Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Members' Journals
Old 08-26-2008, 09:52 PM   #111
Feedback Score: 1 reviews
Car: AW 08 STI
Fav Mod: torque
IWSTI Addict since: Aug 2008
Send a message via AIM to sysfailur
Default Re: My RaceComp Engineered 2005 STi (Updated pg. 2)
Originally Posted by twiSTies View Post
Well, the results have been posted:
2008 Otto's Mini Summer Series Philadelphia Region SCCA AutoX -- Sportsfest
I was racing in SM and finished 7th. I would have finished 3rd if i didn't hit two cones, but I was fighting severe understeer from the alignment and lack of proper tires all day. After that second run a rain storm hit and covered the lot, so the rest of the day was relearning how to drive the car on the wet with an entirely new suspension, tires, alignment, and a big front swaybar. haha, not too shabby all things considered.
What a small world we live in. So I'm browsing the forum, I see a post you made somewhere. I see "Allentown, PA" as your place of residence, and I just so happen to live in Walnutport (North on 145 about 10-15mins).
Anyway, I then read through your log here and find this post and check out the AutoX results. I scroll to the bottom to get the overall top times of the day and who is in 1st?
1 STU 4 4 Andrew Klucsarits
34.870 *0.830 28.942 0.000 0.000
That just so happens to be my good friends older brother who I knew AutoX'ed but I had no idea he was actually good lol. I'm definitely gonna have to tell him about this. It's just too weird!
Anyway, hit me up sometime.. I'd like to check your ride out
sysfailur is offline   Reply With Quote
Old 08-26-2008, 10:28 PM   #112
Car: AW 08 STI
Fav Mod: torque
Originally Posted by wrxcelration View Post
I always angle over speed bumps and inclines at stock height. If you really want to test out the lip try the entrance to Toys-R-Us by the mall on grape street. That is an ABSOLUTE B**** even stock.
A fix to this solution: Don't go to Toys-R-Us! :P That entrance is nasty, I think I only ever went there once in my LGT when trying to find Rock Band.
Old 08-28-2008, 12:51 PM   #113
Feedback Score: 8 reviews
IWSTI Addict since: Oct 2005
Default Re: My RaceComp Engineered 2005 STi (Updated pg. 4 I can has Recaros)
updated my plans. modding is done for the summer. heading to the track on the 7th to see what she'll run with all the weight taken off in the rotating places. 12.9 at 105 was my previous best 2 years ago before the car really had anything on it.
Still playing with the T2's to find a nice daily driver setting. I'm absolutely loving these things! Since I'm moving to Greensboro, I've decided to keep the 500/400 rates sinc ethe roads will be smoother down there.
Also, since I'm moving to Greensboro next spring, all my spare cash gets thrown into house downpayment savings, so no more buying blitzes This gives me enough time to really enjoy the car as is, which is what I'm doing. I want to hit a few more autocrosses before I leave the area too, even with the PS2's on the car. I'm hoping more neg camber up front will alleviate the understeer.
Oh, ordering a wideband kit for the car so I can log the AFRs in Street Tuner and not worry about tuning the car and it blowing up Should be an easy install.
I can't begin to tell everyone that if you really want your Subaru to handle and ride as good as it gets, get some decent seats and slap some T2's on it. Chassis bracing is key too. It's a totally different experience behind the wheel and I've never been more confident in a car's abilities. It also helps to know that the suspension used on the Viper ACR and its 7:22 Nurburbring run is made by KW.
Doubt I'll have many more updates to this, so signing off in the meantime. Thanks for all of your comments in this journal, it's been a very fun ride this summer.
Old 08-28-2008, 12:52 PM   #114
Power:
APS 65mm Intake
Gimmick Motorsports MAF Hose
Gimmick Motorsports Turbo Inlet
Static X VF-39 Turbo Wrap
Cobb Turbo Heatshield
AREA1320 Ported Intercooler Y Pipe
Perrin Lightweight Crank Pulley
Perrin Equal Length Header (Coated)
Helix Catted Downpipe
Borla XR1 Catback
Walbro 255 Fuel Pump
Prodrive 3-Port EBCS*
Cobb AP w/ Street Tuner
Innovate LC-1 Wideband Kit*
TopSpeed PROtuned 306awhp/341awtq with the Helix dp, a K&N Typhoon, and a 3" ebay catback.
