Go Back   IWSTI.com: Subaru WRX STI Forums > GD Series STi Discussion (2003/4-2007) > GD-Members' Journals
Old 05-08-2009, 12:38 PM   #1
Feedback Score: 1 reviews
My StuffSubaru Parts
Fav Mod: AEM STANDALONE!!!
IWSTI Addict since: May 2009
Default 07EVOK1LR- Topspeed Customer Service In Action!!!...600 whp and TOPSPEED FTW!!!
Table of Contents:
Current Setup- post 1
Weight reduction list- post 7
Power numbers and graphs- page 42
Taken from another's Journal.....
Parts/ Mods I love
So So, Could be better
Waste of money or Not at all what i expected
Journal in Progress- Pic Below is pretty old but it gives the idea before i can get more
Motor and car is being put back together at Topspeed in Alpharetta, GA after having two failures with different shop. Tried to list all the mods below. Still exploring a new engine management unit to replace AP, shooting for 450-500 on 93, 550 on 93/meth, over 600 on 100/meth when its all said and done. I'll try to keep the journal updated as best I can. Thanks and any input is appreciated.
SETUP IN PROGRESS
Engine
Raw Performance Track Series Shortblock- OLD- stock SB with Wiseco forged pistons, cometic/ cosworth HG's, arp headstuds
2.5 Liter STi semi-closed deck case
Modified forged EJ257 crankshaft
High Performance Main & Rod Bearings
Pauter 4340 Chrome-Moly Forged Rods
CP Forged Pistons w/ Moly Coated Skirts
High Performance Piston Rings
Fully Balanced & Blueprinted
8,500 Rev Limit Recommended
ARP Headstuds
OEM Headgasket FTW cosworth and cometic can suck it (they both failed on my dom3 setup)
OEM Gasket Set
Cosworth Billet Timing Belt Guide
Heads/ Headwork
Supertech Valve Springs/ Retainers
Supertech Oversized Valves EXTREMELY worried after Jays05 and other failures pertaining to their valves, we'll see i guess
Topspeed Headwork/ Porting
Gsc S2 Cams
Air Pump Delete
Oiling
Custom Setrab Oil Cooler With 180 Degree Thermostat my finest moment of creativity
Aftermarket Oil Pickup
Modified Crank
Modified 11mm Oil Pump
Fuel
1000 cc DW's OLD- 860cc DW's
Perrin Topfeed Fuel Rails
Aeromotive Fuel Pressure Regulator
Dual Walbro Fuel Pumps OLD- single walbro
AEM Progressive Meth Kit- 100 Percent controller has stripped screws and impossible to set begin/full 100 % accurately, other than that for the price you really can't beat it (UPDATE- replaced pump with 250 constant flow Coolingmist Pump, custom SS lines with check valve and in-line filter)
Cooling
Koyo Aluminum Radiator no need for a shroud with this bad boy
edit- stock caps
Oversized Overflow- OLD Perrin overflow
edit- stock Thermostat
Gimmick Motorsports Radiator Hoses, top- hardpiped
Induction
Looks like Perrin Fuel Rails are going to force using a 4"to3" reducer o well
OLD- spt sr intake, perrin big maf sr, custom 3" cai using perrin big maf
P and L 35R (Fp HTA 3582) .82 with V-band Flanges- OLD- Dom 3.0R w 2.4 in and 3.0 in inlet, gimmick motorsports silicone and aps hard inlet
Perrin Front Mount Intercooler Perrin's finest product
Perrin Blow Thru IC Piping- OLD IC piping w/o blow thru
Perrin VTA BOV- OLD forge recirculating BPV with BLUE spring
PnP Intake Manifold- Self Done REALLY want cosworth mani
PnP Throttle Body- Self Done
8mm Phenolic Spacers not sure of the true benefits
Profec B Electronic Boost controller
Grimmspeed Coated TGV Deletes
Exhaust
GT Spec Equal Length Header GREAT quality piece, great welds- OLD Perrin El headers (cracked- don't wrap them) PnP Grimmspeed coated stock headers and cross pipe
P and L Rotated Uppipe- OLD- Gimmspeed PnP uppipe, Gimmick Motorsports 44mm EWG uppipe (cracked and wg fell off)
44mm Tial V-band External Wastegate will never go back
