Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-General
Old 02-08-2010, 12:12 PM   #1
Feedback Score: 1 reviews
Car: 2008 WRX STi
Fav Mod: Hannah Montana Stickers
IWSTI Addict since: Feb 2008
Default Cobb Stage 2, 91oct, v1.04 Over-boosting?
I have been using the Cobb Stage 2 map for the past 17,000 miles - through various revisions. Although I've never spent much time concerning myself with boost levels, the few times I hooked up the AP as a monitor I would see the boost at 18psi (which might have been the limit of the AP at the previous map version 1.03?).
This week, I updated to the most recent firmware, flashed with Stage 2, 91oct, v1.04 and did some data logging. I think I'm over-boosting as my data logs show a max 19.8 psi, slightly above the specified 19.3 (18.5+/- .8) but no knock. Outside temps were around 10F.
Until I get some feedback, I'm running the Stage 2, 91oct, LWG v1.04 map but it certainly does not feel as fast, and not nearly as smooth. Boost is peaking within tolerances at 18.2, and no knock.
Three Questions:
1. Is 19.8 psi abnormal, or safe?
2. Can anyone explain how the LWG map works? Cobb lists the power gains on their website to be the same between Stage 2, and Stage 2 LWG.
3. Has anyone else noticed any negative nuances with the Stage 2 91, v1.04 LWG map?
Current Mods:
Cobb AP
Invidia Catted Downpipe
Magnaflow Catback Exhaust
djrossco is offline   Reply With Quote
Old 02-08-2010, 12:17 PM   #2
Feedback Score: 7 reviews
Car: 2010 SS STI
My StuffSubaru Parts
Fav Mod: Back-seat Shih tzu
IWSTI Addict since: Nov 2008
Default Re: Cobb Stage 2, 91oct, v1.04 Over-boosting?
That sounds normal to me. Personally "I" wouldn't run an OTS Stage 2 tune, as there are more variables than just the Stage 1, but that's just me. When I got protuned on my 08, I was hitting 20.7 PSI, so if you're hitting 19.8, you're fine. How are your AFRs? Temperature will also play into some of that, as well. I do remember running the OTS Stage 2 for a few days, and yes it was a little higher than Cobb's numbers, and it was just fine.
WilliamG is offline   Reply With Quote
Old 02-08-2010, 01:23 PM   #3
Car: 08 REAL WHITE
Fav Mod: BBS
IWSTI Addict since: Aug 2006
I'm sure it has to do with it being 10 degrees outside.
mxer is offline   Reply With Quote
Old 02-08-2010, 02:06 PM   #4
Car: 2008 WRX STi
AFR is 11.04
Here's a copy of a datalog today:
RPM (RPM),Calculated Load (g/rev),Ignition Adv. (°),Knock Correction (°),Knock Learning (°),Throttle Position (%),Accel. Position (%),Boost (PSI),Wastegate Duty (%),Air/Fuel Ratio (AFR),Inj. Duty Cycle (%),MAF Voltage (V),Fuel Trim (Long) (%)
3013,1.86,17.00,0.00,0.00,99.96,99.96,2.18,54.49,1 8.51,29.83,3.4,0.00
3137,2.38,10.50,0.00,0.00,99.96,99.96,6.82,57.23,1 3.23,43.37,3.70,0.00
3300,3.42,9.00,0.00,0.00,99.96,99.96,14.65,57.23,1 1.04,70.11,4.06,0.00
3580,3.89,9.00,0.00,0.00,99.96,99.96,19.58,49.78,1 1.04,74.66,4.26,0.00
3750,3.87,9.50,0.00,0.00,99.96,99.96,19.14,49.78,1 1.04,78.27,4.28,0.00
3955,3.76,10.00,0.00,0.00,99.96,99.96,18.85,50.18, 11.04,80.45,4.34,0.00
4150,3.72,10.00,0.00,0.00,99.96,99.96,18.42,50.96, 11.04,84.50,4.38,0.00
4362,3.75,10.00,0.00,0.00,99.96,87.02,18.42,51.74, 11.04,88.42,4.44,0.00
