Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Exterior
Old 10-27-2008, 05:11 PM   #11
Car: 08 STI
Fav Mod: Stuff
IWSTI Addict since: May 2006
Send a message via AIM to gibjer
Default Re: blue bat's tail light overlay
Well the link works, I have no clue what's up with the photobucket words, those magically appeared
gibjer is offline   Reply With Quote
Old 10-27-2008, 05:30 PM   #12
Unobtainium Member
Feedback Score: 7 reviews
My StuffSubaru Parts
Fav Mod: CG Lock
IWSTI Addict since: Jan 2008
Guys, I tinted the rear using Lamin-X and it was really easy. Honestly, I'm by no means a pro and the rears went on in about 20 minutes each side, max. I did the headlights and THOSE were very difficult but the rears were very simple. Just made sure I laid them out in the sun to get them as pliable as possible.
Just figured I would get another option out there since it seems quite a few on here had a tough time with the HM/Bat overlays.
Old 10-28-2008, 04:01 AM   #13
Car: Silver 08 STi
IWSTI Addict since: Mar 2008
i agree that lamin-x is easy to lay cause its a different and softer material to lay down then the blue bat.....but nonetheless both products are great....
the trick to the the blue bat it to work you way from the inside(being the most curvy part of the light) outwards....
just make sure you spray a light coat of water and soap mix on the lights before laying the vinyl....
once layed on, use a heat gun or hairdryer to heat the spot that needs to be stretch.....once streched use a credit card or hard edge to sqeeze some of the water out....
HINT:spray a little water and soap before using the credit card or hard edge to prevent scratching the layout
keep doing this a little at a time cause once the material cools down
CAUTION: dont let the heat gun or hairdryer sit to long on the same spot
pretty much just keep doing this til it stretched to the end....you'll barely have anything left to cut at the end.....and i did take the lights off the car before i started....
for the people that is afraid of screwing theirs up, just take it to a tint shop.....might cost you 30-50 bucks....
riggedSTI is offline   Reply With Quote
Old 10-28-2008, 09:44 AM   #14
Mo-de-ra-tor
Feedback Score: 17 reviews
Car: 06 WRB STI
Fav Mod: Advan RS
IWSTI Addict since: Mar 2006
Send a message via AIM to Ikon
looks good...
Old 10-28-2008, 09:58 AM   #15
Feedback Score: 8 reviews
Car: 08 AW STI - 10/31/08
Fav Mod: P & L 30r :)
IWSTI Addict since: Sep 2008
Looks good!
Got a question, how come on some fellow member's car, the overlay looks alittle bit darker red than some? Could it be the lighting of where they took the pics
combatp21 is offline   Reply With Quote
Old 10-29-2008, 02:57 PM   #16
Car: Silver 08 STi
it all depends on the company you get it from.....i think the thicker the material the deeper the red it is....
Old 10-30-2008, 11:45 AM   #17
Car: Red 2008 STi
Fav Mod: 1L Rockstar
IWSTI Addict since: Aug 2008
I used Lamin-x one sides looks ok the otherside has too many bubbles in it, like guy said earlier from far away looks good, close not soo much, i only did the outside ones gonna do the inside ones tonight
Red08onGOLD is offline   Reply With Quote
Old 10-30-2008, 11:49 AM   #18
Fav Mod: Maddad Whisper
IWSTI Addict since: Dec 2006
Send a message via AIM to topend Send a message via Yahoo to topend
Looks good
topend is offline   Reply With Quote
Old 10-30-2008, 02:19 PM   #19
Car: Silver 08 STi
for the bubble you might be able to heat the material a little to soften the adhesive a either be able to run the bubble out w/ a plastic card or stretch the material til the bubble is out.....
Old 10-30-2008, 03:25 PM   #20
Feedback Score: 2 reviews
Car: 08 White STI
IWSTI Addict since: Mar 2004
Send a message via AIM to Chiznarles
nice job man.. looks clean.
I've always thought that this overlay looks like the Maserati Gran Turismo:
Chiznarles is offline   Reply With Quote
Privacy Policy
