Subaru Impreza WRX STI Forums: IWSTI.com
Home  |  Register  |  Today's Posts  |  Go Premium  |  New Posts  | Mark Forums Read Create a Member Journal  |  Marketplace
Go Back   Subaru Impreza WRX STI Forums: IWSTI.com > GR Series STi Discussion (2008+) > GR-Technical > GR-Braking
Old 03-20-2010, 03:58 PM   #31
Feedback Score: 2 reviews
Blip's Avatar
Default Re: Alcon, Brembo or Stoptech BBK?
riddle me this batman, when did you every see an STI, run with F1 car, LMP, and just I saw a STI take the win at Bristol, But the AP's for WRC I bet I can put them on my car go 2 years in MI with out needing to rebuild the calipers all I would need is a set of street pads.
http://www.motorsportads.com/race-ca...ers/14648.html
08 D.Gray STI BBS/NAV
ETA Feb 29 08
"Advanced driving is advanced thought." - Perry "Stig" McCarthy
Blip is offline   Reply With Quote
Old 03-20-2010, 06:22 PM   #32
Feedback Score: 1 reviews
ANY caliper you push hard on track will eventually need rebuilt, street or "track" calipers. I've seen several track calipers used for street and track use and it only took 8 years for my buddy's set to start leaking. We just popped the pistons outc cleaned them up and installed new seals (non-dust boot caliper).
Heck, WE already drive with "track" calipers from the factory.
-Jason
yamahaSHO is offline   Reply With Quote
Old 03-20-2010, 06:26 PM   #33
7.62 mm, Hoorah!
sierra68's Avatar
Based on rep, I'm leaning toward Brembo 6 pots; based on price, I'm leaning toward Alcon, stuck in the middle is Stop Tech. My real problem is wheels - but that's a different thread I'll have to start. Thanks for all of the input and I'll post my purchase in the next 3 weeks. . .
sierra68 is offline   Reply With Quote
Old 03-20-2010, 06:47 PM   #34
uber STI enthusiast
Feedback Score: 4 reviews
Originally Posted by berdugo View Post
i'm glad to know you got Alcon from CVRMS
what size of bbk did you got? can you please post some pictures of it installed? thanks
I got the 365mm front, and 343mm rear set... FYI, you can NOT run the 365mm front set under stock wheels, they don't quite fit.
Check my other thread for all of the pictures of the Alcon kit being installed and the end results
Alcon Advantage Extreme BBK install with pics!
scoob r u is offline   Reply With Quote
Old 03-20-2010, 06:51 PM   #35
uber STI enthusiast
Originally Posted by Dunkinsti View Post
how do they perform? is there any other extra maintanance you have to do with these brakes?
Since the weather here in Chicago is still pretty crappy, I haven't really been able to push the new brakes very hard yet. They do feel a bit more stiff than stock (even comparing to my stock setup with stainless lines and ATE Super Blue).
The real advantage of getting a BBK isn't really increasing your stopping power so to speak. It is really designed to give less brake fade over extended periods of heavy use (track days or racing events). For any one just driving hard on the streets or doing occasional autocross, a BBK isn't really necessary. You can get away with a good set of stainless lines, pads and good rotors.
So far, the only thing I've had to do to keep them running well is to periodically clean them. They spit out a bit more brake dust than the stock kit. I just spray them with a high pressure hose, and a bit of brake cleaner. That seems to keep them running well.
Old 03-20-2010, 06:59 PM   #36
Blip's Avatar
Scoob How many track events a year do you do.
ETA Feb 29 08
Old 03-20-2010, 07:10 PM   #37
uber STI enthusiast
Look guys, I am SPONSORED by Alcon. There is no question that my view points are biased. HOWEVER, before I was sponsored, I met with the head of the North American branch of the company because I wanted to BUY them.
There are definitely other companies out there that make good or even great brakes. There are also companies out there whose products are complete ****. I'm not really interested in buying brakes that come in 1000 different colors to match my paint scheme. I'm also not interested in buying brakes from a company that sells racing brakes but will refuse to warranty your clearly defective set because you took your car on the track.
If you are interested in the actual PERFORMANCE (instead of hype) of a BBK, I will be posting data regarding the differences between a stock Brembo system and an Alcon BBK within the next month or two. We will be hooking up an accelerometer to a car with similar mods to mine that has a totally stock brake system and measuring g-forces during successive hard braking maneuvers to determine when brake fade starts to occur and how bad it is.
We will basically be taking the two vehicles up to 80mph and hard braking to 40mph repeatedly until both systems start to fade. To try to keep things on even ground, I will be running the same brake fluid and pad compounds on each car.
As soon as I have this data, I will be sure to post it in my other thread regarding the Alcon brake install and information.
Old 03-20-2010, 07:13 PM   #38
uber STI enthusiast
If anyone else is willing to participate in this test that has a different BBK, please PM me. I would love to be able to compare every brake kit on the market in the same fashion, but I don't exactly have the personal funds to do it ;0
Old 03-20-2010, 07:41 PM   #39
No Project-Mu love in here?
I'd still like to hear from the OP about how the brakes got stolen too... Wheels stolen, followed by brakes stolen?
Bullwings is offline   Reply With Quote
Old 03-20-2010, 09:55 PM   #40
Power Greedy
berdugo's Avatar
nice kits and pics you got there
it's great to see Alcon's 2 piece rotor for the rear bbk and retain the hand/parking brake. Alcon is the only bbk for the GD body that I saw with 2 piece rotor.
I have AP Racing rear bbk but the rotors are just 1 piece, good thing it retains the hand/parking brake, I wish AP made it 2 piece rotor like Alcon did.
my car is a rolling laboratory of setup and parts, always modding something because I'm whp greedy
power first, that is stopping power, then whp, handling is last on my priority
Similar Threads
Project Mu pads, KW Coilovers, Brembo BBK e-autosports Brakes/Suspensions/Stiffening 23 11-17-2008 12:03 PM
Stoptech vs Alcon BBK therealkaisersoze GD-Braking 17 07-18-2008 01:50 PM
BBK Specials!! Endless, Stoptech, Brembo & One Time Special Price on PFC 2pc Rotors!! CVR Motorsports Vendor Group Buys 135 03-18-2008 01:37 PM
Stop better in the wet with Stoptech, Project Mu, and Hawk! WorldONE Brakes/Suspensions/Stiffening 6 10-27-2006 09:52 PM
StopTech Brake Components from the unofficial StopTech Girl @ W1! WorldONE World One Performance 9 06-06-2006 05:06 PM
Powered by vBulletin® Version 3.8.6
Privacy Policy
