Go Back   IWSTI.com: Subaru WRX STI Forums > GR Series STi Discussion (2008+) > GR-Technical > GR-Exterior
Old 11-26-2008, 06:19 PM   #21
Car: 08 STI, 05 Legacy
Fav Mod: dirt, grime and brake dust
IWSTI Addict since: Feb 2008
Default Re: Adjusting headlights?
Originally Posted by PSUbaru View Post
bringing this back from the depths... I got the driver side light adjusted in a few seconds but the passenger side, that's a toughy. I can't get my ratchet to go in between the air box and the bolt. I'm gonna try tomorrow when it's lighter out but any suggestions to make this easier short of taking out the air box?
It's easy to take off the airbox. Take it off and make it easy on yourself.
Edvig is offline   Reply With Quote
Old 11-26-2008, 06:26 PM   #22
Fav Mod: COBB AccessPORT
IWSTI Addict since: Mar 2008
It's very very easy. I believe it's only two screws, if I'm not mistaken.
Wronks is offline   Reply With Quote
Old 11-26-2008, 06:47 PM   #23
Feedback Score: 1 reviews
Car: Aspen White 08 STi
IWSTI Addict since: Aug 2008
oh, ok thanks guys, i'll try this tomorrow when it's light
PSUbaru is offline   Reply With Quote
Old 11-27-2008, 07:58 AM   #24
Car: 08 DGM STi
My StuffSubaru Parts
Fav Mod: Seat time
IWSTI Addict since: Jan 2008
I recommend you skip using a screw driver. The head of the bolt is plastic and is very easily stripped out. Use an open-ended wrench if that's all you have. It takes longer but the adjusting bolt is less likely to get damaged.
Much better is a ratcheting box end wrench. Buy 1 now and add it to your tool kit that will last you the rest of your life. Buy a set and thank yourself for decades to come.
A quick google came up with these combo wrenched (metric is what you wants). Amazon.com: Gear Wrench 9900 7-Piece 10-Millimeter to 19-Millimeter Flex Ratcheting Box End and Open End Combination Wrench Set: Home Improvement i can't make a recommendation for them specifically, but they give you an idea of what I'm talking about.
and, yeah, remove the air box intake (as described) and it's much easier to access.
2008 Subaru WRX STi - HID Headlight Adjustment
Old 12-07-2008, 12:51 AM   #25
Do the highbeam lights align together with the lowbeam lights?
Suberman is offline   Reply With Quote
Old 12-07-2008, 09:12 AM   #26
Car: 08 DGM STi
Fav Mod: Seat time
Good question. I know that the low beams are HID and have their own capsules and reflectors; different needs than halogen bulbs and reflectors. I adjusted my HID low beams as described and the highs work okay without any individual changes. I'm of the opinion that the factory adjusts them excessively low so that the inconsiderate/clueless CAN'T use the height adjustment in the cabin to make them blind oncoming traffic. By adjusting them as described, I can crank them up nice and high when out on the open road and they work better than the high beams.
Check it out and let us know. I'll be happy to update the reference page and give proper credit.
Old 12-07-2008, 09:56 AM   #27
Car: Silver 08 WRX STi
Fav Mod: Perrin Sways & Endlinks
IWSTI Addict since: Apr 2008
I did mine 3 turns counter-clock-wise each. So far, nobody has flashed, they don't seem to bother oncoming cars and visibility is much improved over the craptastic stock setting.
EricGregory is offline   Reply With Quote
Old 12-08-2008, 04:45 PM   #28
Car: 08 OBP STi
Fav Mod: Alignment!
IWSTI Addict since: Mar 2006
What size wrench? 5mm?
dirty_aw is offline   Reply With Quote
Old 12-08-2008, 06:41 PM   #29
Car: 08 DGM STi
Fav Mod: Seat time
i dunno. it was dark out.
Old 12-08-2008, 08:15 PM   #30
Car: 08STI
Fav Mod: raising the headlights
IWSTI Addict since: Dec 2006
I dont get how a wrench is used, pics?
enterthedragon is offline   Reply With Quote
Privacy Policy
