GR Hatch: IAG Built| HTA86| >500whp| Daily driven for 135,000 miles - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > GR Hatch: IAG Built| HTA86| >500whp| Daily driven for 135,000 miles
Old 07-04-09, 01:43 PM   #1
user1029
Feedback Score: 5 reviews
Fav Mod: HTA86.
user1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud ofuser1029 has much to be proud of
Default IAG Built| HTA86| >500whp| Daily driven for 135,000 miles
Disclaimer: I have no sponsorships or financial ties to IAG or any other companies listed in my journal. I am a hard-working, private owner of this vehicle and its modifications.
Stock STi baseline = 225whp (IAG dyno numbers are uncorrected)
http://www.youtube.com/v/KqazCyZDAeM
http://www.youtube.com/v/klFXor5VfO0
http://www.youtube.com/v/DCDAyjXO0Mg
My feedback on this project: NASIOC - View Single Post - IAG Performance (merged thread)
Love, it's what makes a Subaru, a Subaru
IAG V-band Rotated Turbo Kit
-HTA3586 0.82 Tial V band housing (GT35R vs. HTA86 comparison) --> Xona Rotor 7864 0.82A/R (4/2017)
- IAG FMIC kit with Spearco core and front crash beam
- IAG 4" Intake
- IAG V-band Uppipe
- IAG V-band Catless Downpipe
- Tial 44mm External Wastegate with open dump
- GT Spec Equal Length Headers V-band with Uppipe
- Corsa Performance 3" Catback Exhaust
- Aquamist HFS-6 running Boost Juice (50% methanol/50% water; tincture of meth to suppress detonation and get some chunky midrange)
- Grimmspeed Electronic Boost Control Solenoid
- Grimmspeed Thermostat
- Mishimoto Radiator
- Tial Q BOV
- LFR7AIX Spark Plugs gapped to 0.024
- IAG Air-Oil Separator (IAG AOS Review)
- Stock Air Pump deleted
- IAT sensor and 4 Bar MAP sensor
Fueling
- Injector Dynamics 2000cc injectors
- AEM 320lph in-tank pump
- Radium Multi-pump surge tank with 2 Walbro E85 compatible 465lph pumps
- Parallel -8AN feed and -6AN return lines for E85
- Cobb Fuel Pressure Sensor
- Cobb FlexFuel + Speed Density tuned by Junior
IAG Stage 4 Extreme Shortblock (20k DD miles and counting...)
- IAG Closed deck
- Manley TurboTuff Pistons
- Manley TurboTuff I-Beam Rods
- ACL Main and Rod Bearings
- OEM Nitrided Crank
- Pinned Mains
- OEM 11mm Oil Pump
- Gates Racing Timing Belt Kit
- 12,000mile/1year warranty
IAG Stage V Heads
- Flipped Cosworth Manifold with retained Air Conditioning Stock Vs. Cosworth IM comparison
- 14mm IAG head studs
- Copper O-ring
- JE Pro Seal headgasket
- Manley Extreme Duty 33mm Exhaust Valve Set
- Manley Race Flow 37mm Intake Valve Set
- Manley Valve Spring and Retainer Kit
- IAG Stage V headwork with Multi Angle Valve Job/Port&Polish
- Kelford Dual AVCS 272/268 11.30/10.50mm Lift Street Cams
- Cosworth Phenolic Spacers
- IAG TGV Deletes
Exterior Modifications (Daily driver so these mods are easy and cheap to replace)
- JNA V-limited polyurethane lip
- 18x10" Enkei RPF1 +38mm, painted matte black by IAG
- Front and Rear fenders rolled and pulled by IAG
- 3mm MotorsportTech custom spacer in the front
- 265/35/18 Michelin Sport A/S Plus --> 285/30/18 --> 295/30/18
- Lamin-X Taillight overlays
- Plastdip'ed Silver mustache
- Daytime running lights deleted
- 20% tint
Suspension
- 2015 STi 13.0:1 Steering Rack retrofit
- SuperPro Steering Rack bushings
- Cusco Steering Brace
- Tein Street Flex 9K/7K Coilovers
- Racecomp Engineering 25.5mm hollow Front and Rear Sway Bars
- Kartboy Endlinks
- Whiteline Roll Center Adjustment/Bump Steer Kit
- Whiteline V2 Anti-Lift Kit
- Aligned to -2.5F/-2.3R; 0 toe; +6.95 caster
- Project Mu B-Force front brake pads, Stoptech rear brake pads
- Girodisc front and rear rotors
Drivetrain
- ACT XT Sprung 6 Puck; OEM Flywheel
- GroupN Engine Mounts
- GroupN Transmission Mount
- Whiteline Positive Shift Kit
- Whiteline Subframe Inserts
- Whiteline Rear Differential Inserts
- Kartboy Front Shifter Bushing
- Kartboy Pitch Stop
- Kartboy Shortshifter
- Driveshaft Shop carbon fiber driveshaft
http://www.youtube.com/v/kZn95fBXjSA
http://www.youtube.com/v/etp5PtF_cT8
http://www.youtube.com/v/oHv9wSyoWDc <--Corsa exhaust new as of 7/2014.
