Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Exterior
Old 05-21-2009, 09:40 PM   #1
Car: 08 DGM STI
My StuffSubaru Parts
Fav Mod: HKS Legamax
IWSTI Addict since: Apr 2009
Default Strange Turn Signal Electrical Problem
Hi everyone. So I recently purchased an 08 STI from a forum member here.
I noticed a very strange electrical issue. When I have the right turn signal on WHILE my head lights are on the blinker blink really fast.
When the headlights are off, the turn blinker blinks at a normal speed.
This ONLY happens when the head lights are on and ONLY on the right side.
Thoughts on how to find the problem?
xjohnnyleex is offline   Reply With Quote
Old 05-22-2009, 07:25 AM   #2
Feedback Score: 1 reviews
Fav Mod: 18x9.5 w/ 275/35-18
IWSTI Addict since: Apr 2005
Default Re: Strange Turn Signal Electrical Problem
This came up fairly recently. There is a problem with the turn signal socket itself in the headlight. Take it to the dealer and explain. They should be able to get you a new one and fix it. It is not a bad bulb.
Chayse is offline   Reply With Quote
Old 05-22-2009, 10:15 AM   #3
Car: 08 DGM STI
Turns out it was a malfunctioning bulb.
It still lit up though. Weird.
Dealer replaced it under warranty. Thanks!
Old 05-22-2009, 03:36 PM   #4
I had the same problem. I replaced the bulb three times myself. It would fix the issue for a couple of weeks and then it would reappear. A couple of times, it started having problems and then stopped a week later. It wasn't the bulb for me. Keep an eye on it.
Old 05-22-2009, 04:22 PM   #5
Car: 08 DGM STI
Thanks. Will keep an eye on it.
Old 05-22-2009, 05:52 PM   #6
Car: LR 08 STI
Fav Mod: Black Ultraleggeras
IWSTI Addict since: Feb 2008
Crazy, just had this happen to me for the first time yesterday. I didn't notice if it was headlight related, though I did have them on yesterday. I'll have to check that out. It was also only the right side for me.
LtningRed08 is offline   Reply With Quote
Old 05-22-2009, 06:00 PM   #7
Car: 08 DGM STI
Keep us posted to see if it is the same problem as mine!
Old 05-26-2009, 06:16 AM   #8
Car: 08 STi
Fav Mod: Stage 2 or bust!
IWSTI Addict since: Jan 2009
This was the same thing that happened to the Motortrend test mule... fast blinking turn signal lights..
TexRyker is offline   Reply With Quote
Old 05-27-2009, 03:18 PM   #9
Feedback Score: 3 reviews
Car: Silver 08 WRX STI
IWSTI Addict since: Apr 2008
Send a message via AIM to Andy
Happened to me too. It's not the bulb because the issue went away on its own when I was about to replace the bulb.
The bulb will light up very dim, which lowers the resistance on the circuit, which makes it flash faster.
Andy is offline   Reply With Quote
Old 06-26-2009, 02:58 PM   #10
Car: LR 08 STI
My right signal would blink fast sometimes, then it started doing it all the time, with headlights on and off. I decided to see if it was a bulb issue by switching the left and right bulbs, to see if the problem followed the bulb or stayed on the right side. First, I had to remove the battery and airbox to get to the blink bulbs.
To my great joy after I moved the battery out of the way and removed the airbox both blinkers began to work properly again. I decided to switch the bulbs anyway in case the problem happened again I could still see if it was related to the bulb if it happened on the left side rather than the right. Well, since I fiddled with it, both have been working normally... So I don't know what the problem was, but I guess its gone for now. Perhaps just a loose connection on the passenger side.
Similar Threads
Comprehensive Subaru CEL Code List (XLS File Attached) Muffnbluff 2.5 Liter/Litre Factory Motor 18 07-01-2009 03:25 PM
OBD-II Codes (CEL Light Codes) 201Motorsports 2.5 Liter/Litre Factory Motor 8 06-03-2009 03:19 PM
Right turn signal flips headlights on and off, wtf?? kris GR-Exterior 11 11-12-2008 02:17 PM
Front/Rear Turn Signal Bulb "sorta-mod" STI_carnatic GD-Exterior 4 02-16-2008 06:47 AM
dumb electrical problem jonp General 5 10-05-2004 09:00 AM
Privacy Policy
