover
STi "strut bar" battery tie down
Suspension:
TEIN Mono Flex Coilovers
Cusco Trailing Arms
Cusco Lateral Links
Cusco 23mm Front Sway Bar
Cusco 20mm Rear Sway Bar
Cusco Front Strut Tower Bar
Cusco Rear Strut Tower Bar
Cusco Rear Strut Tower Bar quick Release
Cusco Rear Member Power Brace
Cusco Rear Member Side Power Brace
Cusco Front Cross Member Power Brace
Cusco Type II Front Lower Arm Bar
Cusco Front Member Power Brace
Kartboy Front End Links
Cobb Tuning Rear Endlinks
Whiteline Rear Lateral Adjustable toe Arms
Interior:
Prova D Shape Steering Wheel
Prova Black SI drive Knob
ATi Version 2 gauge pod
Defi ADVANCE BF 60mm Boost
Defi ADVANCE BF 60mm Oil Temp
Defi ADVANCE BF 60mm Oil Pressure
Defi ADVANCE BF Link System
Bride Stradia LowMax with CFPR. Passanger
Bride Gias LowMax with CFPR. Driver
Bride Low down seat bases
Cobb Tuning Shift Knob
Takata Harnesses
Takata Harness Pads
JPM Coachworks Cluster hood.
JPM Coachworks Shift Boot
JPM Coachworks E brake boot
JPM Coachworks Custom Wrapped Dash
JPM Coachworks Wrapped Rear Seats with Bride Fabric
JPM Coachworks Wrapped Pillars
JPM Coachworks Wrapped center console
JPM Coachworks Wrapped Sun Visors
JPM Coachworks Wrapped Arm Rest.
Proto Tuning Tool Holder
Exterior:
Prova Mirror Covers in Yellow
HKS Kansai Front Tow Hook. Custom Powder Coated Project Mu Color
HKS Kansai Rear Tow Hook. Custom Powder Coated Project Mu Color
STi R205 Black side badges
STi V-Limited Front Lip
STi V-Limited Front Lip Skirt
STi Rear Bumper Brake Light
STi Side Under Spoiler
OEM Wingless Trunk Debadged and Trunk Holes Welded
APR GTC-300 67” Wing
APR/Carbing Craft Carbon Fiber License Plate Backing
APR/ Carbign Craft Carbon Fiber Exhaust Heat Shield
Paint Matched Rear Trunk Trim
Carbing Craft License Plate Frame
Drivetrain:
MODE RACING Double Adjustable Short Shifter
Kartboy Front Shifter Bushings
Kartboy Rear Shifter Bushings
PST Carbon Drive Shaft
Brakes:
Project Mu 6 Piston Front Big Brake kit with 2 piece Rotor
Project Mu 4 Piston Rear Big Brake kit with 2 piece Rotor
ATE Super Blue Brake Fluid
Wheels:
Advan RZ-DF 19x10 +35, Custom Painted Blue Lip and Barrel, with Charcoal Grey Spokes 265/30-19 Nitto Invo.
Advan Racing Flat Type Canter Caps in Black
Kics R40 Regular color Lug Nuts
Would Like to Say Thanks for the Following Manufactures who are involved with this Vehicle:
Cobb Tuning
Tomei
Cusco
DeatschWerks
GrimmSpeed
ProcessWest
Cosworth
TurboSmart
ATi
JPM
PROVA
Project Mu
Volk Racing
APR
Update: 10/29/2010
We where fortunate enough to be invited to display our 2011 STi at the VOLK/Rays wheel booth for the 2010 SEMA show...we cant spill all the beans of the parts on the car until the show, but here is a preview.
More official pictures and details coming up! So stay tuned!
At the 2010 SEMA show!
And the PhotoShoot of the Exterior :) (11/15/2010)
G2's in different lighting...These wheels are SICK!
SEMA 2011!
Images of the Rear Suspension, and the Prototype Cobb Exhaust (keep in mind minor changes will be made to the exhaust). 11/23/10
Interior Photo Shoot! 11/29/10
#62 ·
Re: RallySport Direct's 2011 STI Sedan
Keep up the nice work!
#67 · (Edited)
VVVEERRRYYYY nice looking!!!!
do you know if Rally Armor v2 for STI 2011 hatch will fit on the 2011 sedan?
or if Ill have to order two sets
1: STI 2010 , for the front
1: WRX 2010 , for the rear
Just got a follow-up email, and looks like they will have a new flap that is sedan specific!
#74 ·
Sorry about the lack of updates.
The last thing we did was get the car aligned. We are currently in the process of getting the motor broken in so we can start messing with other aspects of the car.
With that being said, we have some goodies on order right now which should be here in the next little bit. Once those are here and the motor is broken in the next round of installs will follow.
#76 ·
The settings are -4.25 in the front and -3.25 in the rear.
No camber bolts where needed.
On the front we can get another .25 degrees up to 4.5 total if we wanted to.
On the rear we should easily be able to get o -4. However adjustable toe arms would be needed as the stock Toe adjustment is currently maxed out.
#77 ·
And a little something for you guys who plan on using the Cobb AccessPort on your 2011 STi's.
Cobb is now using the Si drive to increase boost levels from S to S#.
And if you also look at the difference between Stage 1 and Stage 2, its minimal. Compared to all the previous turbo Subaru vehicles that saw huge power gains from stage 1 to stage 2. Do to some slight differences in the OEM down pipe design, the need for a aftermarket unit to get huge power gains is not as critical while running the stock turbo.
#79 · (Edited)
From all the testing done so far, the OEM 2011 STi Down pipes are showing to be less of a restriction and better flowing compared to how restrictive the previous models where.
That seems very strange. Different design in downpipe makes the OEM downpipe on the 2011 a little bit better?? But at the same time it is still rated 305 hp?
Correct. Some companies have been know to under-rate cars. Also its hard to say how Subaru tests the motors output and what items are and what ones are not in place in terms of exhaust and intake components.
Just going off the old rule of thumb and saying that AWD cars have a 25% drivetrain loss, this would put the stock output around 340ish at the crank.
#81 ·
Any pictures of the new downpipe?
#87 ·
Daaamn! Makes me very jealous! Looking very good! I can't wait to see what all is in store for the car. Way to go guys!
#88 ·
My psychic says they see a jdm interior and headlight conversion in your future...