AREA1320 Sticker +50hp
Driveline:
Kartboy Exhaust Hangers
TiC Rear Differential Bushings
TiC Subframe Outrigger Bushings
Kartboy Botox Bolts
Whiteline Steering Rack Bushings
Kartboy Pitch Stop Mount
Kartboy Front Shifter Bushing
Cobb Double-Adjustable Short Throw Shifter
TiC Shifter Linkage Bushings
TiC Shifter Pivot Bushing
TiC Rear Shifter Stay Bushing
TiC Transmission Crossmember Bushings
Suspension:
RaceComp Engineering Tarmac IIs 500/400
Vorshlag Front and Rear Camber Plates
RaceComp Engineering 25.5-28.5mm Front Swaybar
RaceComp Engineering 25.5-28.5mm Rear Swaybar
Kartboy Front and Rear Swaybar Endlinks
Whiteline 'Comfort' Anti-Lift Kit
Whiteline Roll Center Adjuster Kit
Group N Lateral Links Bushings*
Group N Trailing Arms Bushings*
Brakes:
Ferodo DS2500 pads
DBA 4000 Series Front Rotors
Technafit SS Lines
Perrin Brake Master Cylinder Brace
ATE Super Blue Fluid
Chassis Stiffening:
Carbing Front Subframe Brace
CL Development X-brace
TiC Fender Braces
Interior:
EVO VIII Recaro Driver and Passenger Seats
Wedge Engineering Seat Brackets and Height Adjusters
JDM S203 Hazard Button
Autospeed Dead Pedal
JDM Auto Intercooler Spray Button
Prodrive Floormats
2007 OEM Radio w/ Aux. Input and Sub
2007 OEM Sirius SAT Radio Box
10th Street JDM Alcantara Shift Knob
Exterior:
JDM Rear Spats
AREA1320 Painted and De-Badged Front Grill
BeatRush Titanium Belt Cover
Greddy Titanium Radiator Cooling Plate
AMS lightweight battery kit to reduce weight
Grimmspeed Hood Dampers
Black O.Z. Ultraleggera 18x8 wheels w/ 245/40/18 Dunlop SP Sport 600 tires (Summer)
Stock BBS w/ 225/45/17 Toyo Proxes 4 tires (Winter)
* - waiting to be installed or on order.
** - waiting to be removed.
Future Mod List Goals:
-Perrin GT30R .82 rotated turbo kit w/ crinkle red piping
-Perrin Stealth FMIC with crinkle red piping
-Perrin Blow-Through Boost Tube
-Perrin CAI Extension
-Cobb AP V2
-Deatschwerks 850cc injectors
-TGV Deletes
-Cosworth Intake Manifold
-ACT clutch upgrade
-ACPT CF Driveshaft
-DBA 5000 front brake rotors
-DBA 4000 rear brake rotors
-Carbing Under Panel
-APR Strut Tower Bar
-Group N Engine Mount
-Group N Trans Mount
-Upgraded Oil Pickup
Old 08-28-2008, 02:02 PM   #115
that is pretty cool. you should meet up with matt and i sometime. we're probably getting together sometime soon for a photoshoot.
Old 09-05-2008, 11:25 AM   #116
Innovate wideband kit from import image came in the mail. now i can properly datalog the car and make real changes. this is a pretty complete kit, i'm impressed. you get the guage, all the wiring needed, the bosch sensor, and a cd-rom with software to monitor everything. i got the red gauge so the numbers match the dash, although i will probably just run the guage into the glovebox so it's hidden when i'm not logging.
Old 09-05-2008, 04:31 PM   #117
IWSTI Addict since: Jul 2008
Originally Posted by Nachos Libres View Post
Nice looking car. You should at least debadge that dealership emblem though.
Maybe its a sleeper NOCHOS. Not eveything has to be mexican!
Lenny Boottzz is offline   Reply With Quote
Old 09-10-2008, 11:54 PM   #118
Car: AW 08 STI
Fav Mod: torque
Sure shoot me a PM some time!
Old 09-11-2008, 04:26 AM   #119
Feedback Score: 4 reviews
Fav Mod: 57fs
IWSTI Addict since: Jul 2007
Dave, I get my alignment next wed so hopefully itll fix the sound Im having.
So let me know when you want to get some pics together
wrxcelration is offline   Reply With Quote
Old 09-11-2008, 04:34 AM   #120
Awesome, sounds good. I'm free this weekend?
Picked up the factory Sirius kit for my 07 radio yesterday, going to install that tonight.
Privacy Policy