Credits to Boris at IAG for these spectacular images!
IAG Stage V heads (credits to Crystal_ImprezaV)
fuckin surgical welds
IAG Built| HTA86| &gt;500whp| Daily driven for 135,000 miles-dsc01795finalresize-png
user1029 is offline
Likes 19 Dislikes 0
Old 07-04-09, 01:44 PM   #2
user1029
Fav Mod: HTA86.
Default Re: 2008 wrb sti
Ran the setup below: IAG Stage 2 block at >500whp 26-30psi for 3 years (1/2013-2/2016) with minimal oil burn/slap and minimal power loss; oil analyses posted below
IAG Stage 2 block
- Manley Platinum Series 99.75mm Piston Set
- Manley H-Beam Rods
- OEM 11mm Oil Pump
- Killer B Oil Pickup with Baffle
IAG Stage V Heads
- ARP2000 Head Studs
- OEM Headgasket
- Kelford Dual AVCS 272/268 11.30/11.50mm Lift Street Cams
- IAG TGV Deletes
Stock STi = 225whp on IAG dynojet
GT35R (not HTA86) comparisons/videos below
Dyno graph comparison (stock heads vs. IAG built heads, 272s) to illustrate how much IAG Stage V heads flow; no confounding variables because boost was kept the same as well as the turbo and all other parts of my setup.
speedo at 500whp with GT35R (not HTA86)
http://www.youtube.com/v/OL8rd_ifKoU
user1029 is offline
Likes 5 Dislikes 0
Old 07-04-09, 01:45 PM   #3
user1029
Fav Mod: HTA86.
Ran the GT35R setup on the stock block from 15,000 miles to 60,000 miles (11/2009 - 1/2013) with perfect compression, visually PERFECT pistons on teardown, and no oil consumption
Performance (IAG V-band rotated turbo kit: My review/impressions: NASIOC - View Single Post - IAG Performance)
- Stock Long Block
- GT35R 0.82 Tial V-band housing
- IAG 3" Intake
- IAG V-band Uppipe
- Harman Motive Catback Exhaust
- Aquamist HFS-6 running Boost Juice (50% methanol/50% water; tincture of meth to suppress detonation and gain some chunky midrange)
- Deatschwerks 1000cc Injectors
- Walbro 255lph Fuel Pump
- Tial Q BOV
- IAG Catchcan
- Cobb Accessport protuned by Jorge
IAG Stage 2 Bottom End (built and ready to be swapped when stock motor fails)
- Manley Platinum Series 99.5mm Piston Set
- 12000mile/1year warranty
IAG Stage V Heads (built and ready to be swapped when stock motor fails)
- ARP Head Studs
Exterior Modifications (Daily driver so these mods are easy and cheap to replace )
- 18x9 Gunmetal Rota G-forces +30 offset
- 30% tint
Suspension
- Kartboy Endlinks
- Whiteline Steering Rack Bushings
Drivetrain
- ACT XTSS Clutch; OEM Flywheel
93 octane (Blue) on 11/2009, Meth (Red) on 2/2011
(stock STi's dyno 225whp/wtq; Stage 2 STi's dyno 280whp)
Bought the car for $28,700 on 11/2008 (0% financing for 63 months + $7000 off of the deal of century in the winter of 2008). Went stage 1 at 300 miles, stage 2 at 1000 miles, protuned stage 2 at 5,000 miles...then the rest is history
user1029 is offline
Likes 7 Dislikes 0
Old 07-04-09, 11:05 PM   #4
zxc954315
Active Participant
Car: White 08 WRX STi
zxc954315 is an unknown quantity at this point
Default Re: 2008 World Rally Blue STI - keepin' it simple
how much is ur rota g-force? and where u get it?
thank u
zxc954315 is offline
Old 07-05-09, 07:41 AM   #5
user1029
Fav Mod: HTA86.
thank u
$900 shipped from wheeldude.com
user1029 is offline
Likes 1 Dislikes 0
Old 07-08-09, 05:23 PM   #6
yohan7
Advanced Contributor Level 5
Feedback Score: 2 reviews
yohan7 is an unknown quantity at this point
I see your car quite often around xxxxxx road. Looks clean bro.
yohan7 is offline
Old 07-08-09, 05:31 PM   #7
mzj24
Advanced Contributor Level 1
Car: 08 Subaru WRX STI
Fav Mod: Racing baby seat!
mzj24 is on a distinguished road
You my friend SLAMMED that thing! It looks great!
To often, we lose sight of lifes simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only takes 4 muscles to extend your arm and slap that mother.... upside the head.
mzj24 is offline
Old 07-08-09, 05:44 PM   #8
user1029
Fav Mod: HTA86.
Thanks
What car were you in? I'll wave next time hah
user1029 is offline
Old 07-08-09, 05:48 PM   #9
user1029
Fav Mod: HTA86.
Form over function
user1029 is offline
Old 07-08-09, 06:01 PM   #10
mzj24
Are you on the stock rubber?
mzj24 is offline
