GD: Trollbaru Reborn 700WHP build (update 4-13-17) - Subaru Impreza WRX STI Forums: IWSTI.com
Go Back   STI Forums > > > GD: Trollbaru Reborn 700WHP build (update 4-13-17)
Old 08-18-16, 07:41 AM   #1
Mr.jingles
Advanced Contributor Level 1
Fav Mod: GF + Victoria Secret
Mr.jingles will become famous soon enough
Default Trollbaru Reborn 700WHP build (update 4-13-17)
As some may know, she's been trolling for over 4 years on 400WHP with over 70,000 miles on the build. I must say that should set some type of subie build longevity record lol Anyways her heart is finally starting to show signs. I'm pushing coolant under load/ WOT, having heating issues and AFR issues to the point I have to run her on an open loop and even then temperamental. Countdown for the build is less than a month. Here is the goodies if the title didn't already give it away
Here is my original thread when I got my subie if you wanna know history
Perrin & Cosworth 07 STI Limited Updated! (4-14-13) - NASIOC
Block: IAG Stage 4 Tuff EJ25 Closed Deck Case Halves, O-Ringed, Bored & Honed to 99.75mm, 14mm Head Stud Conversion, Pinned Mains, ARP Case Bolts with JE Pro seal.
Killer B oil pan kit
Process west street intake manifold
Boomba 75mm throttle body
Internals: CP pistons, manly rods, OEM crank.
heads: new case halves, Ferrea valves, kelford spring and retainers, Kelford 280 cams
Turba: gtx 3584rs 83ar t3, reusing perrin kit
Treadstone 900hp 4.5" thick intercooler
Fuel: ID 2000CC, AI dual 044 fuel pump surge tank setup with SS lines everywhere
AEM Infinity 6 ECU with IQ3 street racepak because i dont have a choice lol also boomslang wiring harness
Other goodies i have
Perrin big tube EL headers
Perrin downpipe modified with dump tube
Perrin mid pipe
Custom Axel back straight pipe with downward cone by ASC Speedmetal
Prodrive ECBS
AEM 3 bar map sensor
DEFI boost, AFR, oil temp and oil pressure gauges
Racecomp tarmac zero coilovers
Whiteline anti lift kit
Whiteline lateral links
Perrin pitch mount, tranny mount, sub/diff lockdown kit, engine mounts
Perrin 24mm sways front and back
Southbend stage 3 daily clutch
Rays 57xx wheels with rays 57xx edition centercaps
18x10 + 20 offset
Continental DW 285 35 summers
Kiks r40 2 piece lugs with red aluminium caps
Karlton flares installed by DTM autobody
Metro performance will be doing the engine work. Easily estimate 700WHP on E85. Stay tuned ****ers!
Trollbaru Reborn 700WHP build (update 4-13-17)-img_20160725_180136_zpsxgihf2q8-jpg
Mr.jingles is offline
Likes 1 Dislikes 0
Old 08-18-16, 07:42 AM   #2
Mr.jingles
Default Re: Trollbaru Reborn 800WHP build in Sept
pics for the illiterate
Likes 1 Dislikes 0
Old 08-18-16, 07:43 AM   #3
Mr.jingles
Here is the machined and pnp heads, also comparison with stock cams vs Kelford 280 cams and also stock vs arp standard size vs 14mm studs
Old 08-18-16, 07:43 AM   #4
Mr.jingles
res 3
Old 08-18-16, 07:43 AM   #5
Mr.jingles
res 4
Old 08-18-16, 07:44 AM   #6
Mr.jingles
res 5
Old 08-18-16, 07:44 AM   #7
Mr.jingles
res 6
Old 08-18-16, 07:44 AM   #8
Mr.jingles
res 7
Old 08-18-16, 07:45 AM   #9
Mr.jingles
res 8
Old 08-18-16, 07:45 AM   #10
Mr.jingles
res 9
