Well here she is, I figured I would post up a thread here on nasioc so I can get some constructive criticism and some feedback on what I have going on with the car.
Anyhow, I have a 2007 STi with just passing 14,000 miles. I got the car with 7,000 miles and bone stock and I have been building it since. I have just recently (within the past year and a half) have found a passion for autocross and track days, so this is the route I have decided to take my car down. It still spends some time around on the street though
Mods to date..
Tuned on Cobb speed density by Nate Silveri at TPG tuning
Engine
*Now on E85!
-Darton sleeves
-O-ringed
-JE forged pistons 99.5mm CR: 9.0:1 (coated, Tool Steel Wrist pins)
-Maxwell power H-beam long rods +2mm
-King XPG extra clearance
-Crank: nitrated crank
-ARP custom age 625 Headstuds
-Heads ported (done by Curt Brown)
-Custom headgaskets
-GSC S2 cams
-STD size Super alloy valves
-GSC Beehive spring and retainers
-Gates Timing belt
-Motive Composite TGV deletes
-Stock STi 10mm oil pump
-Killerb oil pickup & baffle
-LGT/wrx plastic manifold (reversed)
-Ported WRX throttle body
-ACT XT-SS clutch
-ACT Streetlite flywheel
-Koyo Vh091672 Radiator
-AMS GT3076 rotated turbo kit
-Tial .82 hotside
-Tial 44mm wastegate
-Custom TPG Intercooler piping
-4" intake
-Litespeed UEL header
-Perrin FMIC core (Silver)
-Cobb accessport V2
-Blitz Nur Spec R catback exhaust (removed taper)
-Hallman Pro RX MBC
-Tial BOV
-IAG AOS
-ss power steering line
-Dei titanium heat wrap (Up pipe, Header, Downpipe, Ewg dump tube)
-Painted engine bay caps
-Braille 15 lb battery
-NRG hood struts
-KSTech air pump delete block off plate
-PTP T3 turbo blanket (silver)
-NGK one step colder plugs
-GM air intake temp sensor
-Omni 4bar MAP sensor
-MAF sensor block off plate
-IAG ewg up pipe
-Peterson catch can
-Tial 38mm MV-S with 1 bar spring
-Synapse synchronic bov
-Grimmspeed VF series IWG bracket
-Cobb SF intake
-Invidia V2 catless downpipe
-Aquamist HFS-6 Meth kit
-Stock BPV
-MAC valve (allows use of aquamist failsafe with MBC)
-Coolingmist CMGS-FS meth kit
-Ultimate Racing up pipe
-Ultimate Racing flex dump tube
Fueling
-Injector Dynamics 1300cc injectors
-Radium Engineering 2x Walbro 255 pumps
-Radium Engineering surge tank
-Russell "Pro Classic" -8 & -6 Fuel Lines
-Fuelab Fuel Pressure Regulator
-Fuelab fuel filter
-Cosworth Top-Feed Fuel Rails
-Walbro 450lph (in tank)
-STM battery re-wire kit
-Walbro 255lph fuel pump
-Injector Dynamics 1000cc injectors
Fluids
-Brad Penn 15W-40
-Purolator PureONE filter
-Shell Rotella T6 15W 40
Heat Shielding
-Turbo blanket
-Thermotec copper exhaust wrap on dp
-Cobb Turbo Heat Shield
-DEI Cool Tape on shield and intercooler
Drivetrain
-TiC super shifter set
...TiC STi Shift Linkage Bushings
...Kartboy Front and Rear Shifter Stay Bushing
...Kartboy Shifter Lever
...Pivot bushings
...Pivot bushings
-TiC rear diff bushings
-TiC outrigger bushings
-TiC subframe bolts
Suspension
-Racecomp Engineering Tarmac 2 coilovers
-Swift 9k 6" front springs
-Swift 8k 7" rear springs
-Hyperco helper springs
-GTWORX camber plates (front/rear)
-Custom X-brace
-RCE yellows
Exterior
-HKS Kansai Diffuser
-Tint on rear windows (not sure what %)
-Debadged all but sti and center Subaru logo
-05 Tails
-WRC tail light mod
-Blacked out headlights
-Chrome indicator bulbs
-Chrome front and rear turn signal bulbs
-White STi fog light cover stickers
-Passenger fog light bezel
-Custom DIY Front air splitter (for autocross/track use)
-Baysonr front lip painted satin black
Interior
-Sparco EVO II blue
-Sparco bracket
-Sparco sliders
-Sparco side mounts
-blacked out:
*black microfiber suede headliner
*pillars
*visors
*dome lights
-Nardi Personal Neo Grinta 350mm steering wheel (black leather)
-NRG quick release
-Works Bell hub
-Teamtech silver 3" harness
-Autometer Elite series vac/boost gauge
-Autometer Elite series oil pressure gauge
-Autometer Elite series oil temperature gauge
-Sparco Harness bar (painted honda gray metallic)
-Clarion MAX385VD head unit
-Blacked out center dash, vent rings, polished shift trim
-ATI gauge pod
-Type S universal holder (use for accessport)
-AEM digital Boost gauge
-AEM digital Oil Pressure gauge
-Aquamist meth flow gauge
-JL audio 12" W7 with ported box
-Hifonics 1200w amp
Wheels and Tires
TRACK
-Enkei RPF1 17x10
-Toyo R888 275/40
STREET
-Enkei RPF1 black 18x9.5 +38
-8mm spacers for front
-ARP extended studs
-Project Kicks neo chrono R40 lugs
-255/35 Star Specs
-Fenders rolled and pulled
-Konig Hotswap black 18x8 +40
-Falken 225/40/18
Weight Loss
-Removed spare tire and jack
-Removed Oh S*** Handles and brackets
-Air pump delete
-Removed all back seat seat belts and supporting hardware
Waiting to be installed/ On the way
Red- for sale/ sold
Green- removed
Latest Test Results
...compression.. Leakdown
Mods to date..
Engine
*Now on E85!
-Darton sleeves
-O-ringed
-Custom headgaskets
-GSC S2 cams
-Gates Timing belt
-ACT XT-SS clutch
-Tial .82 hotside
-4" intake
-Cobb accessport V2
-Hallman Pro RX MBC
-Tial BOV
-IAG AOS
-NRG hood struts
-IAG ewg up pipe
-Peterson catch can
-Cobb SF intake
-Stock BPV
Fueling
-Fuelab fuel filter
Fluids
-Brad Penn 15W-40
Heat Shielding
-Turbo blanket
Drivetrain
...Pivot bushings
...Pivot bushings
-TiC subframe bolts
Suspension
-Custom X-brace
-RCE yellows
Exterior
-05 Tails
-WRC tail light mod
Interior
-Sparco EVO II blue
-Sparco bracket
-Sparco sliders
-Sparco side mounts
-blacked out:
*pillars
*visors
*dome lights
-NRG quick release
-Works Bell hub
-ATI gauge pod
-Hifonics 1200w amp
Wheels and Tires
TRACK
-Enkei RPF1 17x10
-Toyo R888 275/40
STREET
-ARP extended studs
-255/35 Star Specs
-Falken 225/40/18
Weight Loss
-Air pump delete
Red- for sale/ sold
Green- removed
Latest Test Results
