Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Members' Journals
Old 07-02-2009, 06:31 AM   #81
Feedback Score: 1 reviews
IWSTI Addict since: Dec 2008
Default Re: hokie_sti's 2008 SSM STI Journal - Orange BBS wheels INSTALLED!
Originally Posted by GTsolutions View Post
my paint faded. I am probably just going to get some overlays or something. Matt_H cleared his and still faded as well.
Doh! Did you use Krylon Stained Glass spray paint or the Testors Enamel?
hokie_sti is offline   Reply With Quote
Old 07-02-2009, 09:49 AM   #82
I'm going to give this UV-resistant clear coat a shot. It says it protects against fading:
Krylon: Products: UV-Resistant Clear
Old 07-03-2009, 06:09 AM   #83
I had some time last night so I painted the tails. I'm really happy with the way they turned out. I used a bunch of coats of UV resistant clear coat, so I'm hoping it will prevent fading.
Supplies used:
- 1 can of Krylon Stained Glass spray paint
- 1 can of Krylon UV Resistant clear coat
- 1 exacto knife
- painters tape
Results:
Old 07-04-2009, 06:50 AM   #84
Car: 06 WRB STI
Fav Mod: EFI Logics protune
IWSTI Addict since: Mar 2006
Send a message via AIM to ebo03
Default Re: hokie_sti's 2008 SSM STI Journal - Painted Tails INSTALLED!
Tails look good. Hope they hold up to the sun and don't fade.
ebo03 is offline   Reply With Quote
Old 07-05-2009, 05:14 AM   #85
Car: SSM 09 Impreza STI
IWSTI Addict since: Jul 2009
With the older BBS wheels did you have to use a spacer or they cleared the brembos just fine? Also do you have some close up pics around the calipers. Thanks.
blackrussianSTI is offline   Reply With Quote
Old 07-05-2009, 05:37 AM   #86
They clear without spacer. It should be the same brake clearance as any '05-'07 STi as I believe the brakes are very similar, if not the same, as previous generation STis. I will see if I can dig up some pics for you.
Edit:
These are the best I could find right now. I can snap some more this coming week.
Old 07-06-2009, 07:54 AM   #87
My StuffSubaru Parts
Fav Mod: The turbo inlet that was a b to put on and was taken off 3 weeks later
IWSTI Addict since: Jul 2008
Tail lights look good man. Look forward to seeing how they hold up.
gaguilarsti is offline   Reply With Quote
Old 07-21-2009, 04:46 AM   #88
Some MAIC members (sti robot and RandomRacing on NASIOC) took some pics of my car at autocross last weekend. Thanks guys, they came out really well!
Old 07-21-2009, 07:02 AM   #89
Feedback Score: 2 reviews
Fav Mod: gf shotgun :)
i think i used krylon. I got it from micheals.
they look good agian although darker red since I couldn't get the faded layer off so i just sprayed over it. Im not planning to pwn car shows so i don't care.
tails look good man
TrkWhre is offline   Reply With Quote
Old 07-28-2009, 01:35 PM   #90
I bought some used tire totes and wheel felts locally. Hopefully these will protect the tires from the sun. They certainly make it really easy to carry wheels/tires around.
Before:
After:
Not very exciting, but I was bored and felt like posting something.
The 225/50/17 Michelin Alpin PA3s (winter tires) stack slightly higher than the 245/40/18 stock Dunlop SP600s.
Privacy Policy