P and L Rotated Downpipe- OLD Invidia catted V3, Invidia catless V2
Invidia G200 Catback
Drivetrain
ACT Streetlite Flywheel
Perrin Lightweight Crank Pulley- Removed- Stock Crank pulley put back on
ACT HD Pressure Plate
ACT 6-Puck Sprung Clutch- OLD ACT streetdisc
A.C.P.T. Carbon Fiber Driveshaft love it for weight savings, other than that it was expensive and power inc to the wheels is imo a myth
Cobb Adjustable Short Shifter
Kartboy Front and Rear Shifter Bushings much better feel- OLD Perrin front shifter bushings (overtightened, whoops)
Subaru Titanium Shift Knob- NOT ANYMORE
Abrams 400g Satin Shift Knob
Beatrush Tranny Mount
Kartboy Tranny Crossmember bushings
Beatrush Pitchstop (Aluminum Not forged)
Beatrush Engine Mounts-
Tires/Wheels
17X8.5 Enkei Rpf1's +40 offset a bit too radical, couldnt fit 245's for rubbing reasons, so I wish I had a +45-47 instead but for 780 shipped I couldn't beat the price
235/40/17 Dunlop Direzza Z1 Star Specs great tires for dry and wet
Hawk HPS rear Brake Pads w/ stock rotors
Brake Man LW Front Rotors- installed DAMN light
Brake Man #93 front pads
Suspension
RCE Yellows ALWAYS wonder if coilovers would have been better...o well OLD- tein H-techs
Perrin 25mm Front/ 22mm Rear Swaybars both on soft setting
Greddy Font Strut Bar- OLD ebay front strut bar
Cusco V-Brace - mated to an ebay rear strut bar, creaks somewhat
Cusco Trunk Brace
Beatrush LW Subframe
Whiteline Steering Rack Bushings
Perrin Rear End Stabilizer Bushings/ Lockdown Bolts
Whiteline Roll Center Adjustment-
Perrin ALK-
4- H and R Camber Bolts-
Electronics
Braille 15 lb Battery
A-Pillar-52mm- red
Defi Boost Gauge
AEM Uego Wideband
Prosport EGT Gauge
ATI clock Pod- 52mm-red
Prosport Oil Temp
Prosport Oil Pressure
Prosport Clock Gauge
AEM Standalone with harness for 2007 STI
AEM 3.5 bar MAP sensor
Profec B Electronic Boost Controller
Blitz Turbo Timer
ETC
Sparco Pro2000 Driver's Seat
Scoop Delete- Flat Vent
All Kind's of heatwrapping- all exhaust, cold side IC piping etc
Twin Greddy Catch Cans
Cleared Headlights
OBP Paint matched Vent and Paint matched V-Limited Lip replica
Debadged
35/20 Tint
Tein Hood Dampers
"EVOK1LR" TAG
Subie Underseat Sub- with all the weight reduction I can't get myself to remove it lol
Armrest Extension
Weight Reduction- TOO many to list right now but still "full" interior
As of 2/1/10- 3043 lbs- 58.9/41.1 F to R distribution
OLD SETUP BASICS-Tuned to 464 whp 505 ft/lbs-
Blouch Dom 3.0 R
850 cc DW's
V2 AP
100% Meth
Perrin FMIC
Click image for larger version
07EVOK1LR is offline   Reply With Quote
Old 05-08-2009, 01:38 PM   #2
Default Re: 07EVOK1LR- Final Build
Almost Done....
Old 05-08-2009, 04:46 PM   #3
Just Pm'd Ben to get the Brake Man rotors
Old 05-09-2009, 03:32 PM   #4
Working on list of weight reduction mods.....After reading A-Man's journal it seems everything he has done coincides with my mods but what the heck I'll post em up anyway and maybe the differences will stick out
Old 05-09-2009, 06:43 PM   #5
Lighter, faster, better
Feedback Score: 16 reviews
Fav Mod: Litespeed Titanium turbo heatshield
IWSTI Addict since: Jan 2009
Well, not quite everything...like 500whp ! Cool vehicle and mod list man. Get us up some pics of all this great stuff.
You can go nuts with the weight loss but it does make a difference, not like 200 whp difference, but it does make the car feel better. Some of it's free and some of it's pricey but it's all fun. I decided to do my big power mods at some indefinite point in the future. Just making the car alot of fun with the stock turbo right now.
Can't wait to see more - subscribed.
