LED trunk light install - Subaru Impreza WRX STI Forums: IWSTI.com
STI Products
Membership Benefits Advertise FAQ Members List Contact
Go Back   STI Forums > GR Series STi Discussion (2008+) > GR-Interior > LED trunk light install
Old 04-07-11, 07:07 PM   #1
Advanced Contributor Level 5
Feedback Score: 1 reviews
Fav Mod: To Date: COBB SF Intake / GTSPEC D Shaped Steering Wheel
My: Subaru Parts for sale
STiEZY is an unknown quantity at this point
Default LED trunk light install
I got this idea from asukadc and ordered the exact parts he did from zestjdm.
Gotta give credit where it is due.
Original thread:trunk LED light solution, GR hatch DIY
Ordered the wiring harness, 3 led strips, 2 strip connectors, and the 12 LED plate to replace the stock light.
Note: i removed the cargo net hook because I was going to attempt to pull the lower section away too. You can just thread the wire through the hole for the light and grab it.
Stock trunk light is horrible and doesn't light the trunk at all.
Remove the two screws, at the location for the cargo cover, holding the panel
Here are the components of the LED trunk lighting from Zestjdm
Pop the stock trunk light out using a flathead screwdriver. Pry from the right side of the light. Also pull the panel away starting at the left near the second screw, there are hole clips, so just pull till they release.
Pull out the stock bulb and insert the end of the wiring harness that replaces the bulb. If you do not buy the replacement LED panel, there will not be anything spliced into the wires
If you look behind the panel, you can feed the end of the wire to your hand and take it to were you want to run the lights. I ran it up to were asukadc did.
Center the lights, pull the cover off the tap, and apply. I centered the middle strip around the centered headliner clip and fastened to the plastic. Asukadc applied on the headliner.
Clean up the excess wire. I used the twist tie that hold the wiring harness originally.
Push the wire through the hole and reinstall the light
Reinstall the screw fastening the panel and you're done! Finished the install extremely fast, 15 minutes max. Here are some pics in the dark.
http://www.iwsti.com/forums/gr-membe...installed.html
STiEZY is offline   Reply With Quote
Old 04-07-11, 07:16 PM   #2
Wes
I'm Jim Halpert
Feedback Score: 9 reviews
Wes is on a distinguished road
Default Re: LED trunk light install
wow... thats pretty bright! Nice job!
Wes is offline   Reply With Quote
Old 04-07-11, 07:40 PM   #3
Feedback Score: 2 reviews
Car: 2010SPW STi BBS/Navi
Fav Mod: Pro-tuned by YimiSport
asukadc is an unknown quantity at this point
good job dude, now we have the same kit rolling around, show up to meets and and pop the trunk
asukadc is offline   Reply With Quote
Old 04-07-11, 07:45 PM   #4
For sure, that's the first thing I want to show!
Old 04-07-11, 08:28 PM   #5
Fav Mod: BC coilovers
GotSTI? is an unknown quantity at this point
15 minutes? That's nuts. I like it.
2011 SWP STI Sedan / Turbo back Invidia Exhaust (dual tip Q300) / Invidia catless downpipe / K&N drop in air filter / triple A pillar gauges (A/F, boost, oil pressure) / Hella tone horns / Bayson R front lip / usdm foglights added / 38% tint / rally armor mud flaps / HT Auto front grill / Hankook 265/35ZR18 Ventus R-S3 tires, Gold Rota DPT wheels 18 x 19.5 / Blox Lugnuts / BC Racing Coilovers / Perrin sways 24F, 22R / Stage 2 / EFI tuned 280 whp / 330 wtq
GotSTI? is offline   Reply With Quote
Old 04-07-11, 08:52 PM   #6
If that!
Old 04-08-11, 07:58 AM   #7
Advanced Contributor Level 4
Car: 08 DGM/BBS
fishingfiend is an unknown quantity at this point
Thanks for sharing! Any thoughts on adding a switch so you can control the light strip separately? Sometimes lighting up the entire trunk area is not such a great idea...
fishingfiend is offline   Reply With Quote
Old 04-08-11, 08:04 AM   #8
Advanced Contributor Level 2
Car: 2011 SWP STI Hatch
Fav Mod: TWM Short Shifter
cooldude117 is an unknown quantity at this point
Isn't there a switch right on the factory light that will do that?
cooldude117 is offline   Reply With Quote
Old 04-08-11, 08:06 AM   #9
Car: 08 DGM/BBS
My factory light is hidden behind an AI enclosure with a 10" sub. This is why I'm looking for some options. I'm thinking that adding a simple toggle switch or something should work. Added to my project list.
Old 04-08-11, 09:44 AM   #10
I'm sure there is some sort of online switch you could do right were the wiring comes out of the panel. Pm zestjdm and see what they say.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Privacy Policy
