Subaru Impreza WRX STI Forums: IWSTI.com
Home  |  Register  |  Today's Posts  |  Go Premium  |  New Posts  | Mark Forums Read Create a Member Journal  |  Marketplace
Go Back   Subaru Impreza WRX STI Forums: IWSTI.com > GD Series STi Discussion (2003/4-2007) > GD-Members' Journals
Old 10-15-2009, 12:38 PM   #1
Uranium Member
BAD STI's Avatar
Wink Jared's 06 SGM STI (build plans on post 2891).
Mod List:
Engine/Fuel:
-APS 70MM CAI
-Perrin lightweight crank pulley
-Grimmspeed 3 port EBCS
-Coolingmist CMGS-FS kit with trunk mount tank
-Forge BPV
-Wabro 255 LPH high pressure fuel pump
-NGK Iridium 1 step colder spark plugs
-Cobb Accessport
-Cobb heat shield
-Deka ETX14 lightweight battery (11 lbs)
Exhaust:
-Cobb catless downpipe
-Cobb exhaust
-Cobb exhaust hangers
Drivetrian:
-TWM short shifter
-TWM M1 Abrams Satin heavy shift knob
-Kartboy front and rear shifter bushings
-TIC shift linkage bushings
-TIC pivot bushing
-ixizSclutch clutch over-travel adjustment device
-Whiteline rear subframe lock bolts
Suspension:
-RCE Yellow springs
-Group N front top hats
-Cobb front and rear sway bars
-Cobb front and rear end links
-Cobb adjustable sway bar mount
-SPC front and rear camber bolts
-CL X-Brace
Brakes:
-Cobb SS brake lines
-Centirc Premium rotors (not yet installed)
-Hawk HPS pads (not yet installed)
tires/Wheels :
-Bridgstone RE760
-Anthracite powedercoated OEM BBS wheels
-Limited "STI" center caps
-Mcgard black lug nuts
Exterior:
-Replica V-Limited lip
-Tint 20% rear, 30% front
Interior/ Electronics:
-Black floor mats with pink "STI" embroidered
-Lo-Tek pillar pod, painted to match the OEM gray
-PLX DM-5 wideband gauge
-PLX SM-AFR wideband sensor
-Coolingmist CGMS-FS controller
-Interiorflair red clock
-Interiorflair red footwell lighting
-Interiorflair red HVAC
-Kenwood DDX 512, 6.1" screen receiver
-Omori 45mm boost gauge
-Apexi Autotimer
-Clock auto-dim delete
Countermeasures:
-Valentine 1 radar detector
-Blinder M27 Extreme laser jamer
-Laser Veil on headlights and taillights
-Ontrack license anti-laser plate cover
Other:
-ixizHood hood damper
-Sig P250 .45ACP (yes I bought it to be dedicated car pistol )
-Ka-Bar Short (5.25" blade under the legal limit of 5.5")
Alignment:
-2.0 front, -1.75 rear
Current Dyno:
2006 STI - 321whp / 377 wtq
Upcoming Build:
Purchased:
-Blouch 20g-XT 3" inlet 8cm2 hotside
-APS 3" inlet
-Grimmspeed EWG upipe
-Tial 38mm V-band EWG
-PTP turbo blanket
-ixizAOSep
-Centric Premium rotors
-Hawk HPS pads
-ATE Super Blue brake fluid
-Grimmspeed 3mm phenolic spacers
-Grimmspeed TGV gaskets
-Torque Solutions pitch stop
-Spearco TMIC
-Turbineguy port matched, extrude honed and radiused Y-pipe
-Intercooler couplings
-ZeroSports intercooler splitter
Need to buy:
-DW 1000cc injectors
-Litespeed UEL headers (not yet released)
-Grimmspeed TGV deletes
-PLX Device boost gauge
-Boost pressure switch for IC sprayer
-Exhaust wrap
_____MORE TO COME_____
BAD STI is offline   Reply With Quote
Old 10-27-2009, 08:22 AM   #2
Uranium Member
BAD STI's Avatar
Default Re: Jared's 06 SGM STI (a work in progress)
Old 10-27-2009, 10:45 AM   #3
Feedback Score: 11 reviews
TIMELESS's Avatar
Send a message via AIM to TIMELESS
Default Re: Jared's 06 CGM STI (a work in progress)
Wow seems like you work fast haha. That's a lot of stuff to install in a month. Alky will give you a nice boost in power.
TIMELESS is offline   Reply With Quote
Old 10-27-2009, 11:18 AM   #4
Uranium Member
BAD STI's Avatar
LOL I was sick with the flu for a week and worked on my car then as well. Its almost done . I will be able to rest after my protune. LOL my girlfriend is pissed. Between work, school at night, and my car I've seen her like twice this month .
Old 10-30-2009, 11:27 AM   #5
Feedback Score: 6 reviews
Boris's Avatar
Send a message via AIM to Boris
no pics?
Boris is offline   Reply With Quote
Old 10-30-2009, 11:29 AM   #6
Uranium Member
BAD STI's Avatar
Originally Posted by bfedorov14 View Post
no pics?
I need to get a photobucket account or something. 90% of the time I'm online I'm at work and I can't access that site here. LOL. I'm doing a photoshoot next month.
Old 10-31-2009, 09:49 PM   #7
Unclejesus's Avatar
How much power did you end up with?
Invidia V2 DP--Injen Intake--Blitz Turbo Timer--Act Streetlite Flywheel--Exedy Organic Clutch--Accessport V.1--GroupN motor mounts--Maddad Gauges(Ati Clock Pod)--Hawk HPS Pads--RCE Yellows--SSAC FMIC--Maddad Header/UP--Megan Black 3in CB--GMS Turbo Inlet--Walbro FP--Prodrive BCS--Siegel Tuned--Alpine 9874--Forester din pocket--18x8.5 Grids--235/40 Dunlop Z1's
Unclejesus is offline   Reply With Quote
Old 11-02-2009, 07:35 AM   #8
Uranium Member
BAD STI's Avatar
314 whp, 370wtq. Keep in mind its a mustang dyno.
http://www.iwsti.com/forums/power-br...p-370-wtq.html
Old 12-01-2009, 10:54 AM   #9
Feedback Score: 1 reviews
Send a message via AIM to NaiveRapture Send a message via Yahoo to NaiveRapture
God damn that's a lotta torque for what you've got going on haha, and from what you said about other STi's making on that same dyno, you would definitely make more on another dyno!
NaiveRapture is offline   Reply With Quote
Old 12-01-2009, 11:07 AM   #10
Uranium Member
BAD STI's Avatar
Yup stage 2's protuned with out meth were putting down 285whp.
Im getting the tune tweaked this Saturday and will hopefully make more.
Powered by vBulletin® Version 3.8.6
Privacy Policy
