Go Back   IWSTI.com: Subaru WRX STI Forums > IWSTI Engine & Drivetrain > 2.5 Liter/Litre Factory Motor > GR-Exhaust
Old 07-09-2009, 09:35 AM   #241
Car: blk 2008 wrx sti
IWSTI Addict since: Mar 2008
Default Re: Megan Exhaust Just Arrived!!!
Steye,
i have a perrin 1 piece downpipe. i first used the 3" flat gasket from my downpipe to the megan mid pipe but i had a huge leak and i could not tighten the bolts anymore.
So i took off the midpipe and noticed an imprint in one of the ends on the mid pipe that would seat the donut gasket. i tried that with the spring bolts and had no leaks so i figured that i was golden.
I should had taken pictures but the round end on the donut gasket goes into the megan midpipe and the flat end of the donut gasket goes onto the downpipe.
one other observation. on the midpipe, the end that connects to the downpipe looks to be 2.5" and the other side 3". can anymore confirm this? thanks in advance.
wooyoung is offline   Reply With Quote
Old 07-09-2009, 10:20 AM   #242
update,
i spoke to megan racing and they said to use the donut gasket if i'm using an aftermarket downpipe. i would only use a flat gasket if both ends were flat which the megan mid pipe end is somewhat rounded. I was also told their exhaust is made to marry up with an oem downpipe not aftermarket
Old 07-09-2009, 12:07 PM   #243
Feedback Score: 9 reviews
Car: '08 DGM STI
Fav Mod: So so STOCK!
IWSTI Addict since: Nov 2004
The end (closest to the DP) is similar to the stock midpipe connection. You should be able to use a flat flange or donut type gasket.
STEye is offline   Reply With Quote
Old 07-10-2009, 12:25 PM   #244
on the fence on putting back my oem exhaust.
anyone interested in my 2wk used megan black exhaust?
i'm thinking of selling it due to the following
mid pipe to aftermarket downpipe is 2.5 inches and made to fit oem downpipe. if it was a full 3 inches, it would fit better, IMO this exhaust would fit and work great with oem downpipe.
sound is nice but i do miss the quiet oem exhaust.
Old 07-10-2009, 12:27 PM   #245
sorry repost. can't figure out how to delete.
Old 07-10-2009, 12:45 PM   #246
Car: 08 STI
IWSTI Addict since: Jun 2009
I was told that the black megan exhaust is 3". Is it different piping than the titanium tipped one?
I have the black one mated to an invidia downpipe. I think I may have a leak at the dp/cbe joint location also.
STiLLawd is offline   Reply With Quote
Old 07-10-2009, 12:54 PM   #247
it's 2.5" from the front mid pipe to downpipe (for the donut gasket i'm guessing) , it's 3" from back mid pipe to the exhaust. i'll take pictures when i take it off.
STiLLawd, did you use a flat 3" gasket or their 2.5 " donut gasket that shipped with the exhaust?
Old 07-10-2009, 05:24 PM   #248
Car: '08 DGM STI
The CBE comes with a donut gasket? I am looking to mate this to a Invidia catted DP. The stock CBE fits quite well with the flat flange 3" gasket and straight bolts that came with the DP.
Old 07-10-2009, 07:17 PM   #249
Car: 08 STI
the little circle thing that came in the little white box? I used their two gaskets to mate the three pieces of the catback together. I then used the gasket that came with my invidia dp to mate the two sections together.
I checked and i have a HUGE exhaust leak where the cbe meets the dp. Its on the top portion of the joint. I am also using the bolts that came with the dp(the spring bolt setup has barely any thread if you install it the proper way...
I think the CBE is pointing up a little bit which doesnt allow the two surfaces tomate properly. Im not sure what to do... WAs thinking of using two 3" gaskets instead of one to move them apart and maybe seal it up. I guess ill have to contact megan about this also. I tried to re-adjust it today but it still wont seal properly.
Old 07-10-2009, 07:42 PM   #250
Car: '08 DGM STI
STiLLawd, take some pics if you can. The pictures of the exhaust on the megan website show a connection very similar to the stock CBE, which is why I am confused how it would mate differently.
Don't get me wrong, the stock CBE and Invidia connection aren't perfect. I had to sort of center the 2.5" CBE around the 3" DP connection then tighten it up. It wasn't a perfect connection (like as it would be with a 3" to 3"), but with aligning it up, it fit ok.
Similar Threads
NYS Vehicle and Traffic Law (375) - Exhaust Laws Majin Northeast 20 02-18-2010 01:57 AM
How-To: So you Got Yourself an Exhaust Ticket, now what? SUBIRU How-To / Install 33 12-06-2009 07:40 PM
WeSellCarParts.com // Perrin, Invidia, Megan Racing, DC Sports, AEM, Fujita & MORE! WeSellCarParts Engine/Power/Exhaust 265 06-20-2009 04:35 PM
Free APS Manifold Offer for Limited Time. Big APS Shipment with New Lower Pricing! RallySportDirect Engine/Power/Exhaust 31 05-12-2009 12:37 PM
Parting photographs of my S202/S203 STi Titanium Exhaust Nivek 2.5 Liter/Litre Factory Motor 20 09-23-2005 09:14 AM
Privacy Policy
