Subaru Impreza WRX STI Forums: IWSTI.com
Home  |  Register  |  Today's Posts  |  Go Premium  |  New Posts  | Mark Forums Read Create a Member Journal  |  Marketplace
Go Back   Subaru Impreza WRX STI Forums: IWSTI.com > GD Series STi Discussion (2003/4-2007) > GD-Technical > GD-Suspension, Handling, & Stiffening
Old 05-07-2008, 11:47 AM   #1
Feedback Score: 2 reviews
layza4sti's Avatar
Default 07 struts fit on 04 “well“
Ok, so I installed my rce black spring last week. I love them buy the way, but there was a small clunk in the rear. I also realized I for got to install my bump stops. So last night I decided to remove my struts again and install my bump stops and to grease the struts “hoping the clunk goes away”.
So the front went smooth no problem’s, but as my buddy and i got to the rear we ran in to a problem. The nut on the bottom of the strut was so rusty we some how over spun the nut and broke the strut canister in side the strut. I just so happened to have a set of 07 struts in my garage. So we decided to remove the strut canister and compare the 07 to the 04, we realized that it was about 1/2 inc. longer. We went a head and installed it into the 04 strut. Every thing seems fine. So in short I have 07 strut canisters in my 04 struts in the rear only. It drive’s fine and the clunk is gone. So what do you guy’s think should I keep it that way or go buy some new 04 struts?
04 STi Stage 2
http://www.vimeo.com/8767260
layza4sti is offline   Reply With Quote
Old 05-07-2008, 12:43 PM   #2
mgsm666's Avatar
Default Re: 07 struts fit on 04 “well“
02 through 07 the rear housings are the same. 04-07 STi's they are identical (i believe).
Your fine with the way you have it, assuming that you tightened everything down properly and installed the strut properly into the housing.
I'm about to use a set of wrx housings for my koni rear inserts
Jesse
I finally created a JOURNAL http://www.iwsti.com/forums/members-...-5-2-08-a.html
<< Now with pics of the RX-7 >>
mgsm666 is offline   Reply With Quote
Old 05-07-2008, 12:54 PM   #3
layza4sti's Avatar
Jesse
well not identical, the canister is about 1/2 inc. longer if that matters...
04 STi Stage 2
Old 05-08-2008, 02:37 PM   #4
layza4sti's Avatar
so does anyone have any input or info on this?????
04 STi Stage 2
Old 05-08-2008, 03:29 PM   #5
n00b
Feedback Score: 12 reviews
VSGTS14's Avatar
should be fine, iirc the 04 front is what is mainly different due to the hub.
Powered by vBulletin® Version 3.8.6
Privacy Policy