A-man is offline   Reply With Quote
Old 05-09-2009, 07:00 PM   #6
yea thanks A-man (funny my names Alex and thats what my dad calls me anyway) but i have pretty much done all the weight mods you have done (i stalked your journal yesterday) i really want to get more of that firewall crap out but w/o taking out the dash ive gotten as much as possible
I've noticed my car is a bit *** happy being 2/3 of the weight has come out of the rear especially with the rear bumper beam etc so I am trying to get those front rotors I first found in your journal and possibly switch to a 22mm solid rear sway as opposed to the 25 on there now
but I am going to try and post more info and pics as I have time etc but thanks for your interest as your car is one of the subies I am modeling after
Old 05-14-2009, 06:55 PM   #7
Weight Reduction List WISH I had step by step pics but when I get my car back I will take pics to try and show results
Body (Trunk)- Rear Bumper Beam/ Foam (installed cusco trunk bar to reinforce chassis in its place
Rear Tow Hook/ Unnecessary Bolts
Entire IC Sprayer from tank to nozzle
Entire Trunk Accessories- Carpet, Spare, Tools, Etc
Debadged
Body (Rear)- Driver's and Passenger's side rear seatbelts and components
Sound deadening, baby seat brackets, baby seat vertical supports, behind rear seat (now is open to trunk with rear seat removed)
Kept horizontal under seat brace still for chassis stiffening
Removed front to back bars that connect to under seat brace
Removed all other unnecessary components under seat
Body (Front)
Glove Box reinforcement bar
Both Driver's side Dash Metal brackets (keep knees from smacking under steering column I assume)
Removed as much sound deadening and padding under front carpet/ firewall without removing dash
Removed Dead Pedal Components
Hardwired Button under clutch pedal and removed it (makes you press clutch to start car)
Removed a few light pieces "I" think aren't necessary in door panels- AND has anyone felt how light our speakers are lol- no metal at all- STILL in car
Removed Metal Brackets and supports protecting ECU on passenger side- Passengers are thoroughly reminded lol
Driver's side seatbelt- very heavy
Body (etc Front/engine bay)
Removed Factory Oil Cooler
Air Pump Delete
Removed Front Bumper beam and foam (replaced with Perrin IC)
Removed TMIC obviously
Cut and Drilled IC support bracket (re
moved around 9 lbs)
Removed Washer Reservoir
Trimmed Bumper Cover Fog Extrusions (plastic extensions behind fog covers- no fogs ever obviously)
Removed some unnecessary bolts and nuts (for example 1 bolt and 1 nut out of the 4 on each headlight holding it in place)
Intake snorkel etc etc
A/C (condenser, compressor, lines)
under hood bonnet
wipers
wiper motor
LW parts
Carbon Fiber Driveshaft- 11 lbs
Brake Man Front Rotors- 10 lbs per rotor
Braille 15lb Battery
Sparco Pro 2000 Driver's seat- a bit over 20 lbs said and done
Beatrush LW subframe
Enkei RPF1's- about 2 lbs per wheel
Uppipe/ Turboback exhaust etc etc
Hood Vent replacing hood scoop
LW crank pulley RETURNED to stock pulley
LW Flywheel
EL Header
Plus other engine parts/ internals
PLUS lots of crap that have ADDED weight that I won't mention now- I am going to weigh my car on SCALES when i get it back, I am hoping for 3000-3100 somewhere in there
Old 05-14-2009, 07:11 PM   #8
lol every thing in this post was wrong
Old 05-15-2009, 01:51 AM   #9
How did you remove CEL's after air pump delete?
And definitely post up pics when you can.
Old 05-15-2009, 10:14 AM   #10
IWSTI Addict since: Sep 2008
Delete wrong thread
stiguy34685 is offline   Reply With Quote
Similar Threads
Looking for 340-350AWHP, suggest a build! cloSTi 2.5 Liter/Litre Factory Motor 65 01-01-2009 07:55 AM
BDSTI Brand new jorunal and engine build! New Pics inside!!! BDSTI GD-Members' Journals 6 12-02-2008 02:04 PM
AMS Top Shop Engine build..the quest for 1000hp on 100octane! AMS Vendor Announcements & Project Buildups 8 11-05-2008 04:58 PM
planning build MaSTi04 2.5 Liter/Litre Factory Motor 11 08-17-2008 01:54 AM
ICS '08 STI Project Stage "X" Build Up Dyno Flash 2.5 Liter/Litre Factory Motor 18 06-22-2008 08:51 AM
Privacy Policy
