GD: The Engineers STI- 07 STI Limited#534 - Subaru Impreza WRX STI Forums: IWSTI.com
STI Products
Go Back   STI Forums > > > GD: The Engineers STI- 07 STI Limited#534
Old 02-03-12, 08:45 AM   #1
jvsoundwave
Advanced Contributor Level 2
Car: 07 UGM Limited #534
Fav Mod: AirLift Baggs
jvsoundwave is an unknown quantity at this point
Default The Engineers STI- 07 STI Limited#534
IG: @JVsoundwave
Always up-to-date picture of my STI
Car in body shop for major overhaul Nov 2016 thru Present
My two loves got nice ends
My Story
So, November 2010 I finally came back to Suby land. I searched the whole US for a 07 Limited… I had it on my mind since 2007, that I was getting a 07 Limited.. Why? Who doesn’t love the Hawkeye! Besides, there is only 800 made, so I put myself in a elite group of owners who say they have one. So, my search brought about 15 STI’s. Most of them had mileage above 50k, and I really wanted to stay below 40k. No Limited’s were available in the Houston, or even Texas Area! Well, I finally found one pretty close, and it so happened to have the least amount of miles on her (30300). Franklin Tenn! It was a no brainer! I used my miles to fly to Tenn, BOOM, bought her on the spot!
MOD List
Engine:
*COBB Tuning FMIC Black
*COBB Intake w/Intake box
*COBB Crank Pulley
*COBB Tuning 3-Port Boost Control Solenoid
*Cosworth 154 Degree LowTemp Thermostat
*Flat4Motorsport Fuel rail kit (Not Installed)
*Invidia Cated dp
*Motive Autowerks MAW Composite TGV
*Perrin Oil Cooler Kit Custom mounted behind center grill
*Ralco RZ Performance AC Pulley, and Power steering Pulley
*Radium Engineering Dual Catch Can
*Tomei Full Titanium Exhaust w/Blue COBB 15mm hangers/Pro-Bolt Titanium Hardware
Management:
*COBB Tuning Accessport V3
W/ Anti Glare Film and World Rally Blue Faceplate
Misc Engine Bay:
*APR Radiator Cooling Plate Carbon Fiber
*Cobb Heat Shield
*Crowsworth Airpump deletes
*Cusco Cylinder stopper
*Chasebay Power steering tank, with Braided lines
*Cosworth 1.3 Bar High Pressure Radiator Cap
*DC Aluminium High output alternator w/light pulley
*4 gauge blue wire for all grounds, and power wires.
*Full Titanium Hardware mounting front grill, and bumper to frame.
*Dimple Magnetic Transmission/Front Differential Drain Plug
*Hella Sharptones Black/Blue
*GimmSpeed Bro Tie Hella Horn Mount
*Gates Alternator/AC Belt
*Gates Crank/Power steering belt
*Grimmspeed Hood Struts
*Koyo Aluminum Radiator
*Moroso Aluminum Coolant Overflow Tank
*Perrin Upper Radiator Brackets
*Samco Radiator Hose Kit w/Mishimoto Stainless Steel T-Bolt Clamp
Driveline:
*COBB Tuning Adjustable Short Throw Shifter
*COBB Tuning Rear Shifter Bushing
*COBB Tuning Shifter Bushings
*Dimple Rear Differential Magnetic Drain Plug
*Perrin Black Rear Diff Cover w/Pro-Bolt Full Titanium hardware
*Turn In Concepts Rear Diff Mount Bushings Comfort
*Whiteline Rear Diff Support Lock Bushings
*Whiteline Steering Rack Bushings
Suspension:
*AIRLIFT Special STI V2 Bag system.
Air Tank custom installed on Rear Strut bar using Aluminum mounts. All Polished.
*Cusco Adjustable Rear Trailing Arms
*MSI Rear Lateral Links
*Perrin Positive Steering System
*Perrin 25mm Rear Sway Bar W/Stout Mount and Xtream Duty Bushing upgrade kit
*Perrin Xtreme Duty Rear Endlinks
*Super Pro Front Roll Center Adjustment Kit
*Super Pro Front Control Arm Bushing
Stiffers:
*Beatrush rear Strut bar
*Beatrush Add-on Truck Cage
*Beatrush Propeller Shaft Mount Bushings
*Kartboy Rear Subframe Lockdown Bolts
Wheels:
*245/40 Potenza's
*Stock Enkie 17’ Limited Rims (Plasti Dipped)
17x8" Offset: +53. Bolt pattern: 5x114.3. Wheel Weight: 21.2 lbs
*Enkie Blue Aluminium Valves
*Full Titanium Lug Nuts
*ARP Extended Wheel Studs
Brakes:
*Girodisc Custom slotted 2-piese front and rear Rotors
*Tirado Custom Chrome Powder coated Brembos
*Goodridge Brake Lines
*Quantum Motorsports Brake Duct Plate
*Speed Bleeders
Exterior:
*APR Carbon Fiber Mirrors
*Carbign Craft Carbon Exhaust Burn Cover.
*Circuit Demon Headlight Modification
w/ D2S 5.5k Low Beam, Amber markers wrapped in Carbon, Hosing painted black, LED Diode Dynamics
Multicolor Demoneye, LED Turn Signal Morimoto XLB with Diode Dynamics
*Illumaesthetic LED Rear Tail lights
*Juggernaut ABWC1 Air Flow 60mm fender Flares
*Kenwood front and rear camera.
