Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Exterior
Old 12-17-2008, 11:02 PM   #41
Fav Mod: COBB AccessPORT
IWSTI Addict since: Mar 2008
Default Re: Adjusting headlights?
I adjusted mine when I was low on gas, and now that I filled up I think I may be aimed a bit high. :\
That's perfect. You want them to be slightly high. Just adjust the headlight dial on the left hand side to the steering wheel onto a lower setting.
For example: If your lights are on setting 1, and they seem a bit high, change the setting to 3 or 4, and they should be much better/lower.
Wronks is online now   Reply With Quote
Old 12-18-2008, 03:30 AM   #42
Feedback Score: 1 reviews
Car: 08 DGM STi
My StuffSubaru Parts
Fav Mod: Seat time
IWSTI Addict since: Jan 2008
Originally Posted by ChazzMichaelMichaels View Post
I read the "warning" regarding putting the air intake back on. Is there even a way to put it on wrong? I just slid the box back in and it seemed fine.
me too -- the first time. when i went back and re-did it using the tape-on-the-wall method to be sure i did it right it gave me fits on getting the square plug into the square hole. that's why i put the caution. you can end up with the plastic rivets back in place but the snorkle not really seated into the breather box completely.
as for adjusting them... that's why i adjusted them to be right when the dial is on 2. that gives you options to adjust your beams up and down depending on the load in the car, if you're out on the open road, and if you sitting behind someone in traffic.
Old 12-18-2008, 03:39 AM   #43
Feedback Score: 2 reviews
IWSTI Addict since: Nov 2008
When I replaced my snorkel, I wasn't sure if the outter edge of the snorkel (the side closest to the passenger side fender) was supposed to slip under or over the metal protrusion of the fender. This might be hard to explain without pictures but it's too cold to go out and do it now. In any case, I don't think anything's wrong.
For adjusting the lights, I didn't do the 25' method because I didn't want to wait until night time AND find a place that I'll have a 25' minimum distance from a wall AND be level at the same time.
What I did was I knew I was pretty satisfied with the level of the light output when the switch was set at 0 from the factory. That level really is too low for 0. The cutoff would just clear a standard sedan's rear bumper.
With that in mind, I flipped on my lights and put pieces of tape on my garage door where the cutoff was. I then adjusted the lights to that level (a tad bit higher, actually) at the 3 setting.
This is a suggestion to anyone else if you're satisfied with what you see at 0 or any other number but just want the light to be that level at a different position. It certainly saves the trouble of finding the "perfect" location to do this.
Mugen Power is offline   Reply With Quote
Old 12-23-2008, 01:03 PM   #44
Feedback Score: 5 reviews
IWSTI Addict since: Aug 2005
just got done with my headlight adjustment. Took me all of 15 minutes to do. Man they were way low from the factory. I also used the 25" at 25 feet method and put the beams just below the tape line on the garage door on the #2 setting. Now I have some "Wiggle room"
Old 05-23-2009, 12:45 AM   #45
Car: 2009 WRX
Fav Mod: AccessPort
IWSTI Addict since: May 2009
I do the look test. Find a nice level dark road. Adjust my lights, then walk out in front of the car a good distance, and sort of squat down a bit to simulate the average small car with 5'4" driver. And adjust the lights to a couple inches below getting blinded. This way bumps in the road will let drivers know that I don't have my brights on but still sit low enough so they don't get blinded. Just gotta make sure to check both lanes to make sure your not blinding people your following too.
Found this to be the best way to get the max height that won't blind people.
Oh speaking of which.. I replaced my stock low beams from H11s to H9s. Now with these and being adjusted properly I can say this: These lights are now adequately bright for night time driving. Also, they are now as bright as they should have been from the factory. Best $34 I spent on the car so far.
I am going to order some HIRs now for the high beams. They are adequte for sub 55mph rural roads. But gonna need some HIRs or something for 70mph runs for me to feel animal friendlier.
Last edited by HellTriX; 05-23-2009 at 12:45 AM.. Reason: Btw. This was done to my brand new 2009 WRX hatchback.
HellTriX is offline   Reply With Quote
Old 07-21-2009, 10:42 AM   #46
Car: 08 STI, 02 WRX Wagon
Fav Mod: 02 WRX: Tokico D-specs with RCE wagon springs
IWSTI Addict since: Oct 2008
Old thread but I wanted to say thanks, I've been putting this off because the adjustment isn't immediately obvious and I haven't been able to find a proper service manual online for the 08. The stock level is just too low when the car isn't loaded down-- it's almost dangerous! Just adjusted the level 2 setting to the same as level 0 set from the factory, hopefully it'll work out properly (did it at mid-day so I haven't been able to check yet, at worst it'll still be better than it was). I understand why Subaru did it, too many idiots who only care about blasting the road with light so they can see (mostly driving Ford Excursions, I've noticed ), but I'm intelligent and considerate enough not to blind other drivers.
Regarding the air intake snorkel, I was careful enough to get it back into the seat before noticing that caution, but I can see where it would be an issue if you were just quickly getting things back together. It doesn't naturally just fall into place, you kinda have to work it at just the right angle.
jprowland is offline   Reply With Quote
Old 07-21-2009, 10:54 AM   #47
Feedback Score: 3 reviews
Car: 09 SSM STI
Fav Mod: AP
IWSTI Addict since: Mar 2004
I did this as well..... its nice to drive without my sonar on
traction is offline   Reply With Quote
Old 08-26-2009, 09:08 AM   #48
Car: S.Pearl Wht 07 STI
Fav Mod: All of them
Originally Posted by Suberman View Post
Do the highbeam lights align together with the lowbeam lights?
Yes they do align together. The H.Lamps have a motor that adjust them both as you move it through 0-3 settings
STi Str8 Beast is offline   Reply With Quote
Old 08-26-2009, 10:44 AM   #49
Car: 08 lightning red sti
Fav Mod: Your mom
cheapest and easiest mod I have done to my car, also one of my favs! (does it even count as a mod? )
Barrok is offline   Reply With Quote
Privacy Policy