4571,3.72,11.00,0.00,0.00,99.96,71.74,18.42,58.80, 11.04,91.97,4.50,0.00
4727,3.71,11.50,0.00,0.00,99.96,71.74,18.13,64.68, 11.04,95.68,4.54,0.00
4953,3.64,11.50,0.00,0.00,99.96,79.18,17.55,72.52, 11.04,98.55,4.58,0.00
5117,3.54,11.50,0.00,0.00,99.96,99.96,17.11,79.18, 11.04,98.96,4.60,0.00
5276,3.46,12.00,0.00,0.00,99.96,99.96,16.53,82.71, 11.04,101.07,4.58,0.0
5400,3.38,12.50,0.00,0.00,99.96,99.96,15.95,83.10, 11.04,101.36,4.56,0.0
5580,3.30,13.00,0.00,0.00,99.96,99.96,15.66,83.50, 11.04,103.83,4.58,0.0
5666,3.24,13.50,0.00,0.00,99.96,99.96,15.23,83.50, 11.04,103.18,4.62,0.0
5848,3.16,14.50,0.00,0.00,47.43,0.00,14.94,0.00,11 .04,83.80,4.38,0.00
5278,0.14,0.00,0.00,0.00,9.80,0.00,-8.27,0.00,11.85,0.00,1.86,-0.78
4730,0.18,0.00,0.00,0.00,9.41,0.00,-9.86,0.00,14.49,0.00,1.88,-0.78
4141,0.21,0.00,0.00,0.00,9.02,0.00,-9.72,0.00,20.47,0.00,1.86,-0.78
Old 02-08-2010, 06:29 PM   #5
Fav Mod: Future 2010 STI Owner :)
IWSTI Addict since: Dec 2007
Have you tried the LWG map?
chmura is offline   Reply With Quote
Old 02-08-2010, 06:51 PM   #6
Car: 2010 SS STI
Originally Posted by djrossco View Post
AFR is 11.04
Sounds like an OTS map! Running a tad rich, but fine for an OTS map. The rest of the numbers are gibberish to me.
Old 02-08-2010, 09:38 PM   #7
Car: DGM 09 WRX STI
IWSTI Addict since: Sep 2009
Both the LWG and non-LWG maps should put out the same power, as long as they're being run properly. If you're running the non-LWG map and overboosting, sure it'll feel faster until the ECU shuts you down with a code. But that means the map isn't right for the car and is asking too much.
Both maps will make the same power at the same PSI. It's just you need to figure out which is better for you to make that PSI and not overboost.
Sabrewings is offline   Reply With Quote
Old 02-08-2010, 09:52 PM   #8
Car: 2008 WRX STi
I understand the rationale that more boost = more power. Even though I'm beyond spec - I have never thrown a code for over boosting. I've been more or less curious about the seriousness of running slightly high on specs from Cobb and trying to understand how the LWG map works.
Thanks WilliamG: It's reassuring to hear that I'm on the rich side of things while under power.
Old 02-08-2010, 09:58 PM   #9
Car: DGM 09 WRX STI
The LWG maps simply have lower WGDCs so the turbo boosts lower. Everything else should be pretty much the same.
Old 02-09-2010, 12:45 PM   #10
Car: 2009 DGM STi
Fav Mod: Hella Horns
IWSTI Addict since: Jan 2009
My wideband reads that I am in the 10s, can that be right with 1.04?
dkohn1337 is offline   Reply With Quote
Similar Threads
Cobb AP & stage 1 ? tportela ECU Tuning & Performance Electronics 19 07-07-2009 05:26 PM
COBB Stage II boosting to 22PSI in 6th. anshugiri@yahoo.com ECU Tuning & Performance Electronics 23 12-20-2008 11:19 AM
Cobb Stage 1 STI Suspension Package Sway Bars Kartboy Endlinks CMoore711 Brakes / Suspension / Stiffening 4 10-19-2008 08:27 PM
Cobb AP2 Stage 1 STI2envy ECU Tuning & Performance Electronics 21 12-19-2007 10:24 AM
Another 20G thread, compare the spool with Cobb Stage 2. treefolk 2.5 Liter/Litre Factory Motor 3 11-04-2007 04:54 PM
Privacy Policy