*Morimoto XB 2.0 LED License Plate Lights
*Moveover Racing Quick Release front bumper
*PIAA Aero Vogue Silicone Wiper Blades
*Pro Sticker Carbon front Emblem wrap
*Racing Solution Duck Bill Trunk Spoliler Carbon Fiber
*Subtle STI license Delete
*Seibon Carbon Fiber TT Style front Lip w/NRG washer Kit SS
*Seibon Carbon Fiber Rear Roof Spoiler
*Singular Motorsports Hood Louvers w/Full Titanium hardware, powder coated black
*TopOne Motor Sports Diffuser S2000(modified for my car)
*Rear Custom JV76 plates w/Titanium hardware
*LIMO tint on Sunroof, upper front windshield and rear window.
*30%tint on side windows
*Painted Windshield Wiper Cowl, Painted Rear pillar.
*Shaved Trunk
*Quick-Latch locking hood quick-release
Interior:
*ATI Triple Meter Center Dash Pod
*Blend Mount, Review Mirror Radar mount
*Defi Advance BF Red Gauges 60mm, Boost 30psi, Exhaust Temp, Oil Pressure w/controler
*Escort REDLINE Radar Detector w/Hardwire Radar Mute control
*IAG Billet Drivers Floor Mat Bracket
*JDM STI floormats
*JPM Coachworks‏ wrapped Shift boot, Ebrake, Cell phone holder, arm rest and ATI gauge pod
*Pro Sticker Carbon Steering wheel Emblem wrap
*Perrin Reverse Lockout Lever
*Pro Driven Led bulb replacement
*Subtle Lower ash tray Blank w/Installed
- V2 Digital Bag controller
- STRI DSD SLM II Volt Warning Gauge
*WC Lathe Werks Titanium Shift knob
*Custom Leather Iphone mount
Fluids:
*Gas- Shell 93 Octane
*Engine Oil- AMSOIL SAE 10W-40 w/HKS Hybrid Sports Oil Filter
*Brake Fluid- MotulRBF660 (Adding soon)
*Diff Fluid- Motul Gear 300 75W90
*Transmission Fluid- Motul Gear 300 75W90
*Power Steering- Motul MULTI ATF
*Coolant- Red Line WaterWetter
Trunk:
*Airlift Suspension Controls
*Air Pump
*Air Tank
*AVS Chrome water Trap
*Braille Carbon Battery B2015 w/Braille mount
*Cusco Tower Brace Type-OS Quick Release Clamps
The Engineers STI- 07 STI Limited#534-main-pic-jpg
jvsoundwave is offline
Old 02-03-12, 09:07 AM   #2
jvsoundwave
Default Re: JV’s 07 STI Limited#534 Journal… IM BACK!
My 1st mod!
Battery wasn’t holding a good charge, so I opted for this!
-Bar Spec-
Installed
Old 02-15-12, 02:16 PM   #3
jvsoundwave
Talking Re: JV’s 07 STI Limited#534 Journal… IM BACK!
I was gone to Mexico for 27 days for work, ordered me a few small goodies so that I could start modding ;-)
Heres what was waitng for me!
-Bar Spec-
- Aluminium jack stands
- Heat Gun
- 2 HKS oil filters
- Zero Sports oil plug
- Rick's S2k license plate bracket
- Smoke plate for Licence plate
- Grill Craft upper
- Custom Iphone mount
- Hard wire w/mute for Radar
- Mount for Radar
- Enkie Almuninium Valves (to Match my Enkie STI rims)
Not Shown:
- Custom Licence plate frame
- Ebay STI mats
- Plasti dip
Ok, Modding begins!
Old 02-15-12, 04:52 PM   #4
janderson13
Advanced Mastery Level I
Car: 04 WRX STi WR Blue
Fav Mod: Decent gas mileage, the BRAKES!!
janderson13 is an unknown quantity at this point
Get some pics of the floor mats up id love to see them! sexy car by the way.
janderson13 is offline
Old 02-15-12, 05:17 PM   #5
jvsoundwave
Thanks! Im doing some Modification to the Mats, but they'll be in soon.
Old 02-15-12, 05:33 PM   #6
jvsoundwave
OK, Got my Ricks S2K Bracket Painted, and gathered up some hardware to match.
Cut the Smoke Shield to fit inside my custom frame... Also Plasti dipped the back of my plate for added protection
Ok, Hope to have it mounted soon.
Old 02-16-12, 12:19 PM   #7
jvsoundwave
Changed my oil for the 1st time!
JDM Hottness!
And... Started to Plasti-dip my Enkie's... This is a temp, till i order new rims.
Old 02-17-12, 11:26 AM   #8
06JcSTI
Master Contributor Level 2
Car: 2006 CGM STI
Fav Mod: Driver Mod/Boost
06JcSTI is an unknown quantity at this point
Nice ride brotha
Sent from my Galaxy SII using Tapatalk
06JcSTI is offline
Old 02-17-12, 12:41 PM   #9
xe808
Advanced Contributor Level 5
Feedback Score: 5 reviews
Fav Mod: Too many to list
xe808 is an unknown quantity at this point
very nice looks super clean with some tasteful mods
xe808 is offline
Old 02-17-12, 03:12 PM   #10
1shot1kill
Advanced Contributor Level 1
1shot1kill is an unknown quantity at this point
nice pick up bro.. i got a limited too.. white tho. plastic dip'd my rims for winter as well lol
1shot1kill is offline
Privacy Policy
