| Professional STI Racer Feedback Score: 1 reviews
Car: 05 STi Fav Mod: ohlins w/RCE springs, sz55 Location: charleston Posts: 642
IWSTI Addict since: Nov 2005 | So here's the starting point with 75k hard well loved miles on it. . I have the suspension setup just how I like right now with: Ohlins fixed perch struts RCE yellow springs V2 PDE v2 camber plates groupn rear strut tops whiteline roll center adjusters whiteline race swaybars TiC Clunk killer kit race version With carbotech xp10's in front and 8 in the rear all on dba rotors Until about a month ago I was happy with the performance and then I realized that all that coolant I was pushing at the track was leading to no good. Read this thread: http://http://www.iwsti.com/forums/s...ad.php?t=95480 So then this had to happen: The heads and block checked out fine, even after all those miles of abuse, but I figured if I was going to pull the motor out to check the heads I might as well get a fresh block, and if I was doing all that I might as well get a little more power. That led to this: So I finally decided that the best setup for me right now is going to have include the following: Power: Stock block and heads w/ arp head studs Deadbolt sz55 w/ 3" inlet ewg and "fatboy" turbine (not pictured) Deatschwerks 850cc injectors grimmspeed TGV deletes coated grimmspeed 8mm phenolic spacers grimmspeed pnp oem headers and hf crosspipe w/ ceramic coating APS dr525 fmic APS turbo inlet APS 70mm cai turbosmart recirc bov UR upipe with tial 44mm wastegate Invidia N1 TBE w/ cat Prodrive 3 port boost solenoid AEM 50 psi map sesor and cobb adapter Accessport tuned by scott siegel Cooling: Koyo radiator Crawford water pump crucial racing 160 deg thermostat STi high pressure cap samco hoses Setrab oil cooler with thermostat maybe no a/c its a hard decision Drivetrain: act 6 puck group-n motor and trans. mounts kartboy short shifter w/ front and rear bushings My wallet doesn't agree but with a couple of defi blue racer gauges to keep it in check, it should be fun. I'll have many more pics in the next few weeks as all my stuff comes in and my baby gets put back together. Last edited by elirentz; 08-24-2008 at 07:04 PM.. |
| | #2 |
| Professional STI Racer Feedback Score: 0 reviews Posts: 769
IWSTI Addict since: Dec 2004 | Sounds like a solid plan Matt, can't wait for the end results. |
| | #3 |
| S204 Racer Feedback Score: 6 reviews | Nice work Keep it up |
| | #4 |
| Amateur STI Driver Feedback Score: 0 reviews Posts: 23
IWSTI Addict since: Mar 2007 | Ohh yeahhh |
| | #6 |
| IWSTI Club Level 1 Feedback Score: 5 reviews
Car: OBP-GDB cuh Fav Mod: realtime Location: Fullerton, Ca Posts: 14,016
IWSTI Addict since: Jan 2006 | Are you planning on torquing the ARP head studs after 1k miles? Nobody does it cause it's a *****. But I can tell you are a diy'er. Doooooo eeeiiiiitt. Anyways. I can relate to you and your impulses when stuff in unassembled |
| | #7 |
| S204 Racer Feedback Score: 13 reviews
Car: 05' Sti Black Fav Mod: Dyslexia Location: Central, NJ Posts: 3,352
IWSTI Addict since: Oct 2004 | Nice work with most of the plan, looks like it gonna be pretty wicked when it's done. If you plan to drive the car on the street: 1. Definitely put the AC back in! It's not like you live in Alaska. 2. The Carbotech XP10's are rarely gonna come up to operating temp. If it's a track only car: 1. I would go with a more agressive suspension setup. 2. Get R-comps! |
| | #8 |
IWSTI Addict since: Nov 2005 | Thanks guys. flatthump: Yeah I thought about it then I thought about how much work it is. I pretty much pulled the motor out myself but luckily I have the head tech (I work at a subie dealership) to help me put everything back together the right way. I'm not so sure how well or in how long I could do it alone. |
| | #9 | |
IWSTI Addict since: Nov 2005 | Quote:
Yeah I do plan on going with a more aggressive setup when finances allow which means in several months. The 10's definitely get up to operating temps on the track, even on 245 re-01r's, and I have bobcats for the street. R-comps will come eventually. I planned on doing a more gradual setup change but since I have the motor out it makes it much easier to get the power side situated first. The car definitely handles great as is though. I'm definetly going to have the change my driving style though, which is why I love driving the E30. Last edited by elirentz; 09-15-2007 at 05:50 AM.. | |
| | #10 |
IWSTI Addict since: Nov 2005 | The only reason I even thought of taking the a/c out is because my condensor is a mess after 75k miles and I can't afford to get a new one. |
| Thread Tools | |
